Question about Juki MO-644D Mechanical Sewing Machine
Does anyone know what model juki was used in the B-line long arm machine made in British Columbia?
Cannot find a model number and need the bobbin hook assembly
yalmer
  • 549 Answers
SOURCE: threading a juki ddl 5530
Go to this link and you will find how to thread your machine.
Posted on Apr 02, 2008
  • 13 Answers
SOURCE: juki ddl-227 industrial machine
Before all else. Turn off machine!
(1) break screws on the hook loose.
(2) tighten one back up very skightly, one you can reach when the needle bar is at its lowest position.
(3) lower needle bar to its lowest position.
(4) loosen the screw just tightened.
(5) position the tip of the hook behind the needle hole. the tip should be as close to the needle hole as possible without actually touching the needle
(6) tighten screws
(7) slowly hand turn the machine (depress the foot pedal to disengage clutch brake on motor) several revolutions to make sure the needle doesn't hit anything on the hook.
(8) if it passes this test, try on a scrap of fabric
Posted on Dec 15, 2008
  • 14 Answers
SOURCE: Juki TL-98QE thread comes out of needle, won't pull up bobbin
It can be many things but first make sure the needle is in correctly, follow the manual to be sure, if it still does not pick up the bobbin thread you may want to bring it to a repairman to see if it is out of timing.
Posted on Jul 07, 2009
  • 47 Answers
SOURCE: I am looking for a owners manual for a Juki ddl 5500 machine
Www.ifixmachine.com has lots of manuals and parts for a cheaper price
Posted on Jul 24, 2009
  • 125 Answers
SOURCE: i have a juki industrial machine when i try to
so many different versions to disengage the drive, but all are located on the right hand side of the machine on the part that allows you to rotate the sewing mechanism by hand. there is likely a button or that part will pull outwards
Posted on Aug 16, 2009
Testimonial: "thank you so much there is not a button so it must pull out i will try it tomorrow"
Cannot pull bobbin thread up on juki 2200 longarm
replacing the bobbin carrier has upset the needle/hook timing
readjust or take it to a machine shop to have it adjusted
Jul 24, 2017 | Juki Sewing Machines
Looper arm does not clamp over bobbin case all the time
If the arm does not clamp over the bobbin case, it is probably because the bobbin case is not securely in its place (make sure you are using the correct bobbin and it is loaded into the bobbin case correctly). Be sure that the bobbin case is inserted correctly and securely latched.
If problems continue, may want to consult a repair service.
Jan 02, 2016 | Juki TL-98Q
Manual needed for juki ddl 555 also need bobbins for this machine
go to the Juki website and ask them about a manual and bobbins
Mar 15, 2015 | Juki Sewing Machines
Why is my juki sewing machine sewing loose bottom stitches?
How thoroughly have you cleaned out the hook race area? Take a clean piece of cloth, and wipe it out. Look for fluff, bits of thread, etc.... You might need to tighten up your bobbin casing. If there's a screw there, get a flat edge screwdriver and very gently tighten it a little bit, then try sewing a scrap of lamb. You also may need to interface your lamb, so it's more stable.
List the model number of your machine, so anyone replying will know exactly what you're dealing with.
Jan 11, 2015 | Juki Sewing Machines
Juki.co.jp
Make sure you are threaded correctly. Also be sure that your bobbin is sitting in the casing correctly. If the timing is right and the hook is catching, the thread may not be pulling through correctly. Clean your machine as well. Make sure your tension spring is clean and doesn't need to be tuned up.
May 01, 2014 | Juki Sewing Machines
Skipping stitches on bobbin thread Juki DDL555-5. any suggestions?
sounds like u have the wrong needle or machine is out of time. if its a needle feed machine u might have the wrong bobbin case. try lowering the needle slightly. machine is easy to time. theres a mark on the needle bar which u align with the bottom of the bar guide then loosen the hook (3 screws) and move hook till it just starts to meet the needle. careful of side to side movment. bobbin case has to remain in the finger.
Mar 27, 2014 | Juki Sewing Machines
I have an 8700 juki industrial machine and as I'm sewing the thread will not catch on the bottom bobbin. I'm frustrated.. It was fine the last time I've used it.
machines do not just go out of time. Is the top threaded correctly. did u miss threading thru the take up arm or take up spring change needle too.
Nov 26, 2012 | Juki Sewing Machines
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
Bobbin tension problem with kenmore model 385.16231300
If You have a drop in bobbin you will have to remove the hook and adjust the tension, however try adjusting the top tension before you remove the hook.
Jul 17, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Juki MO-644D Mechanical Sewing Machine Logo
16 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
