Question about LG Washing Machines
LG- Front Loader making loud deep humming noise prior to draining.
Cleaned, Inlet Hose filters, Cleaned Dischsrge filer, and drain. Checked Outlet hose, still making adeep noise, and then slowly drains, then drains ok.... Worried a pump is going?
    Champion:
  • 207 Answers
I had the same problem. Loud noises during draining operation. It turned out to be the drain pump motor. The impeller that pumps the water wears out on the shaft, and then starts to flop around creating vibrations, and in turn the noises you hear. The pump is a very inexpensive part. $35-50. There is some work involved to get to it, and to replace it, but not overly complex. Just watch the motor wire connections. Take a picture with your camera/phone of the connections. I would recommend watching the youtube video in the link provided on how to get to the motor, as some of the steps can be challenging, especially the drum seal retaining ring removal and reinstallation steps. https://www.youtube.com/watch?v=8cPl22OC9f4 .
Good luck.
Posted on Apr 15, 2014
    Habit-Forming:
  • 165 Answers
The same problem I cleared today,, it is the drain pump. You have to change it.
Posted on May 10, 2015
  • jalal May 10, 2015
  • 185 Answers
SOURCE: LG WM1812CW Does not Drain
check the timer
Posted on Mar 26, 2008
  • 161 Answers
SOURCE: My LG Tromm WM1814CW is not draining. I cleaned
Check inside the filter housing with a flashlite for debris that got around the filter. If it is clean, you have a bad pump and it needs to be replaced.
Posted on Jan 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: LG front load washer OE error. cleaned filter need
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
Posted on Sep 18, 2010
  • 489 Answers
SOURCE: On the LG Tromm front
You have a broken drain pump and it will need to be replaced.
Good luck
Posted on Jun 15, 2011
Macmarkus
  • 2605 Answers
SOURCE: F02 Error Code on Kenmore
Hello, welcome to FixYa.
Based on your information posted I understand you have the Kenmore HE3t washer, correct ?
Reading your description and factoring in all you've done and inspected, it may in fact be a faulty pump...(the F02 ultimate worse case) even if it is draining slowly it does not rule it out, trust me I've seen many of them.
By reading your post I've gathered you are pretty thorough so I don't expect you missed it, but I must mention it or I wouldn't be thorough either, I think you can appreciate that, have you checked the back-flow/check ball ?
If not, here's how...
Pull the boot off if you have not and just see if anything has got in there to obstruct the "ball" from working correctly. It is shown here...(this is from the back, but you can do it from the front...just not as easily...in my opinion)
Undo the clamp and inspect inside...if you have not already.
It's amazing how often I find this ball "stuck" or the bellows clogged with debris of all sorts of items...definately worth looking into before declaring the pump has failed. Good luck. Let me know how you make out as I said and if I can help you in any manner going forward I will do whatever I can.
I've also included a more thorough link of my repair tip below
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for choosing FixYa. Please take a moment to rate the info provided here and a testimony on your experience here at FixYa today is appreciated.
Regards,
Macmarkus :)
Posted on Sep 11, 2011
My LG front loader will not drain. I took the drain hose off, no clogs. Cleaned the filter, still won't drain. ???
if you can hear a humming noise when put on drain, this means the drain pump moter is ok but might have an object stuck around the blades! to check this you have to take off the drain moter which is behind the filter which in most models the base is open, so you have to take plug off from mains and lift the machine up and get to it from the bottom! it has 3 screws on it and its the moter which has the drain hose attached near it not the one without as most LGs have two moters one for drain one for circulation! take this moter out and check whats around it! it could be even string of some sort! make sure you put the screws in the exact place otherwise wrong hole would make it leak! take care! my advise would be to call local engineer which wont cost more than 40 to 50 pounds to fix! make sure you dont get ripped off by them saying the pump moter has gone as these pump moters very very rarely goes! im an engineer and i do this every day so i know! good luck!
Mar 01, 2013 | Washing Machines
My Electrolux washer will not drain water or fill water, it will spin. It is also making a humming noise
You need to check for the Humming noise as this can be the indicator to the problem, if this comes from the motor then the capacitor is faulty. Failure to switch on the INLET and the DRAIN pump can be related to fault in the control panel or this can also be due to faulty electric line voltage on the outlet.. So please check this out.
Also check the inlet and drain filters for clogging as a clogged drain pump can also hum.
Jan 12, 2013 | Washing Machines
Front Loader LG Inverter 7.5kg model WM-12330 FB On the last wash it wouldn't drain the water away. Tried 'drain' programme and rinse & spin programme - all works normally till it needs to drain and...
Have you already check your drain clean out? If it's not draining, you'll need to manually drain the washer, via the small hose that pulls out, once it is drained you can unscrew the large clean out filter, and see if anything is caught up in that area.
If all that is clear, it's most likely, you'll need a new drain motor. Also, did you notice if your getting a "OE" error code on the display?
Feb 28, 2011 | LG WM-2277HW Front Load Washer
How do i check the filter
The front filter is at the inlet point of the water hose and the drain filter at the outlet hose of the hose.
you can remove the hose and find the dirt collection prior to the drain pump/valve.
There is also the lint filter within the drum which must be cleaned often
Sep 29, 2010 | Whirlpool LHW0050PQ Front Load Washer
My hoover 540 washing machine started making funny noises a couple of loads ago (loud banging noise during spin cycle). Now it goes through whole cycle but when it gets to 'drain' part of the cycle,...
Sounds like a blockage in the outlet pipes or filter. It may be possible to drain it if you can get the outlet pipe (one from back of machine) outside, lay it flat on the ground as this will take it below the water level in the machine and may slowly drain. Once it drains out enough the machine should disengage the door lock to allow you to open it. Then check your filter and pipes for blockage. If no blockage is found then suspect faulty pump.
Jan 25, 2010 | Washing Machines
How do I winterize bosch front loader washing machine
Turn off the water supply to the washer, and disconnect the inlet hoses, remove the drain outlet hose and lay it down to drain any water in the hose.
Remove filter, and drain water off inside.
That should do it.
Hope this helps.
Dec 10, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Front loader LG Washer
make sure your outlet hose is not constricted or blocked in any way.
May 20, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
118 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
