Maytag centennial washer keeps running and will not fill
    Novelist:
  • 150 Answers
If the machine is "running/agitating dry", try changing your water level settings a few times going through all of the settings. If your problem goes away you will need the water level control replaced. Pleazer Appliance...
Posted on Apr 17, 2014
beltronic205
  • 1461 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
richroth
  • 9472 Answers
SOURCE: I have a Commercial Series
Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
Posted on Dec 26, 2010
richroth
  • 9472 Answers
SOURCE: Washer immediately goes into wash cycle when
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Posted on Jan 26, 2011
jsrock516
  • 5911 Answers
SOURCE: how do I get top of my washer..Maytag Centennial
This model Maytag is actually manufactured by Whirlpool. To access the lid switch on this particular model, all you should have to do is remove the operator console. The console has a retaining clip on each side holding it to the cabinet top. To release these clips, simply take a putty knife and slide it under the left and right front corners of the control panel push straight in towards the back of the washer. The clips will depress, allowing the operator console to be lifted up. The lid switch is mounted next to the left lid hinge. Refer to the "Top and Cabinet" parts illustration, Item 6 at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MVWC400VW1/3048/0153200?pathTaken=&prst=0&shdMod=MVWC400VW1
Some other websites you may refer to for parts include:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
NOTE: If you model number does not cross reference to these sites, use the part numbers fromthe Sears websites as your search criteria. Often, the model numbers may not be included on some websites (newly added models), but the part numbers will.
HINT: In some cases, what may appear to be a bad lid switch, may only be an actuator adjustment. The acutator on these models is the rod attached to the left lid hinge. You can bend the rod slightly to adjust the contact with the lid switch, or it may be tightened as necessary. If the switch toggles (clicks) by hand with the actuator rod removed, the switch typically is not bad.
If you need to remove the entire cabinet to access under the lid, the following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If you need further assistance, please post back and let me know. I hope you find this information helpful.
Posted on Apr 21, 2011
jamesstoner
SOURCE: want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Posted on Aug 06, 2012
Repair manual Where I can download the repair manual for the maytag centennial washer
This is a manual. Since there are so many versions, you might need to search for the appropriate one. I searched for "Maytag centennial top load washer repair manual". There was a Maytag site, but download was very slow. http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf#zoom=100#scrollbar=1#toolbar=1 http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf
Jul 30, 2014 | Maytag Centennial Top Load Washer
Maytag Centennial Top Load Washer drains as it fills.
The water is probably siphoning out of the tub. Your drain pipe is either too low or the drain hose is down too far into the pipe. Take the drain hose out of the pipe and lift it high. I'll bet your problem goes away
Feb 06, 2014 | Maytag Centennial Top Load Washer
Maytag Centennial is filling with hot water on cold setting
Probably the fill lines were reversed. The installation guidance tends to be poor.
Jun 15, 2017 | Washing Machines
My mayage centennial washer is agitating before the water begins to come in , how do I fix it?/
We had the same problem with our Maytag Centenial Washer. I simply removed the Auto Fill Sensor, cleaned the contacts with Deoxit contact cleaner and problem solved. All was done in less than 20 minutes.
Oct 14, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
