Question about Electrolux Refrigerators
No power to thr water pump
Front door board not working and no power to the water pump
  • Official Brand Answer
  • 4,342 Answers
Good Morning Lar,
I see that you are having trouble with your Electrolux refrigerator's front door panel not working and there is no power to the water pump. I suggest resetting your appliance by either unplugging it or shutting the power off at the circuit breaker for 2-3 minutes. When power is restored, if you are still having the same issues, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
Posted on Apr 25, 2014
Washer won't work and door is locked shut with clothes inside. Can I get the door open manually?
turn off . turn off power point. Wait 3 minutes then turn on power point. Try blowing on drain pipe then turn dial to spin cycle .
See if water pump is engaged during spin cycle.
Don't know if you can manually open the door
Had a similar problem and found the water pump was not pumping the water out and spin cycle was failing to complete.
Check filter of front loader as well .
Mar 19, 2016 | Washing Machines
Tip
Frigidaire Affinity Common Error Codes. (E4A, E9E, E56, E46 and more)
Hi.
This error codes apply to Frigidaire Affinity washers and dryers:
E11 - Fill time too long.
E13 - Water leak in tub, or air leak in air bell.
E14 - Reed switch.
E21 - Water not pumping out fast enough.
E23 - Drain pump relay on control board failed.
E24 - Drain pump relay on control board failed.
E31 - Pressure sensor not communicating with control board.
E35 - Pressure sensor indicates water overfill.
E41 - Control board indicates door switch is open.
E42 - Door remains locked after cycle is completed.
E43 - Control board problem
E44 - Control board problem.
E45 - Control board problem.
E46 - Control board problem.
E47 - Control board is sensing the door PTC circuit is open during spin.
E48 - Control board is sensing the door PTC circuit is closed.
E4A - Program Timeout Fault.
E52 - Bad signal from tacho generator.
E55 - Motor overheating.
E56 - High motor current.
E57 - High current on inverter.
E58 - High current on motor phase.
E59 - No tacho signal for 3 seconds.
E5A - High temperature on heat sink.
E5B - High temperature on heat sink.
E5C - High temperature on heat sink.
E5D - Communication problem.
E5E - Communication problem.
E5F - Communication problem.
E67 - Input voltage on microprocessor incorrect.
E75 - Water temperature sensor circuit (digital readout models only).
E76 - NTC temperature for the cold water valve over the limits
E95 - Communication error.
E9E -Voltage error.
EB1 - Incoming power frequency out of limits.
EB2 - incoming line voltage above 130 VAC.
EB3 - Incoming line voltage below 90 VAC.
EF1 - Clogged drain pump.
EF2 - Too much soap.
on Apr 09, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Loc error code Frigidaire frontloader
From the frigidaire site.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
Water in tub after cycle has finished
On our Kenmore front loader the guy came out and pulled the front lower cover off and opened the large round plug cap and there was the kids paint ball ammo stuck in the pre-pump end. Then he re-set the computer board with his tester. When this happened the second time, I repeated what he did, except I unplugged the unit. It cleared the memory and works fine...
Jun 05, 2013 | Crosley CW6000 Front Load Washer
Door is locked, no power to on off switch
if there is still water in the tub.then you can use a wet dry shop vac and attach it to then end of the drain hose and remove all the water,once the water is removed the door should unlock after you turn it back on.then you can check the drain pump for obstructions.
have you checked the power coming off the board to the switch
Mar 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Feb 07, 2010 | GE WBVH6240F Front Load Washer
Whirlpool 6.5kg front loader 2004 model. On any cycle machine won't pump water into tub and brings up an error message of F09.Electrical control board has black scorch marks on it.Would it just be cct...
You can check 1. power supply first then you can check 2.the door lock is working fine then you can check 3.the motor 4. the drain out valve 5. inlet valve is working fine with direct power supply
If every thing is fine means check the main board of the unit then you can replace that cct board
Jan 19, 2010 | Whirlpool Washing Machines
No water coming out
check power at the water pump. It is two of them one for icemaker, one for water dispenser. Pump located on the back bottom left....you need a 1/4 nut driver to take bottom panel off. Check power when someone else push water dispenser botton on the front of thr fride...if it is power you have to repalece whoe assembly, if it is not you have dig in deeper in to door dispenser...any question please ask, totalcarefl@yahoo.com
Aug 23, 2009 | GE GSS20IEP Side by Side Refrigerator
WHIRPOOL FRONT LOADER WASHER NOT SPINNING
Not pumping out the water - if the washer cannot pump out the water, the washer will not be able to spin...check the pump for not pumping.
Door not locking - if the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the consol.
Broken wires at one of the out off balance switches or a bad switch itself.
A fairly common trouble maker has been a burnt diode on the main control board. See diode R11.
f this has happened to your main control board ( in the consol ) , the wax motor in the door lock assembly is drawing too much hydro and must be replacing at the same time as the control board. The wax motor can check, appear and test ok but will fail when working throughout the cycle.
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E14 Reed switch.
EF2 To much soap.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Refrigerators Logo
50 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
