Inside fan won't turn - Heating & Cooling
    Sergeant:
  • 340 Answers
Is it stuck in place?replace the motor is the power on ? bad relay? bad thermostat? you need a contractor. Tom
Posted on Jun 18, 2009
Kf 55e200a
if its a dlp check the light engine there is a color wheel inside it may be worn out hence stuck and needs replacement do check that the fans are all working if one is not replce it to cos these r the only moving parts
Jul 15, 2013 | Televison & Video
The tv usually turns on but now it won't. When it does turn on it makes a noise like a motor boat sound. The noise stays on until you shut the tv off. I'm not sure what it is I think it's the fan but
I would say that if there is a fan inside of it and it sounds like a fan bearing going bad then that is what it is. The reason for it not to be turning on anymore could be because whatever that fan is cooling has failed. Not sure.
Jan 30, 2013 | Televison & Video
My U-Line mode l15BWC fan and compressor won't work
More than likely it is the temp control (thermostat) it is what controls the on and off
Oct 12, 2012 | U-Line Wine Captain (2015WC) Wine Cooler
Cooling fans won,t come on
1 fan is for cooling the motor and the other fan comes on when the ac is turned on or its very warm outside it 2 stage
Nov 08, 2017 | Cars & Trucks
Dell 370 fan runs loud and won't start
If the fan is failing the most times the computer will not start because it will overheat. There are two fans inside the system, one inside the Power Supply and one that sits on the motherboard.
Remove the Power Cord, Open the case, Remove the cover and with a can of compressed air blow out the dust inside the computer. Clean the dust away from the Fans, Vents, CPU and Heat Sink are that sits under the Fan on the motherboard.
Apr 23, 2012 | Dell Precision 370 (370TREC) PC Desktop
My cooling fan does not turn on unless i unplug it from the temperature sensor i have replace that sensor 3 times and it still does not work
Does it come on when the AC is on?
Odd .
Fan won't come on till like 230 degrees.
Or run a small ground wire from the relay to a switch inside.
Jun 17, 2011 | 2001 Pontiac Grand Prix
There are two small fans on in the ceiling. A small round vent on the driver's side in the back, and one in the front by the driver. It is loud and squeaking and won't turn off. What are these...
{: ) They are called the inside air temperature sensors. The HVAC module on your vehicle monitors the feedback from these sensors and helps regulate the climate comfort inside the vehicle according to your preferred settings. Yes it has this tiny fan inside, and if the noise is loud and annoying to you, the only fix is to replace it.
May 30, 2011 | 2003 GMC Yukon XL
I have the Hampton Bay Ceiling Fan and Remote. Model UC7083T. My son was playing with the battery cover and i think he moved the switches. The problem is i don't know what their original position was....
You have to go inside the actual ceiling fan. If you look on the part right above the light, there should be 3 or 4 screws in the side, connecting the light setup to the body of the fan. Unscrew those screws and disconnect the wiring harness. Inside the now open fan wiring, you should see a little box, that is the remote receiver. Either on one of the sides of the box, or inside that box will be the code. It will look just like the code switches on the remote. Make sure they match up, clip the wiring harness for the light and the fan back together, screw those screws back in, and you should be good to go.
May 09, 2011 | Hampton Bay 24002 Ceiling Fan
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
