Question about Craftsman Professional 1/4 Hp Submersible Utility Pump
As I was cleaning my pump the oil leaked out.
Should I replace the oil? What kind of oil should I use? Where does the oil go? How much oil should I used?
When putting the three wire connectors (1 green 2 blue) back on the cord attached to the top of the pump does it matter which wire goes where?
How do you know which way to place the impeller cover over the impeller?
2 Suggested Answers
pondking
  • 21 Answers
SOURCE: oil leaked out
Most utility pumps use mineral oil, but more importantly how did it run out? If a seal was bad the oil should have been milky. It will overheat without proper oil level.
Posted on Mar 03, 2009
Oil leaked out of pump and it wont work
....what kind of pump do you have? house pumps dont require oil. IF it really is oil, add some more into a reservoir, although its probably shot by now. More than likely its electrical parts overheated and melted leaked out. Either way you need to replace it.
Jul 29, 2015 | Pool & Spa
1998 toyota camry problems
If above the pump, it is usually the cam cover gasket in a Camry.
Jun 24, 2014 | 1998 Toyota Camry
Husqvarna 235 is leaking bar oil really bad
Hi, What Kind of oil do You use? A thiker one could be a solution.
Usualy there a other screw (than those H and L of the carburator) to adjuste the amount of oil spend on your blade.
Feb 04, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
2001 jeep grand cherokee. no leaks losing coolant,
Most serious item I see is oil pressure. Put a mechanical gauge on the engine and get an accurate reading. Also make sure that the passage to the sender isn't blocked. If you did the pump yourself, did you find any coolant in the oil? In 99% of all low oil pressure situations, the oil pump has not failed. Rather, either a cam bearing or crank/rod bearing is worn. You do not have to have one spun or completely worn out bearing. Even wear of all bearings that is somewhat excessive can bleed off enough pressure to cause problems (plastigage the engine bearings to determine wear).
As far as coolant loss. A cylinder head gasket can fail between cylinders, into a water passage, into an oil passage or any combination of those and externally as well. The cylinder heads on engines beginning in about '98 are prone to "micro-cracking" which can lead to all kinds of hard to diagnose coolant loss problems. It may help if you have a shop do a dye test and a hydrocarbon test on the cooling system and see what they find.
I have seen several kinds of block sealing systems available. Though I generally do not recommend them, as the longevity of the repair isn't predictable, you could try that as a option of last resort.
There is no quick easy solution to your problem but with a bit of "poking around" you may be able to cure it. Don't bother repairing one problem before finding out what the other one is first though as together, it might be smarter to replace the engine.
May 09, 2010 | 2001 Jeep Grand Cherokee
Engine oil leak on bottom side of motor when driving down the road an not at idal? its not the oil pan gasket just replaced it.
you'll need to clean every thing off to find where it originally started,the wind going under the truck blows it all back,did you use silicone on the corners in the front where the gasket material gaps.if it is not leaking at an idle,it must only leak at high RPMs when the oil is flying around in the pan,you might have good luck on a hoist and take it thru the gears and get it up to forty mph,
Jan 22, 2010 | 1994 GMC Sierra
Mi dodge neon oil light goes on and off. i checked the oil and is on the right level. could it be the oil pump? or the oil filter if is there any?
IT CAN BE ANY OF THE ABOVE AND ALSO A DEFECTUVE OIL PRESSURE SENDER ON THE ENGINE, HAVE THE OIL PRESS TESTED WITH A MECHANICAL TEST GAUGE BY A SHOP, IF IT IS OK REPLACE THE SENDER FOR THE OIL PRESS LIGHT.
Jun 29, 2009 | 2005 Dodge Neon
Oil leaked out
Feb 21, 2009 | Craftsman Professional 1/4 Hp Submersible...
Oil leak from oil pump
steam clean engine first ,run engine and then look for it .before you start spending money on something that might just need a tighten
Nov 21, 2008 | 1997 Toyota Land Cruiser
Oil leak
This is a maddening problem if you don't know what's going on. If it's like my 92 isuzu pickup with 2.3 litre engine, it's a vent line coming out of the fuel pump which will spit oil out. I had a very hard time figuring out why but finally read that there is a galley in the block where oil runs back to the oil pan. If it gets clogged, oil will come out the vent line of the fuel pump. I even took my head off and tried blowing compressed air and sticking various wires through the block holes near where the fuel pump mounts. Nothing did any good and I was sick of the leaking oil and having to add oil so I bought several feet of oil resistant hose at autozone and routed it from the vent line, back over the engine, and into the dipstick tube. This worked like a champ. No more leaking oil. No more adding oil. Make sure you trim the outside of the hose where it goes into the dipstick with a razor knife or similar, so it will fit tightly. Make real sure you use oil resistant hose or it will break down and get into your oil. Not good. Then use a tie wrap to secure the hose to something else like the brake vacuum hose to keep it in place. I keep my dipstick behind the seat and make sure it's cleaned before and after checking my oil. This truck doesn't use any oil to speak of now and I wish I'd thought of this sooner. Short of removing the engine and having the block flushed and cleaned I don't know what else would have fixed this problem.
Someone else said to replace the fuel pump to fix this problem. I tried that. It did not work. It still spat oil out the vent tube to the tune of about one quart every 150 miles.
I also replaced all the engine seals and gaskets. Front and rear main seals too which were also leaking. So now my oil leaks are a thing of the past. Good luck!
Aug 11, 2008 | 1993 Isuzu Pickup
Craftsman Professional 1/4 Hp Submersible Utility Pump Logo
62 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
