Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Nautilus bathroom fan blades don't turn
We have a bathroom fan installed in a wall to directly duct to the outside. It's an older Nautilus. When I turn the knob to turn it on, it hums, but the blades don't move. I can't even figure out how to get the fan cover off. Please help!
  • 288 Answers
The motor is sized up. call someone to replace it and they should know how to remove the cover.
Posted on Nov 04, 2007
Can I connect two bathroom fan ducts to a single roof vent?
No, both cannot be connected to same vent.
Or vent exhause from 1 fan will vent into other bathroom.
All house vents require separate duct.
Nov 26, 2014 | Broan-NuTone Fan,Bathroom Exhaust Broan...
How do I remove the cover to replace the light bulbs on a Round Nautilus brand bathroom exhaust fan from the 1980's.
Most exhaust fan covers use a spring steel wire in a V shaped configuration. The bottom of the V is attached to the cover. There is a slot in the fan housing and by pinching the tops of the V togetherand insert them in the slots the spring pressure pulls the cover up tight to the ceiling.Carefully pulling the cover down enough to reach over the cover and pinch thewires together should allow the cover to be removed. Hope this helps.
. Bob
Aug 09, 2014 | Broan nutone Broan/nautilus Bathroom...
My quiet bathroom fan makes a roaring noise
The roaring noise is probably the fan blades (looks like a hamster wheel) are worn out as it rotates on the spindle/shaft.
It may be a problem with the 4" exhaust ducting, that connects to the exit part of the fan, has come loose. Theres a damper (kinda like a flapper) at the fan/ducting joint may have broken off and may be sitting sideways in the ducting flapping around inside the duct.
At any rate I highly doubt its wiring. Sounds like its time to pull the fan cover off (turn the power off first via the wall switch or the service panel breaker would be even better) and look at the fan blades. Clean off any dust bunnies, lint, etc. and turn the fan back on. Did the noise stop?
If nothing looks out of place and it still makes noise you'll have to get in the attic and remove the ducting from the fan and see if theres a problem at the connection there. Maybe a squirrel put its bedding in the ducting? It happens.
Could be lots of reasons for the noise but wiring it wrong wouldn't cause roaring. The fan wouldn't work, or worst burn up, if wiring was the issue. The problem is the more than likely the fan blade assy is worn out or something is restricting the air flow in the ducting going to the outside of the house.
Nov 19, 2012 | Panasonic WhisperCeiling Bathroom Fan...
How do I make the fan blow from inside to outside? It is ducted to go outside but is blowing inside. I just bought this house and I need to know if there is a setting or fan direction switch?
this is easy. take it off the wall and on the top in the back there is a panel take it off and switch the direction of the diverter. so it si facing either sraigft up or facing out to the back , so it lines up with your duct work.
Sep 11, 2011 | Whirlpool MH1150XMQ Microwave Oven
Replacement Motor for Bathroom Exhaust Fan Need motor and blower assembly or just the motor for a Sears Roebuck Model 864.892 Motor is Universal Electric Co Model 118JF5 S/N 1T26714
Not sure what you are asking, but you can get a replacement directly from Sears. It is okay to replace just the motor, but be sure the fan blades are completely cleaned. When you are all done, verify good air flow outside of the building.
Sep 19, 2010 | Home
Panasonic Whisper Warm Installation
The vent fan must be exhausted into the outside air via a 4 inch flex duct, this may be difficult if installed in the wall!
Feb 20, 2009 | Panasonic WhisperWarm FV-11VHL1 Compact...
Bathroom extractor fan won't switch off
The fan most likely is turned on by the bathroom light switch. You likely have a defective fan motor.
May 01, 2017 | Hampton Bay 24002 Ceiling Fan
Fan just circulates air instead of exhausting the air outside
The exhaust motor was not installed properly - it has to be turned 90 degrees so that the blower openings face up instead of the front. Whoever installed it didn't read the directions:)
Unfortunately, the unit will have to be taken down from the wall to correct the motor.
Dec 21, 2008 | Maytag MMV5207AAS Microwave Oven
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
197 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
