Question about LG WM-2277HW Front Load Washer
Lg front loader washing machine has no power
In midcycle I heard a loud pop and the machine stopped working and now as no power there is power in the outlet
    Novelist:
  • 150 Answers
You will need to unplug the washer, remove the 4 screws from the white plastic pieces on the rear of the machine main top, remove the top by sliding to the rear, locate your main computer board in the top left, plug the washer into the wall, check for a small red LED light glowing on the board. You may have to unplug the washer again and remove the cover in front of the computer board to be able to see the light. If there is no red light your main control board is out, but this could have been caused by another failure such as a faulty stator, or rotor on the motor. Sometimes the connecting wiring from the front control panel to the main rear board will become loose and suffer damage against the moving tub. Best to have a qualified repair company check things out. Pleazer Appliance...
Posted on Apr 17, 2014
  • 1462 Answers
SOURCE: LG WFT1022TP top loader washing machine
the system which controls water level is an air chamber with a small diameter pipe which goes to a pressure stat. when the correct level is reached, the pressure in the air chamber switches the pressure stat and cuts the water off. the things to look for are: gunge in the air chamber split in the pipe. faulty pressure stat to test, get a similiar length of small diameter pipe and connect it to the pressure stat instead. with the machine filling, blow gently into the pipe and see if the water intake cuts off
Posted on Apr 02, 2007
SOURCE: LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Apr 11, 2009
taran_2005
  • 10515 Answers
SOURCE: Tromm LG front loader error code
Already answered by an expert :-
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Thanks.
Posted on Jun 17, 2009
jan mczeal
  • 632 Answers
SOURCE: lg tromm front loader washing machine display panel reading l-E.
error code 'IE' means water does not enter the detergent drawer..if your water is hard or contains traces of lime deposits, the water inlet filter may become clogged..regular cleaning is suggested..clean the filter using hard bristle brush..
note: hard water is the one not undergone any treatment..in other words it is directly from the ground through your water pump and to the washer.
Posted on Jul 19, 2009
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
How do you reset timing on Pfaff Creative 7570 Machine? Was sewing and heard loud pop, now will not work. Any ideas?
Hi Lisa,
"A loud pop" whilst sewing sounds as though a capacitor has blown probably in the power supply unit. I'd recommend that you take your machine to a Pfaff service shop to have it serviced.
To reset the timing on a sewing machine is a specialist job. To give you an idea of what it entails on a mechanical machine (your machine is electromechanical) have a look at this video
Good luck :)
Jun 21, 2015 | PfaFF Creative 7570
Stopped working , heard a loud pop, now there is no heat
Depending on the age of the machine, either it is the power board,which is less expensive to replace or the magnatron, Usually it will be the power supply, but you will have to take it apart which is very easy
Jul 31, 2010 | Sharp R-1405 / R-140 Microwave Oven
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Lg micorwave, lam1180st refridgerator and microwave were plugged into the same outlet. i heard a loud pop. circuit breaker popped. i reset and the frige works fine. Microwave does not have power. the...
It is possible that the interconnection link(s) between the two sockets in the duplex outlet have blown apart. Turn off power at the electrical panel for this circuit, remove the outlet from it's box, and check the interlink on both sides. If obviously burned, replace the socket. A better option is to run another duplex cable from the breaker box to the outlet from a new breaker, cut the interconnections on the new socket, and wire the new cable to the isolated part of the socket. This supplies full power to each half and allows both units to run at the same time.
Oct 19, 2009 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
Loud pop with smoke
Don't know why just plugging it into a new outlet would cause that unless you have a problem with that outlet. Sounds like it may have burned out the low voltage circuitry. I would advise having the outlet checked and certified safe before plugging anything else into it. Also, it sounds like the oven is toast, (Sorry!)
You can get parts on-line from AppliancePartsPros.com/Parts
May 23, 2008 | Emerson MW8107WA Microwave Oven
Loud pop does not work
2 things. Brain (main board) could be dead.
Gun shot sound could also be the gears kicking.
Not a good sound and neither is cheap to get fixed. If its both... dump the machine, it'll be cheaper to buy a new one.
Brain plus both gears would hit you 400+ usually.
Sep 13, 2007 | Saeco Vienna De Luxe Espresso Machine
LG WM-2277HW Front Load Washer Logo
96 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
