Question about Sony DAV-S400 System
Hcd gnv111d please wait error
System continuously shows Please wait and no sound on Tuner and Tape. CD does not eject. Lens changed but still the same problem
SOURCE: SONY DAV-FX900KW - I am
there is a small circle just beneath the CD tray. If you click it using a toothpick or any tiny device, it will help eject the disk. I have tried that and it works... There might be a problem on the roller inside the disk tray, wherein it requires a technician to repair such device...
Posted on Dec 19, 2010
  • 4234 Answers
SOURCE: Sony DSR-45 will not eject tape nor play,ff,rewind shows error
The generic error codes C32:xx indicate that a motor is not functioning. If you have not worked on these machines before, extreme caution is advised. These have extremely sensitive alignments that can easily be disturbed.
Please update this with your familiarity with these machines and I'll try to provide additional directions.
Thanks,
Dan
Posted on Feb 21, 2009
  • 221 Answers
SOURCE: tape stuck in sony uvw-1800
02-874 error code signifies a defective takeup reel. The reel is not winding the tape in, so the deck won't go through the eject procedure. Check the connection to the takeup reel motor; if that's OK, the motor itself may be bad. Rarely, the takeup reel motor assembly will need to be replaced; usually it's a connection problem.
Posted on Jul 09, 2009
SOURCE: "CD RESET" Error while playing CD
i am also facing the same problem with my SONY car stereo, when i inquired same to technician he said there is one switch inside player which got damaged, and requires replacement, he said that will cost me Rs.800 - Rs.1000
VINOD
Mumbai
Posted on Dec 20, 2009
Grubhead
  • 5126 Answers
SOURCE: instruction manual for Sony HCD-SD1 CD/Radio/Tape
Try the Sony website they have them free as a PDF.
Posted on Jun 12, 2010
I have sony HCD-FL5D and I can't get my disk out of it,when turn on my device it displays "PLEASE WAIT" I have waited but nothing special happend,what should I do?
i have a sony HCD-FL5D .it is not playing disc and not eject disc and when playing tape A/B it is on standby. i am worried about this please helpe me.
Apr 01, 2011 | Sony DHC-FL7D System
Sony mhc gnv111d dest error problem. how to reset?
on the system but please wait display only
Feb 05, 2011 | Audio Players & Recorders
MODEL GX250. CD PLAYER DOES NOT WORK. SYSTEM WAS IN STAND-BY MODE FOR SOME YEARS. TUNER AND TAPE PLAYERS WORK FINE. QUICK SOLUTION PLEASE.
This should be because you have not used the player for many years. Does the system eject the CD tray? Use the CD head cleaner CD that removes dust on the laser head if any. Try using the audio CD which are recorded in .cda format and not ion MP3 format.
Aug 27, 2010 | Sony MHC-GX250 CD Shelf System
BMW CD Changer MP3 player is connected to power and i-bus in e39 (1999 BMW 528i). When I press the button on the display monitor to toggle between Tape and CD, most of the time the CD does not show up (it...
in the unit there are two things that you will have to check
1) one is the lens which reads the cd in the unit.
2) second is the gear that moves up and down to the tape/cd.
if the lens is not getting adjusted after you turn it on/off then this problem happens also if the gear is not moving properly then also same problem occurs.if the gears are getting blocked then also this happens.as you mentioned it works that means the unit is not faulty but there is minor problem in lens or gear assembly just get it resetted by checking it.also local electronic repair shop can realign the unit.the unit need proper servicing to get it work properly.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 31, 2009 | Car Audio & Video
Panasonic Stereo system SC-PM28 will not eject any of 5 CDs in stack. Tape deck OK, as is tuner. Any ideas please.stellamurg
These units are known for getting out of time. There is an engineering modification that can be done to prevent this from happening again. Your best bet is to bring it to a Panasonic authorized service center. They will rebuild the CD loading mechanism and make the appropriate changes. I have made this modification numerous times and have not seen a return of the problem once completed.
Dan
Mar 06, 2009 | Emerson MS9700 CD Shelf System
Nakamichi DR2
Check belts. If mechanism is not in proper position, sensors will send ERROR signal to micro processor
Feb 03, 2008 | Audio Players & Recorders
System Error SOO41
Minolta Dimage G500 My lens is jammed in, and cannot eject itself or focus. It keeps on stating SYSTEM ERROR SOO41. Can you please let me know what i can do.
Jul 04, 2007 | Konica Revio KD-310Z Digital Camera
Sony DAV-S400 System Logo
66 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
