Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Waiter will not fill
Water only partiall fills then starts several sequences in rapid succession without completing any one cycle
  • 1,147 Answers
Remove the operations panel securement,maybe screws in lower front of panel and/or clips under the sides just pop up with a putty knife between the sides of panel and top of washer and tilt panel forward to access the back of panel.Connected to the water level switch find a hose connected to it.With ALL water out of tub,blow ALL the water out of said hose/tube.This will reset the water level to proper/what you set it to/when you wash.Explaination.As the tub fills with water,water will also go into this tube I spoke of.As the level in the tube rises,it puts pressure on the void above the water in the tube.This pressure increases as the water level rises and the diaphram in the level switch will shut water off at what YOU set it to.Now you know something you didn't and will remember.IF those other processes you spoke of are still doing an irregular thing,your timer is bad.But just blowing the water out of the tube,and reconnecting it,should work just fine.Have a good wash day.Regards,Rigger.
Posted on Apr 14, 2014
catriver
  • 878 Answers
SOURCE: Starts to fill and then stops, and the cycle continues on.
Jmars, under the consol there is two pressure switches. One controls the fill and the other is back-up incase the other fails. It sounds like your water pressure switch is tripping too soon. Try putting the washer into a self test mode by pressing in this order soak--soil level---soak--soil level. The machine should enter a test mode. Let it run it's test and see if you come up with any error codes. The pressure switch is the one on the left under the consol. It will be marked OPR, the part number is 8054766. The consol will lift up by using a putty knife under each end, pushin on the clips and lifting up. The back panel of the consol is removable. Catriver..post back
Posted on Apr 15, 2007
  • 1028 Answers
SOURCE: Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Posted on Oct 25, 2008
Amigaman
  • 248 Answers
SOURCE: Water fills Cycle won't start
Often the lid switch needs replacement. I can become cracked from the lid being dropped.
Posted on Nov 08, 2007
SOURCE: The washer fills with water but will not complete
We had the same problem. Luckily, we bought a 3 yr extended warranty. The appliance tech came in, pulled out a screw driver and tightened the lid. He said the left side frequently comes loose and that is where the sensor is that tells the machine the lid is closed. Tighten up the lid and see if that solves it. This washing machine BLOWS. We have had the warranty people out 4 times since we bought it. It's only two years old. First there was no hot water, the tech opened the machine and the connecter to tell the machine to use hot water was never connected at the factory. Water leaking from the bottom, don't remember what that was. Oil leaking from the bottom, replaced trnsmission seal. Fills with water and stops, loose lid. What a lemon.
Posted on Apr 08, 2009
SOURCE: Washer starts agitation during water fill up and
I also have a Whirlpool top load Model # WtW57ESVW auto sensing load washer. I have it it almost a year and it has started to do exactly the same as described above. The repairman said today that it needed a "auto load sensing switch" which he has ordered for me.
Note - you can use your washer until the problem is fixed, but you have to make sure you manually stop the spin cycle prior to it just finishing, for that is the time period that the water starts to fill again.
I also noted that my local Lowes store does NOT sell this model anymore - probably too many customer complaints about this exact same problem. As soon as I showed the problem to the repairman this AM, he immediately diagnosed the issue - said that it was a recurring issue with this particular model.
Posted on Nov 15, 2010
Hi, my Electrolux EWX12550w washing machine and dryer, working fine on was but when I'm drying it it starts at 13 minutes then keeps working but sticks on 10min also I get an err sign it's E10
Family error code E10 is visible to customers and (could be E11,E12 and E13 only visible in service mode) means problem
with filling water.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme).
Press and hold down START/PAUSE and the nearest option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the last alarm.
The alarm sequence continues as long as the two buttons are held down.
E11 - Problems with water fill for washing
E12 - Problems with water fill for drying
E13 - Water leakage
I believe there are difficulties in water fill for drying.
Water is necessary in the drying phase in order to cool down the steam entering in the drying condenser.
Possible causes: Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty
Dado
Sep 07, 2015 | Electrolux Washing Machines
On the Maytag Neptune MAH 5500, the timer is running through its cycle without stopping to complete that cycle. In other words if rinse is selected the wsher fills partially and you can watch the timer...
Hi
Thanks for using FixYa. It seems to be an issue with the Timer motor going bad and should be replaced to resolve this issue. Everything seems to be working fine as the washer is filling with water spinning etc so it is the Timer that should be replaced.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Not filling with enough water only filling partway
The fill cycle is a set time and not measured. Either your water pressure is low at the dishwasher or the screen on the fill valve is partially blocked keeping the correct amount of water from entering during the fill cycle.
Eric
Jan 11, 2010 | Kenmore 18 in. 14432 / 14439 Built-in...
My washer fills VERY slowly and will not stop filling after cycle
It sounds like the water inlet valve is stuck partially open and needs to be replaced. It's located on the back of the machine where the hoses attach.
Jun 15, 2009 | Frigidaire FEX831CS Top Load Stacked...
Must repeatedly slam top loading door shut for machine to start
on the inside of the lid there is a lid switch hole that a plastic tab goes down through the switch could be bad or the screws holding the switch in could be lose or broken
Mar 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Frigidaire Washer - FTF2140FS1 - fills with water, but won't complete cycle
The water level sensor or float switch may be faulty. If the unit does not sense that the water is at the right level nothing will happen.When the water filling rate appears very slow, the inlet water filters may be clogged. Although not that common the inlet solenoid valve can jam and only partially lift.The cycle timer or program circuit board may be faulty
Jun 02, 2008 | Frigidaire Washing Machines
Pump turns on while filling
if it start draining while is filling the water. you need to ck the drain house. it is too long in the drain you need to pull it out little.
Feb 06, 2008 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
237 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
