Question about aFe 2001 Volkswagen Beetle - TDi, 1.9L 4-cyl. engine - Pro-Guard 7 Air Filters
Where is emergency fuel shut off
Drive down road hit a hole an car quit
No start or quits going down road then re starts after 10 mins no spark
a bad crank sensor will cause car to shut down, and restart in about 10 minutes.while driving down the road.
Mar 13, 2014 | 2004 Chevrolet Impala
Where is the emergency fuel shut-off on a 2001 hyundai sonata?
Look either inside passenger side door behind panel in floor board or in the trunk find a module with a little red button and push it also google location if not found
Jul 23, 2012 | 2001 Hyundai Sonata
Quit on road and fuel cutoff light come on
find out where the emergency shut-off switch and check to see if it has tripped. if its not that, try to find the fuel pump relay and check it. you can jump the wires when you pull the relay. its usually the biggest pins on the relay. hope this helps.
Nov 30, 2010 | 1992 Ford Escort 4 Door
No power to fuel pump
Your Kia may be equipped with a shock sensor that shuts down power to the fuel pump to prevent fires in case of an accident. Having seen this on several different vehicles, they will also shut down hitting a pothole or driving at speed on rough roads. The reset for these has been always behind a panel or in the trunk of such vehicles.
Jun 18, 2010 | 2002 Kia Sportage
Hit a rock with the fuel tank and the car shut down, is there a fuel shut off switch on it?
I tried to post this once,so here goes the 2nd time,there is an emergency shut-off switch on the fuel-somtimes located in the rear and if you hit a big pot-hole it will shut down-that could be your problem-call the dealership-ask for the service dept and ask them if your car has the switch-if so where? Or it may be electrical-check to see if you have a loose cable or wire by your fuel tank
Nov 23, 2008 | Mitsubishi Mirage Cars & Trucks
I have a 1992 hyundai Scoupe (this car wasn't on the list) with a 1.5L I was driving down the road check engine flashed on engine quit running I waited 15 sec. car stared drove about 1 mile same thing...
You'll have to get rid of that check engine light as it indicates a malfunctioning part. Whether you like it or not you'll have to take it to a shop to do a diagnostic check on it. Check the fuel filter or a relay that's associated with the fuel system. It seems to cut out when it gets hot, check to see if there are any relays in the fuel system.
Nov 18, 2008 | Hyundai Accent Cars & Trucks
Van cuts off while driving down the road
DID YOU CHECK THE FUEL PRESSURE WITH A FUEL PRESSURE GUAGE, AND MAKE SURE IT IS WITHIN SPECS? IF SO THEN IT COULD BE YOUR IGNITION SWITCH...THE PROBLEM IS, TO DIAGNOSE IT IF IT IS THE IGNITION SWITCH, THE VAN MUST BE IN THE "NO START, OR NO RUN" STATE AT THE TIME....
PLEASE RATE THIS,
ROB...
Sep 18, 2008 | 1997 Plymouth Grand Voyager
2002 Mazda Fuel Shut off Switch
The fuel cut-off switch was activated by the impact. Had the same situation. I can provide you with mazda service manual in pdf if you wish.
Jul 06, 2008 | 2002 Mazda Protege
aFe 2001 Volkswagen Beetle - TDi, 1.9L 4-cyl. engine - Pro-Guard 7 Air Filters Logo
116 people viewed this question
Top aFe Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an aFe Measuring Tool and Sensor Expert? Answer questions, earn points and help others
