Question about Electrolux Refrigerators
The frezzer is working the front panel does not light and no power to water pump
The freezer is working the front control panel does not light and no power to the water pump
  • 1,414 Answers
Somehow the connection has come unplugged.Find the plug and hook it up.Surely you got a manual with the fridge.Check the manual.
Posted on Apr 14, 2014
SOURCE: ice/water dispenser control panel
@ Scootertramp
You tell us about this board or that board but never tell us where to located or get at these boards. Would you please clarify that?
My ice and water started dispensing sporadically, though the lights were working fine. After I removed the kick board at the bottom, cleaned out the little connector and put it back together, nothing on the door works. All else works fine.
Posted on Sep 08, 2008
  • 531 Answers
SOURCE: Whirlpool SIDE BY SIDE GS5SHAXNL00 WATER LEAK ON FLOOR
you may have a water line leaking you sure you dont have a clogged drain
Posted on Apr 06, 2009
SOURCE: power went out briefly. Refrigerator control
Press the Power Freeze and the Power Cool button at the same time. Hold for 10 seconds and the digital panel reset.
Posted on Aug 15, 2009
pilungu
  • 30 Answers
SOURCE: front panel on my GE side-by-side refrigerator doesn't work
Replace the touch pad.
Posted on Nov 07, 2009
SOURCE: ice maker and water dispenser front panel lost power
My door dispenser loses power and I can uplug fridge and plug back in and I have power, then after a few minutes the power goes off again.
Posted on Dec 27, 2009
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 10, 2015 | Refrigerators
Control panel off lights in fridge and freezer on but not working
Unfortunately the control panel is probably defective. But check for power to the panel. This controls the temp of the freezer, fridge and the solenoid control valves for the water and ice maker. What is the Year, Model and Make of the refrigerator?
Mar 22, 2015 | Refrigerators
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
Water leaking in Kenmore Coldspot fridge.
is it from the freezer?
if it is it might be that you need to clean the drain hole.
this locate behinde the panel on the frezzer section , if it is side by side unit it is on the bottom left in the middle...
its very easy to clean use a turkey pump that u use to stuff with...:) and use hot water in-out....good luck
Dec 31, 2009 | Kenmore Refrigerators
How do you turn off freezer,refrig. is a side by side with a lower freezer that pulls out. Recently moved and freezer door broke and need to use just the refrig.
I don't believe you can turn off the frezzer section because most if not all frezzer/fridge units use the frezzer section to cool the fridge side!!!! that's just how they are designed.
Sep 21, 2009 | Refrigerators
Refrig/freezer not cooling/freezing
your gonna have to let thr fridge defrost buy shutting it down because it soundsm like you have either a build up of ice it the vents in the back of the frezzer unit also check to see if you can hear the fan working in the frezzer if not that would be you main problem
Jul 26, 2009 | Freezers
My fridge is leaking water
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the frezzer
Apr 28, 2009 | Kenmore 64802 Top Freezer Refrigerator
Bosch Frost Free Frdge Freezer Icing Up
Switch off fridge. Put a pedistal fan in front blowing into the cabinet and leave until all ice has defrosted. Locate the drain hole in the back of the freezer compartment, try to defrost ice which blockes up about the first inch or two of this pipe. If water does not run through you need to force it through with a turkey baster. This should sort your problem. ratemeplease
Mar 12, 2009 | Freezers
My GE PSS26SGRSS is not working. The panel lights are blinking.
Problem is the circut board in the back, you can go to ge appliances.com go to service and support type in model# go to unit and main board parts to order.
Nov 14, 2008 | GE PSS26SGRSS Stainless Steel Side by Side...
Refrigerators Logo
66 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
