Question about Car Audio & Video
Electro voice sba760 schematic online
I need a schematic for a electro voice sba760 subwoofer i can download online
2 Suggested Answers
  • 45 Answers
SOURCE: How to reset the protection on a electro voice sba 760 active subwoofer ?
most of this protection are parmanent you cannot adjust any settings.
Posted on Apr 17, 2014
Tip
Schematic Diagrams for KLH ASW10-120
After acquiring a fried KLH ASW10-120, I write to the tech folks at KLH and they sent me the upper and lower board schematics. I asked if I could publish them online, and explicitly asked if I could share them on FixYa.com, and they gave me permission to do just that.
Here's the lower board, which has the power supply:
KLH ASW 10-120 subwoofer schematic - lower board
Here's the upper board:
KLH ASW 10-120 subwoofer schematic - upper board
on Sep 25, 2009 | KLH ASW10-120 Subwoofer
PSW 125 Diagram Schematic
download with model number suport e-manual pdf
Aug 28, 2014 | Polk Audio Psw 300-watt 12" Powered...
I have a pioneer VSX D-308 RECIEVER and a electro-voiceevt 2210can it be hooked up together
The Tapco equalizer was a very popular line of equipment which was eventually bought up by Electro-Voice. Could not find any online manuals, however found online images of back panel. It appears to have Tape Ins & Outs.
Unfortunately the equalizer you have is not compatible with the receiver unless you have special cables that have built in transformers. This unit has T&R connectors (tip & ring) meant for professional sound equipment.
On a typical home stereo receiver you would hook up your equalizer with RCA connectors as follows.
1) You take the output of the equalizer and plug it into the input of the receiver.
2) You take the output of the Receiver and plug it into the input of the equalizer.
Start with lower volume and your tape switch on the receiver to the on position. Play with the various controls on your equalizer to
Apr 17, 2014 | Electro-Voice Tapco Graphic Equalizer,...
Apr 16, 2014 | ElectroVoice SbA760 15" Powered Subwoofer
Subwoffer will not power up
PDR-8 Specifications
Design
Single driver, bass reflex system with critically tuned resistive port and built-in amplifier Amplifier High-current, discrete output, 90 watts RMS
Amplifier Features Soft clipping, thermal protection Frequency Response On-Axis 29Hz - 150Hz Low Frequency Driver 210mm (8 in) extended travel with 38mm (1-1/2 in) voice-coil, aluminum former Low Frequency Extension 29 Hz (DIN) Finishes Black Ash, Light Cherry, Dark Cherry Inputs From A/V receiver/processor or Paradigm X-Series Subwoofer Control Unit mono-sub out or preamp left/right output;From receiver/amplifier speaker terminals or main/satellite speaker terminals Weight 25 lbs. (11 kg) Dimensions HxWxD 13.25" × 9.75" × 15"
(34cm × 25cm × 38cm)
Specifications are subject to change without notice.
© 2016 Paradigm Electronics Inc. Conditions of Use Privacy Policy Unauthorized Dealers WARNINGSouth Africa
Dec 26, 2013 | Paradigm PDR 8 Subwoofer
Where to plug in powered speaker (subwoofer) on yamaha emx88s mixer? I tried monitor but it doesnt work.
To connect powered speakers and/or subwoofers follow the instructions on page 19. Connect the powered speakers from the Main L and Main R.outputs
"MAIN (STEREO) jack: The stereo (MAIN L,R) bus signal which has passed through the MAIN MASTER control and graphic equalizer."
for the subwoofers set the YAMAHA SPEAKER PROCESSING switch on/off for best sound as desribed on page 13.
To test this I would play the song Let's Go by Calvin Harris.
for best results use a matched pair of speakers and subwoofers
such as the Electro Voice Live ELX112/ELX115 to the elx118p subwoofer.
Dec 16, 2013 | Audio Players & Recorders
Hum coming out of sub..need to replace power capacitors. Does anyone know which one they are or have schematic to share?
The power capacitors should be marked. Many places online to buy them but steer clear of the "made in China" components. You might be able to get them locally, as well.
Nov 01, 2013 | Boston Acoustics PV800 Subwoofer
Dont have wire schematic to hook up american pro bass machine limited edition model 1406,need to know how?
You should go to www.the12volt.com they are very helpful and pretty much have a schematic for every single car audio situation and they give you all your options. If they have nothing go to crutchfield.com and go to the learning section then subwoofer and amp wiring. It all depends on the subs that u wanna hook up to it as well as the ohm impedence and the amount of voice coils and so forth they have all of that.
Jun 13, 2009 | American Pro VS1406 Car Audio Amplifier
Car Audio & Video Logo
104 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
