Question about Epson Artisan 800 All-In-One InkJet Printer
Communication error Try to fax and get communication error
  • Epson Master
  • 3,497 Answers
Do you have phone line plugged into printer and may need adsl filter if you use adsl .
Posted on Apr 15, 2014
3 Suggested Answers
vanherringto
  • 1738 Answers
SOURCE: My epson fax machine is hooked to magic jack and
Can I fax using Magic Jack? This is a popular question. They do not support faxes, but the answer is yes. You may need to do some tweaking. However, not much tweaking. First, turn off error correction on your fax machine or program. Then, set the fax machine or program to use the slowest speed available. The slowest speed will ensure a fax goes through. You may increase later to find the highest speed at which a fax can be received.
Posted on Feb 10, 2010
cns assoc
  • 677 Answers
SOURCE: epson fax hooked to magic jack communication error
I had same problem when I used the dual jack. I had to change it. I had the dual jack which would make it easier to use when I was going to send a fax.
Good Luck
Posted on Feb 12, 2010
Communication error 43 message every time and with every number.Panasonic fax kx-fhd332
COMMUNICATION ERROR (Code: 43, 44) means that "A line problem occurred". There might be a problem with the phone jack where your fax machine is connected to. Try to connect the telephone line cord to a different jack and try again.
Mar 21, 2011 | Panasonic KX-FHD331 Plain Paper Thermal...
Error code com 0001
Hi-
Go to fax settings and try turning off the ECM, if its off then switch it on, chances are its a communication error on the line. Keep me posted for further errors.
Have a nice day!!
Jun 11, 2008 | Office Equipment & Supplies
Why is there a communication error message when receiving faxes?
The communication error is due to there being excessive noise or static on the line, you can try lowering the fax speed and turning the error correction mode to off, to do this go to the printer and press the set up button,. fo to fax set up and press ok, look for all faxes and press ok and change those two settings, you should also have your phone line checked for quality.
Al
Jun 08, 2010 | HP Laserjet M2727nf Multifunction Printer
Cannot fax to one number
PROBLEM IS NOT YOUR FAX 99%CHANCE IT IS THE PHONE LINE CONNECTION WHEN YOU DIALTHE SIGNAL IS GOING TO VARIOUS LOCATIONS LOOKING FOE FREE SPACE TO SEND TO RECEIVING FAX.BEFOR RESENDING TRY CALLING FROM PHONELAND LINE.COMMUNICATION ERRORS ARE THE BIGGEST FAX PROBLEMS IF THEY CANT COMMUNICATE 95%ERROR FREE THEY WILL DISCONNECT STATIC ON LINE IS THE CAUSE
May 19, 2010 | HP 1040 Plain Paper Inkjet Fax
Error Code R.3.1
YOUR PROBLEM IS CAUSED BY STATIC ON THE PHONELINE NOT YOUR FAX. BOTH MACHINES TRY TO SLOW DOWN TO UNDERSTAND INTERNATIONALMESSAGE OF FAX COMMUNICATION THEY MUST UNDERSTAND 95% OF MESSAGE OR THEY WILL DISCONNECT YOU CAN TRY NEW PHONECORD 1.00 AT DOLLAR STORE ORCALL YOUR PHONE CO.
Apr 09, 2010 | Muratec F65 Plain Paper Thermal transfer...
Epson fax hooked to magic jack communication error
Good Luck
Feb 09, 2010 | Epson WorkForce 600 All-In-One InkJet...
What does COM-E mean when we try to send fax's and the transmissions has this written on it instead of OK.
It means "Communication Error".
The result might be twofold:
- the fax didn't reach it's destination because of communications error (any kind)
- the fax did reach it's destination, but part of it may be unreadable or distorted, or some pages of a multi-page fax did not go through.
In many cases, what the device perceives as an erroneous transmission, is perfectly readable by a human. Therefore it's good to call the recipient and ask if the fax is readable and if all the pages were received.
Nov 13, 2009 | Sharp FO 1460 Plain Paper Thermal transfer...
Not receiving fax - notes is error 410* prompts the following: "a communication error occurred during the fax transmission. If your sending try again....
Hi! I will be glad to assist you in this issue. here is the link to fix the issue.
Interpreting Error Codes in Fax Communication Error or Fax History Reports:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=421139#Error396
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02151&cc=us&lc=en&dlc=en&product=421139
Nov 08, 2009 | HP Photosmart 2610xi All-In-One InkJet...
Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
Communication error
the problem is most likely not the machine, once it has established communication it should be fine.
if there is a break in the line for whatever reason then, it will give you the error.
try to fax to a different fax, does it still do it? plug a phone in that outlet and call a freind, chat awhile, is there any static or anything unusual with the line?
Dec 13, 2007 | Brother IntelliFax-2820 Laser Fax
Epson Artisan 800 All-In-One InkJet Printer Logo
87 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
