Question about Marine Metal Cool Bubbles Insulated Bait Saver
Need a new liner.Is one available - Marine Metal Cool Bubbles Insulated Bait Saver
  • 69 Answers
Original liners are hard to find. Local baits store should carry a Styrofoam buckets a little trimming your back on the ice. Good luck
Posted on Nov 26, 2014
I live in Republic of Ireland and require a replacement liner for a 0.5l flask. Where can I find this. Are liners still available or only new vacuum flasks
Vacuum flask liners have faded from the general scene
However if you try the specialist cooking tensile shops ( shops that handle pots, pans knives and all lines for the kitchen) you may get a shop that can still source the liner for you
Aug 29, 2015 | Cars & Trucks
I need a replacement liner.
contact the manufacturer for one if it is available but normally it will be worth more than a new unit especially if freight is involved.
May 03, 2015 | Crock Pots & Slow Cookers
REPLACE POOL LINER
Good luck on your warranty. I'm sure it will be pro-rated. 10 years is a long time for a liner to last. It usually costs 2,000-3,000 for a new liner and installation.
Jul 11, 2014 | GLI Pool Products Pool & Spa
How do u change the liner in a lincoln mig welder
Hi:
That's an easy one. First unplug power cable and remove the gun from the machine.
a. Lay the gun and cable straight on a flat surface.
b. Remove and save the gas nozzle and nozzle insulator.
Make sure that the set screw in the gas diffuser
is backed out so as not to damage the liner.
Use the 5/64" (2.0 mm) Allen wrench provided with your new liner.
Remove and save the gas diffuser from the end of
the gun tube assembly. Remove and save the liner
nut from connector end.
c. Remove old liner and insert a new untrimmed liner
into the connector end of the cable. Be sure the new liner
it's appropriately for the wire size being used.
d. Before installing the gas diffuser, fully seat the liner
bushing in the connector end and install the liner nut
and finger tighten.
e. Be sure the cable is straight and then trim the liner (all new liners are over-sized and need to be cut to your gun lenght) 9/16" to 1" over sized to the length of your gun without the tip holder. Remove any burrs from the end of the liner.
f. Screw the gas diffuser (tip holder) onto the end of the gun tube
and tighten with the wrench provided.
g. Tighten the set screw in the side of the gas diffuser
against the cable liner using the Allen wrench provided.
h. Replace the nozzle insulator and gas nozzle.
That's it. If this was useful to you please vote.
Feb 23, 2011 | Welding Tools
The welding wire is broke off inside the feeding hose and I can"t get it out....I have a Lincoln 100
If the welding wire is inside the liner and got stuck, you must change the liner, it is an easy fix. Take the gun off the machine and take off nozzle, and tip holder, you will need an allen key for this. Pull out the liner form the bottom of the gun and replace it with a new one. You can buy new liner at any welding shop/store. I will recommend praxair, the carry the prostar line which is very inexpensive, a new liner will cost you around 15 bucks.
If this answer was useful please vote.
Feb 05, 2011 | Lincoln Welding Tools
Pressure Cooker Liner - Teflon Coating is Shedding
Cook' Essential liners have a lietime warranty, call 800-231-9786. They no longer available, so they will give u a refund of at least $150.00
Sep 29, 2009 | Kitchen Appliances - Others
Marine Metal Cool Bubbles Insulated Bait Saver Logo
541 people viewed this question
Top Marine Metal Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a Marine Metal Fishing Expert? Answer questions, earn points and help others
