Question about Freezers
I have a beko fridge freezer. I had an error code
I have a beko fridge freezer model AB910, I had an error code E4. I have just got the part. How do I install it. Do I go into the front of the freezer or the back. It is a small black tube with two wires comming out of it. Can you tell me how to replace this part? Many thanks,
John
  • Anonymous Mar 20, 2014
    Error code appearing e4
I got the answer myself and thought I would share it.
The E4 code means that the auto defrost is not working. Call beko and tell them the code and they will tell you what part it is. I think the part number is 421445. It is a little black tube with two wires comming out. The part costs about £10. To fit the part you have to go into the feezer side of the fridge and carefully remove the white plastic at the back which is held with clips and one screw. To find where the part goes look for a long white fatish wire. The black fuse or thermostate is hidden in that. You will see where the wires go when you remove the old one. It is easy to do. Once you replace the part the error light will still be on but will go out after the fridge is back to being cold. Don't forget to replace the inside of the freezer when done! Hope this helps. John
Posted on Jun 24, 2009
  • foufou_fe Nov 14, 2010
    i replace this little black tube with two wire E4 but not for long times (4 days) can u help me plz
I have a BEKO CDA539F and notice that there is one with an X attached to the end of the code that is amongst the recall models. I asssume that my fridge freezer is safe. Am I correct?
From what I understand, you are safe if your serial number does not match the ones in the list exactly. That said, the information I have is from knowledgeable sources but NOT from BEKO, who have failed to answer their 0800 incident line or reply to my mails for 4 days now (By coincidence, while I provide a lot of technical help on this forum, I also have a BEKO fridge that IS on the list).
I would go to their site and send in a mail via the facility they offer there. I imagine that at some stage you will get a confirmation that all is OK with your fridge, but I would want to cover the bases if I was in your position. For convenience, the original article I wrote with the BEKO website listed in it is reproduced here for you:
POTENTIAL BEKO REFRIGERATOR FIRE RISK AND RECALL NOTICE
I would normally give a pointer to articles I have already posted this response on, but as this is such a potentially serious matter, I have posted my entire response here for you.
According to several sources I have checked, including most importantly, BEKO's own website, the MODEL numbers (not serial numbers) affected by the recall are as follows:
CDA543FX
CA5411FFS
CDA752FS
CDA645FW
CA5411FFW
CDA752FW
CDA647FS
CA5411FFX
CDA752FX
CDA647FW
CA7014FFX
CS460FF
CDA648FS
CA7015FFS
CS460FFS
CDA648FW
CA7015FFW
CS460FFSD
CDA653FS
CA7015FFX
CS461FFW
CDA653FW
CDA539FS
CS461FFS
CDA653FX
CDA539FW
CSA4706FFX
CDA659FS
CDA539FX
CSB4606FFS
CDA751FS
CDA543FS
CSB4606FFSD
CDA751FX
CDA543FW
CSB4606FFW
The fridges affected were manufactured between January 2000 and October 2006. After shipping and sitting around in shops, you can probably extend that margin to machines SOLD between 2000 and 2008. The first 2 digits of the serial numbers indicate the year of manufacture, so if your serial number doesn't start 00, 01, 02, 03, 04, 05 or 06 you don't even need to check.
If you go to the BEKO website, there is a link to check your serial number:
https://refsafety.beko.co.uk/
The site also provides a mail address and a UK Freefone number that you can call (Though I've tried the number and it keeps cutting me off!! I presume they are swamped with calls)
Jul 09, 2011 | Freezers
FREEZER DEPARTMENT IN A BEKO CS460FF
the hose out of the back of my fridge freezer is loose is this right and there is a bad oddur
Dec 09, 2009 | Freezers
My beko fridge freezer keeps turning itself off and when i pulled the fridge freezer out there is what looks like a fat gas bottle at the bottom and that was very hot i think the model is cg964d
These appliance work with a thermostat that is when ever they reach a certain temperature they do cut off power automatically..If you find that ice is melting then you need to start worry.By the way the fat gas bottle is an air compressor which helps to circulate the gas around the system...It's like the heart of the fridge.
Jun 15, 2009 | Freezers
BEKO AB910 Frost Free Fridge/Freezer Ice build up
I have the same model + problem. You should not need to defrost this model manually if it's working correctly, but the ice build up you describe is probably due to a blocked pipe in the auto-defrost system at the back. You need to defrost properly to prevent recurrence.
Behind the upper freezer drawer there's an aluminium tray behind a plastic grille. Every few days this tray warms up to melt any accumulated ice behind this plastic grille (full height of the freezer). A pipe should take the meltwater down to a plastic tray below (pipe + plastic tray are visible if you take the lower panel off the back). Your problem is too much ice blocking that pipe: the heater can't cope and it doesn't melt, so the ice 'cascades' down the back behind the bottom drawer.
When you manually defrost, you must ensure that this pipe is clear, otherwise the auto-defrost won't work, and you may have to defrost manually again within days.
I have found that the best way to defrost the pipe is to remove the lower back panel, disconnect the corrugated flexible plastic pipe from the stub that comes from the bottom of the freezer, + pump steam into the stub (gently) using a hand-held steamer (with tube + nozzle). You don't have to empty the freezer or move your food as the door stays closed, and no steam gets into the freezer until the pipe is unblocked. Be sure to unplug the freezer before taking the back off! [There is a fan in this area that could start up without warning]
Check how much of the pipe is blocked by gentle probing with a pencil: the aluminium tray is about 105mm above the bottom of the stub. This measurement is important…
When the pipe is clear, there may still be too much ice in the aluminium tray above (not sure how much is 'too much') if you only created a narrow 'chimney' though the block of ice (likely to get blocked again). You need to widen that chimney by melting more of the ice in the aluminium tray. I use a simple steam nozzle made from an old-fashioned Bic pen with a couple of 1mm holes drilled just below the coloured bung at the end. This directs steam onto the walls of the 'chimney' rather than upwards.
There's no point steaming the walls of the plastic 'stub' pipe, so only use the home-made nozzle when your probe reaches 105mm (i.e. when you have melted all the ice in the plastic stub tube but before your 'chimney' has broken through the block of ice in the aluminium tray). If you judge this right, you'll melt almost all of the ice under a still-frozen top surface: no steam will get into the freezer and your food will stay frozen. With a probe it will be clear when you've broken through the top surface of the ice. When you have done so, it's time to look inside the freezer to see how well you have cleared the aluminium tray.
It's perfectly feasible to get all this done in 30 minutes.
Don't forget to replace the corrugated plastic pipe + valve at the bottom. It stops humid air from going into the freezer and icing up in exactly the area we've just been defrosting.
Take a lot of care with steam jets as they can burn you badly. You should check a first aid website so you know what to do BEFORE it happens.
Some of these tips may be helpful: (1) run the freezer at -18 degrees (the 'warmest' setting) so it's not working so hard. (2) Leave a big gap (>100mm) between the back of the freezer and the wall. (3) Clean the matrix of delicate tubes to the left of the fan whilst you have the back off [a small bottle brush is ideal; remove the fan for better access]. (4) Put something between the middle of the freezer and the wall to prevent the warm air that's being blown out behind the fridge from being sucked into the air intake behind the freezer (there is a baffle built in underneath, but nothing behind. (5) Mount the fan on spacers (with longer screws) so that it's closer to the heat exchanger… this means that a larger area of grille can act as an air intake. (6) Raise the unit off the floor a little to free up the air intake path beneath the freezer.
Apr 23, 2009 | Freezers
Beko fidge/freezer (model cg975ff) overheating
My general maintenance seems to binging the temp down slowly.thanks
Aug 29, 2008 | Freezers
Beko fridge freezer
Is it froze up? maybe it needs defrosted.
Jan 19, 2008 | Freezers
BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 | Freezers
Freezers Logo
1,544 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
