Question about Maytag Legacy Top Load Washer
I have water leaking on maytag legacy. 9 years old. getting worse over 3 months. removed front and rear panels, dried out and looked for leaks. only water was on agitator base. im thinking tub bearings and seal. any other ideas??
    Novelist:
  • 150 Answers
Look for splatter signs along all of the inter panels, including the ones removed, splatter marks will be just below the line of the tub. Pleazer Appliance...
Posted on Apr 17, 2014
erpaalai
  • 999 Answers
SOURCE: Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Posted on Aug 10, 2009
  • 574 Answers
SOURCE: Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Posted on Sep 07, 2009
Maytag317
  • 1136 Answers
SOURCE: Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
Posted on May 30, 2009
SOURCE: Outer tub bearings are gone
My bearings went out too and I found this site http://www.neptunebearing.com/ Ordered the bearings and the Tony Tool. My son and I replaced the bearings in about 2 hours!
Posted on Apr 03, 2009
  • 96 Answers
SOURCE: washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Posted on Mar 31, 2008
My Maytag MAV6000 washer leaks intermittently. In the past 3 weeks it has been used many times but has leaked 3 times. I removed the front panel to look at the pump and hoses and put the washer through a...
Realistically, a 10-year old Maytag is nearing the end of its usual life. The pump may be leaking at random times during a wash cycle. If you put 50% of the cost of a new one into repairs, it is time to thing seriously about replacement of the machine.
Apr 26, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Water leak from under refrigerator
Only two possible sources for a leak one is an ice maker, the other is defrost drain water. Either way it is only 9 months old and still under full warranty!! Call sears and have them come and look at it! I have seen a few of these units with cracked drain pans so be persistent if the tech cannot find a leak, have him pour some water into the pan to see if there is a crack.
good luck and save yourself some stress.. You have a warranty to cover this:)
Jun 11, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
I have a maytag fridge,its maybe 3 years old,lately it keeps forming a pool of water in the front,the drain pan underneath is always dry,seems to be leaking fron the sises,a drain hose plugged or came off...
This is one of the most common problems that the maytag side by side has. ( Admiral ) The drain in the interior rear gets plugged and all of the defrost cycles over a week or so produces enough water to freeze up and the run over and come out under the basket then on to the floor in front left. If this is your problem, shut of the ref., remove the 2 or 3 baskets and remove the 2 screws holding the lower panel on. Remove the panel, careful not to cut yourself on the coil fins, remove the ice carefully, then use some hot/warm water to the drain area with a baster or something to apply and remove the water until it thaws and the drain clears of ice. Its about a 15 to 20 min. job. good luck.
May 07, 2009 | Refrigerators
Leaking Washer Machine
this is joyce
This sounds like a center seal kit, they run around $80.00 they are complecated to install so I would suggest getting someone to install for you.
thanks,
joyce
Feb 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water leaking from Washer during cycle
you can remve a few screws(3) across the bottom of the unit.( just above your "add-on" drawer. 3 torx 20 screws and after removing the acess panel youll get abetter look as to where exactly you water is coming from
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washing machine leak
I've got the same problem going on. You can take the front off the machine . Its two panels held on by four screws. This will expose the "guts of the machine, plus you can lift the top up, but not really enough to do a major repair. You will be able to see the water leaking though. Good luck. I bought mine used about three years ago and am thinking its not worth fixing. The machine I'm guessing is about 8=9 years old. If your looking for a used machine, you might want to check with a "Resale" type store. We have a Habitat for Humanity Resale store that gets good used appliances in sometimes. Of course, whenever you buy used, your taking a chance. However, when you look at the cost of new ones compared to used ones a couple of years old, it might be worth it. I looked at Maytags at my local Lowes, and they were about $600.00. Used ones are about $100.00. Good luck. Hope things work out for you.
Dec 29, 2008 | Maytag Legacy Series Top Load Washer
The grinding (bearing) noise on "spin", now leaking rusty water under machine... 3 1/2 years old "Legacy" ??? NOT !
maytag has rear rollers and front drum glides when goes out sound like sand paper scratching, also inspect belt idler same noise
Aug 14, 2008 | Maytag Legacy Series Top Load Washer
Maytag A212 clothes washer, leaking on fill up.
Possibly Injector / Vacuum break unit has gone bad (mine started spilling water lately, 20 years old). Get a 216201 to replace in your vacuum break, or better (if the machine is older) replace everything from the water valve with a kit: SUB 206680 (INJECTOR HOSE KIT).
Quite easy to get to. Just open front panel (remove two screws at bottom, lift bottom of panel away from machine and swing out. Spring clips at top should release easily. Then remove two bolts that hold top cover down and lift top. Water injector/vacuum break will be at the rear left of the machine. Costs about $40 for the kit. Or $5 for the small rubber part (but I am replacing everything that is pressurized on my machine since it is 20yrs old). -- Kevin
Jul 19, 2008 | Maytag Washing Machines
Legacy leaked on floor and subsequently ruined gararge ceiling. I put a wash in yesterday, filled it shut it off and left it soaking. I returned home from my errands three hours later to an 3/4 empty SS...
Its most likely the tub seal at the bottom, check and see if the area inside is wet in the middle. You will need to remove the outer panels to do this. It doesn't sound like anything else if the water was left to sit so a replacement of the seals around the center shaft should fix this problem. Let me know if you have any questions about doing this and I would be happy to help.
Jun 04, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
