Question about Sony Cybershot W330 Digital Camera
Sony cybershot w330 lens wont move - Sony Cybershot W330 Digital Camera
  • 7 Answers
SOURCE: wont turn on
I don't know if this will help, but try it. Install new batteries. You may have enough power to view the images, but not have enough power to operate everything. There are also microcomputers in the camera. You can also try removing batteries, WAIT 1 FULL MINUTE, then reinstall (making sure the polarity is correct). Hopefully either of these simple solutions help.
Posted on Dec 04, 2008
  • 11967 Answers
SOURCE: the lens keeps on moving in and out and there a
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 17, 2010
  • 420 Answers
SOURCE: sony cybershot dsc - w55
the part which comes out when the power is on might have got stuck .. there may be some dust particles. just blow over it or vaccum it..
Posted on Sep 10, 2010
shajanrs
  • 890 Answers
SOURCE: on my sony cybershot dsc-w100 the lens is stuck on
Most of the lens issues due to mechanical problem. some of the causes are dropping the camera.
Hard shake like keeping the Camera in the hand and jump through steps, Moisture condensation, Insufficient battery.. etc If If you feel that the issue is not with the above reason. Remove the battery, reinsert after 2 minutes to perform a power reset and check the operation.
If the issue persists, service may be required.
Thanks for understanding
Posted on Jan 26, 2011
Testimonial: "Thank you..also does taking the battery out and putting it back in do the power reset or do you do that separately? heather.angle79@yahoo.com"
  • 11967 Answers
SOURCE: hello my problem is on
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Posted on Feb 20, 2011
Can't download pictures to my computer from my Sony Cybershot W330
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sep 25, 2012 | Sony Cybershot Dsc-w330 14.1 Mp Digital...
Pictures on sony dsc-w330 too bright
Please reset the camera or make the exposure mode in +/- 0. then try and let me know the result.
Aug 05, 2012 | Sony Cybershot W330 Digital Camera
When turned on,lens stays in and screen displays day,month,year format.Any ideas?
There has been a problem with the camera IC.
don't try to repair by your own.
take it to a authorized sony showroom.
Jun 10, 2012 | Sony Cybershot W330 Digital Camera
Sony cybershot dsc-w330 functions buttons does not work
Remove the battery and the memory card, press and hold power for 60 seconds this should remove residual voltage and reset the processor ic, if there is no change the systems controller board has failed, cheaper to replace camera.
Jun 09, 2012 | Sony Cybershot W330 Digital Camera
How to fix reinsert memory card from sony DS - W330 digital camera?
Hello.
Remove the SD card then replace it back. If you are still having a problem, format the SD card using the camera. If that still doesn't solve the problem, you need to replace the SD card with a new one.
Aug 09, 2011 | Sony Cybershot W330 Digital Camera
My sonycybershot w330 is blurry..reviews say it has a antiblur so im thinking its a setting i have to put it on.. i need help thanks
On some cameras, it's called "shake reduction" or "shake control". On others, it's "image stabilization". Check your manual.
Apr 04, 2011 | Sony Cybershot W330 Digital Camera
Tried a different battery and still wont turn on, has not been dropped, is there a way to reset from factory like a phone or it that it for the camera
If it won't turn on then you cannot set it back to factory settings. The W330 is a fairly new model and should still be under warranty (1 year) so try contacting Sony support for a local repair facility.
Feb 03, 2011 | Sony Cybershot W330 Digital Camera
I have a sony cybershot and the backlight wont turn on
When i turn on my sony cybershot the lens keeps going in and out and it stops and on the screen it says turn off and on again but it doesn't work
Jan 02, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cybershot W330 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
