Question about Braun FlavorSelect KF 187 Coffee Maker
Need Instructions need the manual can't figure out how to program the time and stuff.
Cannot get scanner programed
Most radio scanners these days have software that you can program from your PC etc, You will also need a cable, if not supplied. Check at the Uniden website. However you should be able to program it manually. Again the instructions that came with it? should tell you how.
Normally a scanner can be programed to scan between two frequencies ie 144 to 146 for the 2mtr amateur band etc
or you can program channels.
Feb 09, 2014 | Uniden BC340CRS Base Scanner
Need instructions to program DVD Rec.Remote
Get the manual or figure out from LG's website about the thing,the site should have a download of the manual for the thing
Jan 03, 2010 | LG Electronics/zenith 6710t00008 Remote...
I need an instruction manual for Brinks model 44-1030
Did you ever get a manual for the timer? I have one too and cant figure out how to program it. I also cant find the instructions.
Nov 22, 2009 | Hardware & Accessories
I am clueless how to set programs on our Honeywell thermostat. I am unable to find a part number or something that distinguishes the type so I may get a manual of operation. Is there a general...
Start at the 'menu' button. Push button and scroll through to 'program' section. You will need to set the date and time and all that stuff. Then just keep going through the menu until yo find the program function that you want. Set the days and times yo like. You won't hurt anything so be bold and just keep at it, you will get it!
Sep 16, 2009 | Honeywell Programmable Thermostat Heater
Need instructions on how to program all ten buttons for different temperatures for we have no manual that shows us how. We manually programmed button number 1 for 350 degrees F and it works, but can'
http://www.langworld.com/lang_cd/Operate%20Manuals/CNVTOVEN/Op%20Convections.pdf
Check out this web site for your manual. The model EHS-APM is not listed but there are other units with multiple programming options. You will have to browse somewhat but what you are looking for is probably there.
Good Luck and hope this helps.
May 17, 2009 | Lang Manufacturing EHS-APM Electric Oven
No assembly instructions in our box!
I didn't get any instructions in the box.What do I do?I don't know how do some of the stuff.
Jan 08, 2009 | Toys
Location of programmer for keyless entry remote?
you shouldn't need to find it. Your owner manual will instruct you how to program your keys.
usually, you get in the car, lock, unlock, lock the doors. turn the key from off to on about six times, wait for the lights to flash to tell you are in the program mode and then program each key. then the lights flash again if you are successful.
The dealer usually charges 1/2 hour to do this for you.
Dec 01, 2008 | 1991 Chevrolet Caprice
Factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Nov 23, 2008 | Sentry Fireproof Safe
Braun FlavorSelect KF 187 Coffee Maker Logo
Top Braun Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
ellipse0904
Level 1 Expert
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
