Question about Garden
Cub cadet trimmer line does not stop unspooling
  • 17 Answers
SOURCE: CUB CADET BROKEN SHAFT
If you have a invoice of your purchase, Check your owners manual it should have a contact for your nearest warranty agent. Give them a call, make shore you have your D.O.P and model number.Hope that helps
Posted on Jan 12, 2009
moretons
  • 155 Answers
SOURCE: primer sticking
Chances are you have an internal blockage in the carby and the diaphrams may be hard as well.
Posted on Sep 08, 2009
  • 736 Answers
SOURCE: I have a Cub Cadet cc4125 string trimmer not starting
need a little more information .. but look for the following .. take out the spark plug and look inside with a flashlight ... if the piston is moving with the rotation of the flywheel then you likely have a blown head gasket .. if there is no compression there wont be a load on the pull cord .. a cracked or damaged piston can also do this .. ... if the piston is not moving when you rotate the flywheel then you likely have a bad "shear key" sometimes called a "shear pin" .. thats usually a half moon shaped small metal part that keeps the flywheel locked rotationally to the crankshaft .. it is designed to shear off if there is an excessive sudden load on the engine .. the flywheel will then spin without turning the crankshaft .. the same thing will happen if you have broken the connecting rod .. (a rod failure is often preceded by lots of clatter from the engine) .. the head gasket or shear key are much more likely to be your problem .. if you cant see in the spark plug hole you might try using a straw to feel the piston motion .. its possible that without the spark plug in place the piston might move even with a bad shear pin .. because with no compression the piston will move freely .. if thats the case you can stop the piston motion with a wood dowell thru the spark plug hole .. if it moves in spite of your dowell resistance then consider the head gasket option ..
Posted on Sep 19, 2009
rycgl
  • 1545 Answers
SOURCE: I have the Cub Cadet
If the head is shot, go to Home Depot and in the garden center, you will find many replacement type heads. They may have one that will fit your machine, because they carry universal replacement string heads. Check them out because they are cheaper than the small engine repair shop.
Posted on May 27, 2011
  • 731 Answers
SOURCE: I have a cub cadet
The carburator is plugged.
1st check your gas can and make sure the gas is not contaminated... no rust no dirt etc as it doesn't take much to plug those little carbs.
Go to a home center store and purchase a can of small carburator spray cleaner
Remove and disassemble the carb and soak the parts in CLEAN gas for about 15 minutes agitating every 5 minutes or so.
Using the spray nozzle blow out all the ports and then reassemble the carb.
2 other alternatives
1) Take it for service ( they'll probably replace the carb)
2) replace the carb yourself
You didn't include a model so I cannot provde part numbers
Posted on Jul 20, 2011
Cub cadet just dropped dead?
like a car engine broken rod--piston ring--wrist pin --blown gaskets
May 18, 2017 | Cub Cadet Garden
Rzt 50 cub cadet stops running after 5 seconds
fuel problems. start with fuel lines, filter. if that don't solve it take the carburetor off and clean it real good. maybe a carb. kit they are cheap.
Nov 04, 2016 | Cub Cadet Garden
Cub cadet weed eater only starts for a second with starting fluid then shuts down
My roybi did the same thing. The fuel lines were swollen due to the ethanol in the gas. Replaced lines with ones that can handle modern fuel.
Jul 14, 2014 | Garden
Trimmer string will not stop comming out
Hi sounds like the cord is wrapped on the wrong way or the bump feed is engaged in the on position.
Apr 14, 2014 | Cub Cadet ST228 17" 27cc 2-Cycle Gas...
I have the Cub Cadet CC4125. The head for the line is very wasteful.Line will not stay in the spool. I also have Toro with the spool type head on it,and this is more efficicnt. Does Cub Cadet have a spool...
May 26, 2011 | Garden
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Unable to serivce or operate cub cadet edgers DE
Hello. go to this link and hopefully you will be able to get what you need
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10051&langId=-1
If the manual is not listed call cub cadet and ask them to send you one. Joe
May 05, 2010 | Garden
Cub cadet weed eater wont stay running
air vent in gas cap pluged, push a pin through it
Oct 04, 2008 | Craftsman 25cc Gas Line Trimmer
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
