Question about KDS Valiant 6380iPTD-01 Notebook
My vaillant atmoMAG does spark but does not start
Vaillant atmoMAG mini PT 11.Is possible a gas problem?
SOURCE: vaillant Boiler time switch no user manual
http://www.vaillant.co.uk/stepone2/data/downloads/9a/42/00/timeSWITCH_120.pdf
Posted on Dec 26, 2007
SOURCE: re-pressure Vaillant Turbomax Plus boiler
two pipes coming into boiler on right hand side have brass block valves with a small round recess. These two valves are linked with a stainless fill hose.
Inside the recess on each valve is a small slot, there is a "key" with the boiler but prob lost with the manual. The advantage of the key is its sized so you wont be poking it in the wrong place!
Using a screwdriver turn both slots throug 90 degrees, you will hear water running through. Sometimes one valve is left open so try a combination until the watert runs.
Keep an eye on the pressure gauge and dont let it get too high, if you have no idea of setting pressure head for about 1bar.
Posted on Nov 23, 2008
SOURCE: f22 on my vaillant boiler turbo max
Hi Guy's,
The answer is that your system is out of water pressure.
Usually there is a nob on the right under the base of the unit near to the small dial to the right of the front cover.
To enable the system to work correctly the needle on this dial should be in the Grey, about midway position.
Currently with fault F22 this will be lower to below the Grey and on the needle.
To bring the pressure back to the correct position, you need to turn this nob until you hear the water entering the system, KEEP AN EYE ON THE DIAL AND TURN THE WATER OFF AGAIN WITH THIS NOB ONCE THE DIAL IS IN THE CORRECT GREY POSITION AS MENTIONED ABOVE. DO NOT OVER FILL THE SYSTEM. I suggest you check this every six months or so.
Once this is corrected your unit will light up again.
Best of luck. Mike. N.
Posted on May 22, 2009
TechieJon
  • 43 Answers
SOURCE: boiler not igniting
sorry, i think u have this in teh wrong category, it was filed under a laptop model called Valiant
Posted on Jul 23, 2009
  • 104 Answers
SOURCE: vaillant eco tec pro 28
IF the weather is extremely cold, and you're getting F28, the external pipework may be blocked with ice. Warm up the external pipes (lag them if you can) - and now see if your boiler will re-ignite.
A friend fixed our condenser boiler with this tip - hope it helps you.
Posted on Jan 09, 2010
My Vaillant Boiler (sorry don't have a model number, although about 16 years old) is giving me central heating but no hot water...BG came round and just said i would need a new boiler (£2000+)...
Vaillant UK have therir own service techs (I used to be one). They sound pricey but they carry plenty of spares and usually fix it properly first time. These units are complicated and many gas guys shy away from working on them; either try and sell you new or hand out massive bills to replace parts that don't need replacing. At a guess i reckon the water section is either blocked in the venturi or the diaphragm is punctured, both easy fixes. Vaillant used to be about 120 pounds for an hour inc. callout, as I said sounds expensive but it gets fixed, maybe ask for a service at the same time so you get your moneies worth.
The only cost for this advice is if you do get them out let them know big Steve from Plymouth is enjoying Australia (left Vaillant after 10 years service in 1999 to emigrate to Oz)
Dec 13, 2010 | Heating & Cooling
My vaillant ecoTec plus shows F49 , new vrt 360
F.49 eBUS undervoltage Short circuit on eBUS, overload on eBUS or two power sources on eBUS with different polarity F.61 Gas-valve control defective Short circuit/earth (ground) leak F.49 eBUS undervoltage Short circuit on eBUS, overload on eBUS or two power sources on eBUS with different polarity F.61 Gas-valve control defective Short circuit/earth (ground) leak i pasted the answer below hope it worked
Aug 02, 2010 | Heating & Cooling
Its a vaillant condensing gas boiler, it is showing problem with ignition, it won't fire up. fault code 28
f:28
air in gas
gas rate low
could be gas valve faulty,ignition transformer,ignition cable.
if there is a spark then its your gas valve,if no spark then check continuity on harness and spark generator,also check earth to appliance
Oct 19, 2009 | KDS Valiant 6380iPTD-01 Notebook
Vaillant combi boiler,dirty water comes out of hot and cold taps ,just been serviced by british gas,could you tell me the problem
Hi ,
Can you please tell me the model of the vaillant, and the approx age?
I can solve this problem
I await your reply
Thanks
Steve :)
Jul 16, 2009 | Water Heaters
I have a Vaillant boiler Turbo Max VUW 242/1E, central heating is working but no hot water
You have a faulty diverter valve, this is a fiddly job, you need to call in a 'Gas Safe' engineer to diagnose and replace this
I hope this helps
Steve
Jun 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Boiler light wont ignite
more likely the thermal coupling is u/s get new one fitted
Dec 02, 2008 | Water Heaters
Vaillant Boiler time switch no user manual
Nov 04, 2007 | KDS Valiant 6380iPTD-01 Notebook
KDS Valiant 6380iPTD-01 Notebook Logo
157 people viewed this question
Top KDS Computers & Internet Experts
RobertFonner
RobertFonner
daibras
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
