For some reason the channel change/forward/rewind/play/pause does not work when pressing the remote control. All other buttons work, and the one on machine work. Please help!
most universal remotes usually only do the simple commands like power, play, fast forward, rewind, pause, stop.
It may not be capable of setting the time.
If the remote is able to be switched to just work for your VCR you could try to press the menu, input or setting buttons to bring up any type of menus that would possibly help. If that doesn't work you may not be able to set it with the remote.
This simply sounds like a "remote address" problem, in other words--the remote is not assigned to the set. If this is for a DVD or VCR, you might have to assign that function before they work--by pressing the "dvd" or "vcr" button before they work.
It sounds like a contact fault to its buttons inside the remote control. Your remote control need to have cleaned. To clean it, you have to open it and take the printed circuit board inside it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/ One among the post by this site have details about how to clean and check a remote control. Surf the site with patience.
The EUR7711150 remote works for several different Panasonic CD stereo systems. To switch between AM and FM, press the Tuner/Band button. (If you were in another mode, you'll need to press the Tuner/Band button once to get to the Tuner mode and then toggle if needed.) Then if you press Play Mode (above Repeat to the left of the number keys), you can toggle between Preset and Manual. In Preset, the rewind and fast forward buttons select between your preset stations. Alternatively, you can set the presets to numerical values and touch the appropriate number button. (Touch the >=10 button first to access Memories 10-15.) If you are on Manual, the rewind and fast forward buttons will let you move up and down between the frequencies. Pressing and holding Rewind or Fast Forward for a moment will let the radio scan to the next frequency in that direction with a signal.
The CD button enables the CD or MP3 disc player mode. AUX and Tape are for external audio devices and cassette tape mode, respectively.
These comments are based on using the remote with the Panasonic SA-PM19. Please add a comment with the specific model of your Panasonic radio if you need additional assistance.
Hi dhperezfamilmy name is Mike Houston of DISH Network and I was going over your post and withyour TV2 remote not working while TV1 is on there is a conflict between theremotes. What you will need to do is on TV1 remote press the MENU button 2 timesand it will take you to the System Info screen. On the TV2 remote press andrelease the SAT button and press the Record button one time and then press theselect button on the remote.
Press and hold the [D] button for 1 second or longer to switch to the adjustment selection display. Press <<(rewind) or >>(fast forward) to select CLOCK. Press Play/Pause button. Press <<(rewind) or >>(FF) to select the hour or the minute. Turn the [Rotary] knob to set the correct time. Press the Play/Pause button to store the time into memory. Press the [D] button to return to the previous mode. Reference page 9 in this link to your Clarion DB165. http://www.clarion.com/us/en/MungoBlobs/615/345/DB165-ENG.pdf
Hello Stephendo394:
Here are some advanced codes that were found on Remote Central.com web site.
003 Menu 004 Timer Recording 010 Timer Recording 024 Shutdown 026 Shutdown 036 Skip 30 sec 039 Next Page in Menu/Next Track in Play mode 041 Previous Page in Menu/Previous Track in Play mode 043 Time Slip 053 Record 055 Play 061 Right 065 AV 070 NTSC/PAL 076 Language Right 080 Language Left 084 Source 091 Source = SD 100 Playlist View 101 AV 105 Tape Speed 106 Advanced 116 5 117 1 118 7 119 3 120 6 121 2 122 8 123 4 124 Setup 127 Picture Info 140 ? 146 Record 148 Channel Down 152 Channel Up 162 HDD Management 164 Delete 178 Record Flexi-Mode 179 Source = DVD 180 Rewind 181 Returns to Menu 182 Pause/Play 183 Rewind 184 Forward 185 DVD In/Out 187 Forward 189 Context Menu 191 Enter 192 Up 193 Return 194 Left 197 Guide 198 Info 215 ? 219 ? 229 Create Chapter 230 ? 234 Display 245 9 249 0
Do you have a remote?
Some camcorders you have to hit the record pause button on the remote and then hit pause.
It then begins recording.
I hope this works for you.
