Question about Garden
Differential noise rear end noise
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Get this checked out may be just low on fluid could cause you major head aches down the road
Posted on Apr 15, 2014
Loud noise coming from rear end. Started yesterday and noise happens when truck is cold, but once it warms up no noise
Check the rear differential for leaks. Look behind both tires. If it is wet , the bearings and seals need replaced. I would put a bearing kit in the differential.
Apr 22, 2016 | 2002 Chevrolet TrailBlazer
Noise in rear end
Provided that this is a rear-wheel drive vehicle, there are a number of things which can make noise when you accelerate. Most are due to excess clearance in moving parts. This means some parts are worn out.
On the outside, the U-joint next to the rear differential can be worn and make noise. Inside the differential, usually a pinion bearing(carrier bearing) can make a noise like a whine or growl depending on the gap.
Now in the axle tube, the axle shafts have a bearing on each wheel. Like any bearing, when they wear out, noise usually indicates failure.
When Torque is applied on acceleration, the parts shift creating noise. If you have a Limited Slip Differential, there are clutch plates which have a material which can wear out. These types of rear ends also need a special Additive to make the parts work. Sometimes you get a clatter when the additive is low.
Have the U-joint checked first as it is the only external part to check. The rest will need disassembly.
Please rate my info.
Mar 11, 2013 | Ford Sport Trac Cars & Trucks
I have a 2002 Ford F 150 Supercrew. There is a whining noise in the rear axle. What causes this noise?
Fisrt thing to check is the differential fluid, make sure it is full up to the plug. If this is dry you could have ruined a bearing in the rear end. Next check all the rear axle bearings. Most likely it is the differential and the gears are dry and when they dry out they scorch and cause a noise like this.
If no issue found in the rear end it may possibly a bearing in the tranny. These noises travel through the steel and sometimes get confusing as to where they originate from.
May 26, 2011 | 2004 Ford F150
Have a 2004 Avalanche 1500 that has rear end noise that get louder turning to the right and goes away turning to left. Also upon excelatation noise not so loud coasting noise get louder have checked rear...
Suspect a worn left side spider gear or it's bearing in the differential. If a limited-slip differential, the left side clutch may be grabbing somewhat. In any case, the differential will need to be removed from the case to service any worn or defective components. Rear end service is not for inexperienced mechanics. Have you checked the fluid level in the differential? Hope this helps!
Nov 05, 2010 | Chevrolet Avalanche Cars & Trucks
Clanging noise rear and rear don't pull
The axle probably lost a keeper ring on the inside of the differential and the pieces may be going through the differential and ring&pinion gearing making the noises you hear. You will need to drain the oil out, find the broken pieces, and inspect all gearing for broken/damaged teeth, and for any noisy bearings. Flush the case out with cleaning solvent. Re-insert the loose axle after cleaning and inspecting it well--especially the interior end. Replace the keeper (new) on the axle end inside the differential spider gearing. Inspect the brakes on the loose axle side for any oil deposits and for any damage that might have been caused when the axle came out. If the differential is badly damaged, it might be cheaper to find another rear end in a wrecking yard. Hope this helps!
Dec 26, 2009 | 1997 GMC Suburban
2002 dodge 1500 rear end making whining nosie
This could be one of several problems: If the noise increases with speed, and you are only hearing it from the rear differential and not the transmission, it could be the rear differential carrier bearings, or rear axle bearings going bad. If you are only hearing the noise upon acceleration or deceleration, the rear differential ring and/or pinion gears may be going bad and the rear differential will need an overhaul. You'll have to get the rear wheels off the ground and see if you can pinpoint the location of the noise with something such as a stethoscope. If it's coming from the rear differential, you'll need to pull the bolts and the cover to determine if the gears are still in good shape, or if there is any pitting. Same with the carrier bearings; if you see pitting/ discoloration, they'll need replacement. If the noise is coming from one side towards the end of the axle shaft near the wheel, it's most likely a axle bearing going bad, and you'll need to pull the wheels, remove the diff. cover to release the C clip which holds the rear axle in place at the differential, and pull the axle out. You also need a special tool with a slide hammer to remove the axle bearing and seal.
Nov 20, 2009 | Dodge Ram 1500 Cars & Trucks
Noise in the rear end, not the brakes as I've checked them of a 2004 40th anniversary V6 Mustang. Has anyone ever had this before as the shop that I'm taking it to tomorrow seemed to know exactly what the...
Hello. I can assist you. Rear end noise is typically from one of three things: a bad or poorly balanced rear tire, the differential, or a bad U joint.
Nov 11, 2009 | 2004 Ford Mustang
Rear end noise when i let off the throttle
Check the U joints, there more common to go bad then the differential, unless you are low on differential fluids. You can take it to a drive line shop and have them replace the u joints and differential fluid and also have them readjust the ring and pin in the differential to give you more life out of the rear end. Good luck and keep me posted. Be glad to answer any questions you may have.
Aug 08, 2009 | 2004 Dodge Ram 1500
99 Jeep Grand Cherokee rear end humming
check the differential fluid in the rear differential. if the fluid is low, add fluid and see if the noise is still there, if the fluid level is ok see if the fluid appears metallic, if it is metallic looking or excessively thick it would be a good idea to have the bearings checked out. i am in the process of rebuilding a front differential on a 98 jeep grand cherokee for the same problem. the bearings inside the differential on the carrier and pinion gear were worn out causing a humming noise. if the wear is excessive the gears might also need to be replaced
Feb 17, 2009 | 1996 Jeep Grand Cherokee
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
