Question about Vector Maxx SST Power Inverter
Can I disconnect the audible low voltage alarm on a Maxx 350 sst inverter?
Does anyone have a circuit diagram of the Maxx 350sst
4 Suggested Answers
  • 69 Answers
SOURCE: I got a Maxx SST 1200 Watt inverter and i burned
(rs components) are really good for componets
Posted on Aug 09, 2009
duane_wong
  • 6826 Answers
SOURCE: i need help hooking my vector maxx sst 1000 w
A 1000 watt power inverter hooks to the battery terminals directly, not through the cigarette lighter.
Posted on Jul 20, 2010
tomtij
SOURCE: (Vector 400 Watt sst Power inverter) When I plug
You would need a pure sign wave inverter for any electronic equipment to work at its best, the playstation3 will not work on any other inverter. this only outputs 110v I that it the TV is set at 110v.
Tom from www.automotivetechnical.co.uk
Posted on Feb 03, 2013
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
Do I need to put a inline fuse or does the vector sst 1200 have a fuse or breaker in it
It probably does, but an in-line fuse is still the safest way to go, connected as close as possible to the voltage source as possible. The internal overcurrent protection device (aka, fuse or breaker) in the inverter will prevent the DEVICE from melting if it malfunctions. An in-line fuse will protect EVERYTHING if the WIRING malfunctions.
May 05, 2014 | Vector ® Maxx SST 1200 - watt Power...
(Vector 400 Watt sst Power inverter) When I plug the Inverter into the Cigarette lighter of my RV, and the TV 26" into the inverter It won't work.
I am assuming that the inverter works with other devices. This being the case, i am thinking that the television start up current is drawing too much power too quick for the inverter to handle and this is what is shutting down the inverter.
Feb 05, 2011 | Vector VEC024B MAXX SST Power Inverter
I have to connect a busser across a inverter such that it will produce sound only for few seconds after supply is gone.give suitable circuit
What kind of buzzer do you intend to use? Have you already selected a particular buzzer? The circuit depends on buzzer type / voltage rating / current draw.
Are you wanting the buzzer to be on the AC side of the inverter, or on the DC side? Is the buzzer going to be close to the inverter, or will it be placed some distance away?
Jun 09, 2010 | Vector Maxx SST Power Inverter
No led red or green vec550pob 1500 watt, nor do i know what the "power supply accessory socket"
how to repair power maxx inverter 1500 wats vec550pob
my inverter turns on but red and green light on at the same time, and fans working for 3 seconds on and off
Oct 25, 2009 | Vector Maxx SST Power Inverter
Green light on but no ac power out
Probably has an internal fuse that is blown. You will have to disconnect it from dc power and take the cover off and look for a fuse that is blown, should be near the AC outlet or on the circuit board. Could be a glass tube or newer style automotive plug in type. Good luck.
May 18, 2009 | Vector ® Maxx SST 1200 - watt Power...
The fault light stays on my power inverter
Try disconnecting the DC input for 5 min. or so, this will generally reset the unit.
Mar 13, 2009 | Electronics - Others
Vector Maxx SST Power Inverter Logo
37 people viewed this question
Top Vector Electronics - Others Experts
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
