Question about LG DLG5932W Gas Dryer
Process to install LP orifice in a DLG5966G LG Dryer. Disassemble instructions?
Amigaman
  • 248 Answers
SOURCE: lg gas dryer lp conversion
On the regulator on the burner you remove cap and turn upside-down and reinstall.
Posted on Nov 18, 2007
SOURCE: LG DLGX8388 Dryer LP conversion
I noticed there wasn't a response, did u figure it out on your own, I am currently in the same position...
Posted on Jan 20, 2008
SOURCE: Remove front of Dryer
go to appliancejunk.com and you can download the service manual. also make sure you don't move the set nut on the change screw.when you turn it in it take a little muscle. stubby screwdrivers are a must. we also removed the tube(2 scews)that was in the way of the oriface.if i had to do it again i could do it again it would be a snap
Posted on Feb 06, 2008
jyackle5
  • 8197 Answers
SOURCE: Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Posted on Jan 19, 2009
  • 36 Answers
SOURCE: how do I change the orifice on my kenmore dryer
More and more, you have to change the gas valve AND the orifice due to the liability issue of changing only the orifice and not doing a complete conversion. If, and this might be a big if, a conversion kit is available, you will need the model # of your dryer to order it. The kit will come with a spring and a tension nut for the gas valve and the orifice you need. Instructions will come with the kit. Follow them to the letter. An improperly installed conversion kit, or just changing the orifice, can be very dangerous. LP operates at a higher pressure than the natural gas the dryer was built to use, and an improper conversion presents a significant fire hazard.
Posted on Mar 03, 2010
WE HAVE A BRINKMAN GRILL AND BOUGHT THE LP TO NG CONVERSION KIT THAT IS RECOMMENDED FOR THIS GRILL ...KIT HAS TOTAL OF 6 ORFICES AND THE GRILL IS A 5 BURNER, WITH SEAR AND SIDE GRILL SO THAT MAKES 7..NOT...
Some Brinkman grills have the LP orifice installed on the NG orifice directly from the factory.
If that is true, you remove the LP orifice and the NG orifice is already there. Check instructions in the conversion kit and look for this detail carefully. I just did a Brinkman conversion and instructions were very confusing. The orifices in the kit are not used (on my unit).
Gary
Aug 21, 2011 | Garden
DLG5966G will not get hot. Vents have been cleaned and replaced with newer shorter ones. The heating mechanism sensor has been wiped clean...what could be causing it not to heat?
check if the igniter is glowing at all upon startup. you will need to partially disassemble dryer to check. if the igniter doesnt glow, then check the safety t-stat on flame tube body. it has a reset button on it. beyond that, it could be a gas valve problem, igniter itself; circuit board, etc..etc.
Feb 25, 2011 | LG DLG5932W Gas Dryer
How do i convert from natural gas to LP or Propane?
You need the LP gas conversion kit: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-lp-gas-con-item-number-ap4300853.aspx . Other sources may exist. This includes a replacement orifice and a spring and the installation instructions. The orifices are swapped with a small wrench. The spring fits inside the regulator inside the blocking plug.
You will also need to remove the cap from the regulator and turn it over. This makes the regulator compatible with LP gas. It's easy to tell which side is which - each side is labeled.
However, the conversion kit should be installed by a professional trained for the job. Your local LP dealer should be able to help you find a repair person with the skill. (Improper installation could result in a gas leak.)
I hope this helps.
Dec 09, 2010 | Amana NDG7800AW Gas Dryer
How do i get to the gas orifice to install conversion kit from natural gas to lp
You will need to call LG parts and ask for the part numbers. Their number is 800 243 0000
Good luck
Sep 25, 2010 | LG DLG5932W Gas Dryer
I HAVE THE GAS REGULATOR AND LINE OUT OF DRYER,DO I DISCONNECT THE GAS LINE AT REGULATOR AND INSTALL THE CONVERSION AT THAT POINT,LOOKS LIKE IT WILL REQUIRE ME TO ALSO INSTALL A NEW LINE TO BACK OF...
No, the conversion requires you to change the orifice and adjust the regulator to LP. The instructions should tell you how to do the conversion.
Good luck
Sep 24, 2010 | LG DLG9588 Dryer
How to check gas valve orifice to insure its correct for a LP install. VDSC5304bwh. It was ordered LP but box has been written over many times nat/LP/Nat.. Searched the web ..no help..I am a HVAC...
What is the BTU rating of the dryer. If you open the dryer door, it is listed on the dryer behind the door. Most are 20,000 or 22,000 btu. The orifice # should either br 54 or 55 if it's LP.
May 16, 2010 | Viking VDSC305-4B Dual Fuel (Electric and...
How do I change the orifice on my kenmore dryer from natural to a LP orifice?
Mar 02, 2010 | Kenmore Dryers
Natural gas to propane conversion LG dryer
You posted under a combo washer / dryer WD-4343RHD.
For a gas dryer, conversion is to replace Nat gas orifice with LP one (the LP orifice has a air hole going cross ways through it) plus screwing the regulator blocker (brass slot head screw on top of the gas valve) all the way down (if you missed that step, I would expect your symptoms). Also, make sure you have a good vent with strong air flow at the outdoor outlet. If poor vent, short cycling may occur.
Nov 22, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Lg dryer - gas
If you do not have the original orifice you will have to order a natural gas orifice and replace the LP one with it. It is just a small brass threaded part with the correct size hole in it, located right at the end of the burner. For a LG dryer it is probably part number 4948EL4001B but you should get your model number from the sticker just inside the door and order the correct part from your nearest servicing dealer. You can find LG servicer's in the US on line at http://us.lgservice.com/index_b2c.jsp
Nov 02, 2008 | Dryers
Dec 22, 2007 | LG DLG8388 Dryer
LG DLG5932W Gas Dryer Logo
251 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
