Question about Delta Plumbing
Need to know part number
I have Delta faucets in my shower - two separate ones for hot and cold that were installed in the mid 1980s. My shower is dripping now and I suspect I need new innards for the faucets, but don't know what part number to look for or even if its still available. In teh photo, they are the two clear roundish handles - the single lever handle is not connected to the water any longer. http://i228.photobucket.com/albums/ee57/debodun/shower_zpsb80bd2d3.jpg
  • 3 Answers
If you can remove the cartridges, might be able to tell you if the parts for the cartridges are still available, take a picture of that and post it.
Posted on May 08, 2014
Testimonial: "All fixed. I called a plumber and he assessed the hardware. He had to go to a specialty plumbing supply that carries older hardware, but was able to get the parts. Took him a half an hour to get the handles off, but everything okay now. Thanks for your response, though."
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
frcs68
  • 1605 Answers
SOURCE: hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Posted on Apr 06, 2009
  • 244 Answers
SOURCE: My Delta single handle shower faucet drips constantly
call delta and describe the round plate and the screw locatios. they can identify model. you need a new cartridge they costs $25-60. They may send to you for free.
Posted on May 09, 2009
  • 129 Answers
SOURCE: Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Posted on Oct 10, 2009
  • 10 Answers
SOURCE: No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Posted on Oct 24, 2009
Why is my delta kitchen faucet hot cold backwards
The supplies are probably hooked up backwards. Hot to cold side and cold to hot side.
May 24, 2014 | Delta & Single Handle Shower Faucet
The plumber reversed our hot and cold water supply for our Delta 1400 shower. This repair is not the same for the temperature adjustment is it? I have the handle apart and can see the adjustment but have...
I dont know if you really want to hear this but the faucet will have to be replumbed. The way this works is on the faucet you have 2 inputs (hot and cold) if they are not in there proper feed ports they will have to be removed and installed correctly. if they are installed using flex lines you can probably do it yourself but if its hard plumed (copper pipe) it will be more difficult as the pipes will have to be cut and moved.
Jun 22, 2011 | Delta & Single Handle Shower Faucet
Connecting shower faucet to water line. what are al lines for . This is a Delta faucet
You should only have two lines, one HOT and ONE cold, if your already using a delta, then that means whatever is already WELDED to inside the unit is DELTA as well. JUST KEEP IN MIND that if you intend to use something other than DELTA parts, you will NEED TO do welding work!! Just changed mine out and ran into the same issue as you.
Jan 26, 2011 | Delta & Single Handle Shower Faucet
Just had a single handle shower faucet installed in my new walk-out developed basement and it seems there is a control on it I want to remove. I can't get the handle to go beyond mid-point and I want more...
Hi im Rossouw
The rest of ur house water in the showers fine?
If not they must install a prv (Presure reducing velve) on the cold going to the house and geyser befor it t,s of to the house and even if the rest of the house water is fine u must ask ur plumber who intalled it if he took the cold water going to the new shower strait of the mains if so he must corect it by t-ing in at the right cold water supply or put a velve on the cold water to ruduse the cold presure . then u will have more hot presure and that means lovely hot shower
plz vote and rate my advice thanx
Jul 17, 2010 | Delta & Single Handle Shower Faucet
I installed this delta shower set & water
remove handle and adjust the cold and hot clips one is set to open to much if u still have the paperwork in it will show how to adjust it also
May 05, 2010 | Delta Home
Single-handle Glacier Bay shower faucet, hot/cold reversed
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
Mar 18, 2010 | Delta & Single Handle Shower Faucet
Delta 174925 single faucet,only gives Tepid water on ''COLD''
SOUNDS LIKE THE CARTRIDGE ASSEMBLY IS BUGGERED UP. PART #46463.
MAYBE THIS WILL HELP:
All parts and finishes of the Delta faucet are warranted to the original consumer purchaser to be free from defects in material and workmanship for as long as the original consumer purchaser owns their home. Delta recommends using a professional plumber for all installation and repair.
Delta will replace, FREE OF CHARGE, during the warranty period, any part or finish that proves defective in material and/or workmanship under normal installation, use and service.
Replacement parts may be obtained by calling 1‑800‑345‑DELTA (3358) or by writing:
Delta Faucet Company Product Service 55 E. 111th StreetIndianapolis, IN 46280
Dec 15, 2009 | Water Heaters
I have a Delta shower faucet model number 1324 and my shower head is leaking How do I get the faucet part apart I have a diagram, but actually looking at the insides it all looks like one piece I don't...
Hi Shannon:
The problem is most likely the seats and springs. You should purchase Delta Part # RP4993. I found some for mine at Lowe's for around $4.00. O-rings are available there too for about $2.00, and you probably should go ahead and replace them as well, especially if they feel dry and brittle.
You have to remove the handle, then unscrew the brass ring (or bonnet) with a pipe wrench, then just pull the cartridge straight out. Separate the lower cartridge from the upper by twisting a quarter turn to the left. Once separated, remove the black rubber seats and springs and install the new.
Sep 29, 2009 | Delta 2402 Classic Single Handle Kitchen...
Delta single handle faucet. Hot or cold no in between.
well they should be same size but unless you getting more of one then other then sound like mixing valve is not mixing. do have 3/4 hook up to mixing valve? you only need 1/2" to valve.
Jun 25, 2009 | Delta & Single Handle Shower Faucet
Plumbing Logo
70 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
john h
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
