Question about Electric Mobility Power Electric Scooter Power Wheel Chair Safety Flag
Remove battery trying to remove dead batteries from battery case so can put in new
  • Electric Mob... Master
  • 1,271 Answers
Hi, so what's the problem ?/ please explain...
Regards
Rob
www.gewizrepairs.co.uk
Posted on Apr 21, 2014
My chevy 95 Tahoe has been parked for a while with no battery, now I put a new battery, it cranks but won't sta st?
I ran into a similar problem with a Cavalier, turns out that the on-board computer needs to have constant power. Even if the battery is very low or even dead, it still has to be connected. If the battery is removed it breaks the circuit and stops the command that lets the engine start. After the new battery was installed it would crank but not start, the dealership told me that I had to have it towed to them to have the comp reset, which would have cost around $150 total. Thankfully a mechanic friend of mine had a diagnostic machine and was able to reset it for me - cost me a case of beer. He then showed me a (not so simple) trick around this for the future. Once it is running again remember this. 1 Have the new battery and jumper cables ready, 2 Loosen the battery terminals on the dead battery but DON'T take them off. 3 Connect jumpers to the car battery cables and to the new battery, like you were jump starting from just the new battery. 4 Remove the terminal cables from the dead one in the car and remove dead battery (be careful not to let them come off the cables OR the good battery) it's OK if it disconnects briefly, but reconnect it A.S.A.P. 5 Put the new battery in and connect the terminals BEFORE removing jumper cables. Once they're on the terminals just take away the jumpers and tighten the nuts. That's how you change a battery without letting the car ever lose power. Hope that helps Jose. Good luck, safe driving. Grimm
Mar 16, 2015 | Cars & Trucks
Battery replacement in wvq141 watch
Remove the back of the case. Remove the dead battery. Replace with a new battery. Close case back set time and your all set till it dies again.
Nov 10, 2013 | Casio Waveceptor Atomic Radio Controlled...
My fone dead put charger in does nothing dead dead dead
Nokia phones are notorious for slow response time when recharging from a completely dead battery.
Remove battery.
Make sure there is good contact between all of the contact points.
Replace battery.
plug in charger.
wait for at least 5 min.
If recharge symbol does not appear in window, then one of these things has occurred:
1. Phone has internal damage or water damage. no way to fix without nokia service.
2. Battery is dead. Try a new battery
3. Charger is bad. Try a new/different car charger or home charger.
These chargers are very inexpensive on Craigs List, try to solve it before throwing away the phone. Good luck,
A former Nokia employee.
Feb 16, 2011 | Nokia Cell Phones
I have 850 volvo and keep getting imobilisor and alarm when i go to start it new battery it doesnt reset
Hi
Did you switch the new battery over directly after you removed the old one? If so try disconnecting the car battery for a few hours, then when you put it back on put the live "red" on first then the "negative" black second. this often resets the immobiliser.
Hope that helps.
p.s in some cases with other makes you have to leave the battery off over night as the immobiliser if factory fitted has a battery backup built in. this needs to run dead.
Regards
Dan
p.s.s also try lock and unlock with the key not the remote.
Dec 29, 2010 | 1997 Volvo 850
The battery is dead. We have tried recharging to
There is a hold down at the bottom near the battery,a 8 mm bolt head,or maybe a 10mm.
Mar 13, 2010 | 2004 Ford Crown Victoria
I have a Sentry OA5835. I am unable to open with factory combo and key. help
Sounds like the batteries are dead.
How to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Mar 11, 2010 | Sentry Fireproof Safe
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
Sentry S3807 safe-cannot open
locksmiths agree on how to install sentury safe batteries
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Jan 26, 2009 | Sentry Fireproof Safe
Will not start with charger but the lights come on.
remove battery and try to turn on without battery otherwise you have to replace the battery.
Nov 02, 2008 | Compaq Presario 700 470024-192 Notebook
Electric Mobility Power Electric Scooter Power Wheel Chair Safety Flag Logo
49 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
