Question about Philips Medio 65 CP H Rad Room
Calibrating generator medio 65 cp h - Philips Medio 65 CP H Rad Room
How do I fix a blue halo around the picture on my Hitachi CP-SX1350 projector?
Have you tried cleaning the lens on the projector? Dirty optics can cause problems with proper light refraction. Hope this helps.
Jul 03, 2014 | Hitachi CP-SX1350 Multimedia Projector
Como actualizar catalogo del buscador medios del a45 eco
Hola! Tengo un Motorola A45 y cuando intento entrar a mis medios me pone: es necesario volver a crear el catalogo de buscador de medios..osea,no me lee ninguna tarjeta de memoria :( Ya lo reinicie general y nada paso.. Quisiera saber si me pueden ayudar?! Muchas gracias!
Feb 16, 2013 | Cell Phones
I have laser printer hp 3525 and printer don't mix colours properly so letters are to be printed green the yelow color print seperate and the blue seperate ,so the the print come with two letters as if...
> go to menu, apply set of default setting, then check..> go to menu, device setting,quality,calibrate color,calibrate now.. printer performs color calibrate, after completion, check the print quality. I hope it will resolve the issue.> if above said advises are not resolved the issue mechanical adjustments has to done which is not suggestible to the users.. only professionals can perform the activity.
Oct 05, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Error 59.CO
1. If the main drive assembly has been
removed for service repair, verify that
the main drive assembly is calibrated
correctly. Click Here for Fuser
2. Check that the following connectors
on the driver PCA are seated
correctly: J403, J405, J213.
3. Check that connector J1020 on the
DC controller is seated correctly.
4. Check that connector J5008 on the
fuser motor is seated correctly.
5. Replace the developing separationdrive
assembly.
6. If the developing separation drive
assembly has been replaced and the
error still occurs, calibrate the
developing separation drive assembly.
7. Replace the fuser assy...
Sep 20, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Is the only difference between at CP-X1200 and CP-X1250 the bulb, or is the ballast circuit different too? Just thinking how easily I could boost the brightness from 3500 to 4500 lumens.
Model: CP-X1200 ( Lamp)
Part#: DT00591
Lamp Type: UHB
Wattage: 275 Watts
Lamp Hours: 2000 Hours
Model: CP-X1250 ( Lamp)
Part#: DT00601
Lamp Type: UHB
Wattage: 310 Watts
I'm not sure but I would think the same ballast board is used, and the trimpots adjustments set in the factory.
If you fiddle with it, you may not be able to get the tube to strike on startup, or worse you can explode the lamp.
Also the extra heat generated may degrade the optics and LCD panels.not mention melting the housing.
Better to leave well alone.
Feb 18, 2011 | Hitachi CP-X1200 Multimedia Projector
Samsung,touch screen
My samsung star s5233W's touch screen not to access the menu .
I keep pressing the area where Menu, Phonebook and keypad are (area below) but It doesn't respond. it seems that the screen's calibration is off somehow but I cannot perform a calibration since I cannot press the Menu area. How can i fix this? Is there a hard reset button or technique? thanks!
Oct 12, 2009 | Samsung Star GT-S5233 Cell Phone
Calibration
The main setting is usually the brightness, contrast and hue, do it manually until you're satisfy with the results
Jul 28, 2009 | Mitsubishi WD-65C8 65 in. LCD HDTV
Harman kardon audio system for harley davison not calibrated
i have the harmon kardon stereo for harley and the sound keeps going out on it. This is the fourth unit that the same thing has happened too. Its like the unit goes into mute mode but its not. everything works but the sound. can u help me please.
Apr 18, 2009 | 2008 Harley Davidson FLHX Street Glide
Screen isn't right
You are in test mode. Take out the battery, replace it then power phone back on.
Dec 04, 2007 | Motorola Mobility i560 Cellular Phone
Philips Medio 65 CP H Rad Room Logo
65 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
