Question about Gateway DX4380-UR308 DT.GDFAA.004 Desktop PC Windows 8 64-bit
Can't Boot from USB Drive
I need to boot to my USB Drive in order to install Ubuntu to my PC. I have the drive formatted correctly and all done and everything, but my PC won't boot to it. I've changed in the BIOS to make USB first Boot Priority, but still no luck. I'm assuming I have to go to a Boot Menu, but pressing F12 doesn't work as the chat support told me I should do. Any ideas on how else to get to the Boot Menu?
  • 233 Answers
SOURCE: BIOS SETTINGS
Take the battery out for an hour. There should be a JUMPER near the battery but the position will vary with different motherboards. It might say something like CLEAR CMOS. There are three pins. Move jumper to opposite setting and power up the computer. Shut down and reset the jumper to original position. In setup, CDROM should be set to FIRST BOOT DEVICE. If all of this does not work the first time try again. They can be stubborn sometimes. But this should get you to a point where you can re-install XP. If your computer has Vista installed none of this may work. I know very little about Vista.
Posted on Jan 01, 2009
  • 60 Answers
SOURCE: PC will not boot up with new hard drive
Do you have a floppy disk in A:? Remove it and the pc will boot to the cd.
Posted on Mar 13, 2009
Combchris
  • 64 Answers
SOURCE: Ubuntu wont boot after mobo replacement
You have to repair the installion, When you change the mobo you need to reinstall or repair the os, even with windows, well of course with windows because windows sucks, Try updating from the shell sudo apt-get install update
Posted on Nov 17, 2009
  • 570 Answers
SOURCE: GT5058 memory and boot issues
If you are tired then you just simply format your system after taking back up of your important data
Dont worry about it it is a small problem and I know that you can fix it
thanks
have a great day
Posted on Jun 15, 2010
  • 39 Answers
SOURCE: GateWay FX6800-01e Computer After computers
deffintly sounds like a cmos battery issue. these are very easy to fix. all u have to do is take a antistatik strap around your wrist and hook to computer. you then can tak a flat head screw driver and pop the battery off the mother board. your can replace looks like a watch battery and is very common . ou can pick up at any computer store or watch place. heres a video that u can actually see how to do it http://www.youtube.com/watch?v=tkBWZOtp2is
Posted on Jan 06, 2011
Can I override the bios at startup so that it will recognize a new hard drive - for linux?
There should be no need to play around with your bios settings. Linux will install on a brand new hard drive as the sole operating system, or on an existing hard drive alongside Windows without any problem.
If you haven't already got a Linux distro, have a look at
http://www.ubuntu.com/download/desktop
Download whichever version of Ubuntu you prefer (LTS- the long term support version is recommended).
When the .iso file containing the operating system had downloaded, burn it onto a dvd, or install it on a usb drive.
Insert the dvd into the drive and restart or switch off/switch on the computer. The dvd will then kick in and offer you the choice of trying Ubuntu without installing, or a full install.
If you're using a new, empty hard drive just follow the on screen instructions and Ubuntu will install as the sole operating system.
If you already have Windows on your hard drive Ubuntu will give you the choice of either erasing Windows or installing Ubuntu alongside Windows. It's your choice.
Installing Ubuntu alongside Windows creates a dual boot hard drive. At start up you just choose which OS to use - Windows or Ubuntu. If creating this dual-boot system Ubuntu puts a (Linux) boot loader into the Windows OS so that Linux is recognised.
If you save the Ubuntu file to a usb drive you then have to change the bios settings so that your computer uses USB as the first boot device. Then restart your computer so that it boots in from your usb .. and Ubuntu will begin installing.
Whichever you use - dvd or usb - during the installation process Ubuntu will ask you how many GB of hard drive space it should use? You do not need to physically partition the hard drive. Linux will do it for you.
If it's a desktop PC you are using with Windows on the first hard drive and are fitting a second hard drive to install Linux on, or have installed Linux on the second hard drive .. and find that Linux doesn't appear at start up, it's because there's no Linux boot loader in Windows.
I quit using Windows many years ago.
Nov 01, 2015 | Everex IMPACT GC2500 PC Desktop
Tip
Run Linux from a USB Hard Drive
Running linux from a USB hard drive is a great way to install Linux without affecting your Windows hard drive that is already on your computer!
First of all you will need to download the Linux operating system of choice. For me, I use Ubuntu Linux. You can download the ISO from the Ubuntu website.
Once you download the ISO image, you will need to burn it to a CD. Once this is done it is time to start installing!
*NOTE - I would remove the windows hard drive prior to installing. That was I can make sure I don't accidentally overwrite my Windows partition! You can put your hard drive back in the computer when you are done installing.
Place the CD/DVD into your drive and shut down your computer. Plug in your portable USB hard drive and turn the computer on. If your computer doesn't say "please press any key to boot from CD" then you will need to change your BIOS settings to boot from CD before booting from Hard drive.
Once the CD drive boots up you will be given the option to run Linux or to install it. Choose install, follow the prompts for networking/computer name etc and make sure you don't install it on your Windows hard drive partition!
Once Linux is installed on the portable hard drive all you will need to do is make sure you can boot your computer from a USB hard drive. This is done in the BIOS settings to choose your boot order.
on Sep 26, 2011 | Computers & Internet
How do i install a operating system on a sony old sony viao 600hep with no dos and no operating system and a broken cd rom drive. only have usb.
Check out this:
http://www.ubuntu.com/download/desktop/create-a-usb-stick-on-windows
This gives instructions on how to download, and create a ubuntu bootable USB stick.
http://www.ubuntu.com/download/desktop/try-ubuntu-before-you-install
This will give instructiosn on how to load and install from said USB.
You will need:
A working computer with Windows
A 2GB or larger USB stick
Internet connection
After you've made your USB stick, when booting up the computer you wish to install ubuntu on be sure you have the USB stick inserted when powering it on. When the start screen comes up press ESC to enter the BIOS or boot order. Select the USB stick from within the BIOS boot order menu, or the USB stick from the boot options menu.
Load ubuntu, install, enjoy.
Mar 13, 2015 | Sony Computers & Internet
Averatec 2100
Remove the usb disc. If it boots you need to go in to the bios and change the boot order to hard drive first then usb etc.
Dec 13, 2013 | Computers & Internet
Ubuntu USB
Is your computer set up to read the USB drive in the boot sequence?
May 04, 2013 | ASUS Computers & Internet
How can i reformat my asus eee pc1000h if it doesnt have a cd drive?
You can reformat your Asus eePC 100h notebook using an Ubuntu Live USB.Here is how to make one: 1. Download an Ubuntu ISO Disk image from www.ubuntu.com or a debian ISO image file from www.debian.com. 2. You can also use an existing Live CD to create an ISO Disk image with if you have a working PC around.Many free tools exist for creating disk images.I suggest Ashampoo Burning studio or CDBurnerXP.Search for them on google. 3.Get your hands on a working PC that has Windows XP/Vista/7 installed on it. 4. Download the UnetBootIn utility from http://unetbootin.sourceforge.net/unetbootin-windows-latest.exe. 5.The procedure for creating the Disk Image is as follows: (a)Requirements: 1 GB or larger USB drive, formatted as FAT32(most USB drives come formatted as FAT32 by default, but if you need to format it, on Windows, go to My Computer->right click your USB drive->format.
On Windows XP, you must be logged on as an administrator; on Windows Vista and above, you will be prompted for permissions via UAC.
On Windows, the UnetBootIN software looks like this:
Follow the guided prompts on the software to make your Live USB drive, and be careful to select the corrrect linux distribution on the window.
When done, safely remove the flashdrive from the PC and plug it in your Asus eeePC 100h notebook.
Boot up your notebook and press the F2 Key as the system starts up and select the USB flash drive as the first boot device(You can also do the same from the BIOS setup).
When you boot up with the Ubuntu Live USB, select "Try Ubuntu without installing" option to run the Live OS on RAM.
When the system boots up completely, go to System>Administration>Gparted and the Gparted Disk utilitty will run.
From the Gparted menu, select the appropriate partition you want to format or modify.
You can read more on Gparted here.
When you are done partitioning and formating your HDD as you desire, you can also install Windows XP/Vista/7 from a FlashDrive by following the instructions below:
1.Get your hands on a working PC with Windows XP/Vista/7 installed.
2.Download the WinToFlash utility from http://wintoflash.com/download/en/
3.Install the application on the PC.
4.Once you are done,insert a Windows XP CD in the PC's optical disk drive and follow the installation instructions from WinToFlash.
By default, the installation path for Windows XP files on the drive is DRIVE LETTER:/Windows/system32.
See the screenshot below for more details:
You can use the created bootable USB to install Windows XP on your notebook.
For more on WinToFlash, see this link:http://komku.blogspot.com/2009/09/wintoflash-guide-install-windows-xp.html
Have a great time ahead.
Jan 14, 2011 | ASUS Eee PC 1000H Laptop
I have an ASUS netbook that runs linux. I don't know linux, but was told to upgrade to ubuntu. I don't know how. Anyone know how?
1. I would suggest finding out which model Eee PC you are using and the hard drive size & type (4GB SSD, 160GB SATA, etc...). If you have less than 4GB, I would probably recommend using another Linux distro, as the Netbook Edition of Ubuntu is pretty heavy.
2. Next, I would probably suggest plugging in the Eee PC (Software/OS installation is very power intensive).
3. Download your distribution (Ubuntu Netbook Edition or Desktop, etc).
4. Download a copy of unetbootin for your PC (unetbootin.sourceforge.net -- There are Linux & Windows versions available.)
5. Using a USB thumb drive (USB Memory stick), you will want to wipe the drive (format using FAT/FAT32 filesystem).
6. Run Unetbootin, selecting the proper USB thumb drive & ISO image from the Ubuntu website.
7. After Unetbootin is finished, close it and safely disconnect the USB drive.
8. Next, plug the USB thumb drive into the Eee PC.
9. Turn on power to the Eee PC & after seeing the initial BIOS splash, hit the ESC key on the keyboard. This should bring up a boot selection screen. Using the arrow keys, select the appropriate USB drive and hit Enter (Return).
10. If all goes well, you should be running Ubuntu Desktop/Ubuntu Netbook Edition as a live desktop. (The installer is a link on the desktop.)
11. There are several step-by-step guides out there, so check them out, if needed. The installer should be very simple on this type of hardware, etc.
Good Luck!
--TaoBeastie
Jul 07, 2010 | Canonical Ltd. Ubuntu
Lost restore disk,want to install oem windows xp. computer doesnt read disk
I assume you're saying that the pc is not booting from the DVD/CD? If that's the case, you
need to go to the BIOS setup, where you need to change the device boot order. It's now
probably set to start running from the hard drive, reason why your DVD/CD is not booting.
To go to the BIOS setup, press the F2 or delete, or whatever key the first POST messages
instruct you to use to go into SETUP mode. Different BIOS manufacturers use different
keys, so you have to be quick and interrupt the boot process using the correct key. If you
fail to determine what key it is, reboot once again, until you see/read what key does the
job.
Next, once you're into the setup screens, look for one set of options called Boot Options
or Boot Order. Read the instructions to learn what keys to use to change the values.
Ensure that the first device accessed is the CD/DVD drive, then whatever else next, etc.
Once that's done, save your settings following the prompts, load your DVD/CD and reboot
again.
That should read the disc and start the installation.
Aug 21, 2009 | Dell OptiPlex 170L PC Desktop
Install Ubuntu
Make sure the computer starts from the cd drive.
see this page for instructions on changing the boot order
http://www.whitecanyon.com/how-to-change-boot-order.php
ones the boot order is set properly insert the cd in the drive and restart the computer.
ubuntu cd/dvd will load and give you some options on the screen, follow the prompts to install ubuntu.
if you need more help read the ubuntu documentation
https://help.ubuntu.com/community/Installation
if the above link is broken try
http://help.ubuntu.com/community/Installation
Aug 09, 2009 | PC Mall Ubuntu 8.10 for Linux
How to use my usb port for booting my acer tm290 series?
First off your BIOS must have a "Boot to USB Hard Drive" option available. Then you need to configure the drive boot order; USB-HD -> CD -> IDE -> SCSI. Then the micro-drive must be formated with the "Boot" or "Active" partition flag enabled. If you are trying to boot Ubuntu there are several tools you can download that format the USB drive and set the boot flag for you.
Nov 28, 2008 | Acer TravelMate 290 Notebook
Gateway DX4380-UR308 DT.GDFAA.004 Desktop PC Windows 8 64-bit Logo
63 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
