Question about New Home Sewing Machines
New home 511 can't change stitch pattern
The machine won't do any of the other stitch patterns aside from the 1st option (straight/zig)
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: changing stitch pattern
you can find it all here
http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_LS_1217_1520_1717_2125_VX_1435_EN_364.PDF
Posted on Dec 17, 2008
MayeresJnot
  • 74 Answers
SOURCE: My sewing machine will not change from straight
Your gears are not aligning correctly inside the chassis. I would suggest taking your machine to a certified repairman, because if you touch the wrong gear or tighten it in the wrong position, it may do a zigzag, but then your other designs will not work properly. Simple fix for the right repairman. If you open the chassis, make sure it is UNPLUGGED.
Posted on Nov 16, 2010
SOURCE: missing stitches on zig zag with loose stitching underneath fabric
try changing the needle
adjust the top tension if nessary
Posted on May 14, 2012
Machine not working as normal
it's possible there could be a loose or broken part in the machine, and the cam that does the zig zag could be worn or damaged.
having it checked would be a good idea.
Apr 03, 2014 | New Home Sewing Machines
Singer 756 zigzag timing is off
The machine may be slightly out of time so it works in straight stitch but not zig-zag.
Oct 23, 2017 | Singer Sewing Machines
Pattern selection dial
take the machine back & get another one
Aug 30, 2012 | Brother LS-2125 Mechanical Sewing Machine
My Elna Super won't sew zig zag or any other stitch except straight. What do I do?
Change the needle first in case it is faulty, if it is sewing straight stitch perfectly then you need to check the pattern camstack on top of the machine to see if there is a split in it
Aug 28, 2011 | Sewing Machines
I cannot get my sewing machine stitch the different stitches. I've followed all the instructions in the manual and all I get are straight stitches. I want to get a zig zag. Sometimes it looks like it did...
When you select a pattern does the needle move back and forth? do you make sure the stitch width lever is on straight stitch then select your pattern then select the widest stitch width? if when you select a zig zag stitch the needle does not move from side to side then you need to look in the top at the finger that goes round the cam.
Nov 04, 2009 | Singer 2732 Mechanical Sewing Machine
Only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Jul 26, 2009 | Necchi Sewing Machines
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
12 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
