Question about NiteRider Lumina 350 Bike Light
Light not working
Light will not work. Battery appears to be fully charged. The outside black wire isn't connected.
    Master:
  • 388 Answers
Your light may be in lock mode, press the power button for several seconds and the button should turn or flash blue. Normal operation should be available. If this doesn't work, you may have a defective unit and will have to return it to NiteRider for warranty.
Posted on Apr 15, 2014
Truck will not turn over, gauges all come on but nothing from the engine, acts like dead battery but it is brand new...it did it before and was told it was the battery, put a new one in....worked great for...
your charging system isn't working, if you replaced the battery and it worked for a few days, then its not being re charged after starting, I'm assuming you cleaned and tightened all the battery post connections when you installed the new battery , if not do so ,, charge the battery from an outside source, once you know its fully charged,, use a meter, and start the car ,, check the voltages at the battery posts,, you should be getting a reading of 13.5-14.5 volts, if not your alternator isn't charging the battery
Sep 07, 2011 | 2004 GMC Sierra
The battery does not charge, its a new battery.what do i look for?
if its a new battery it could be as simple as it wasn't charged when you purchased it, If it was charged and your mower isn't charging it, the power source to the battery from the mowers motor isn't working properly,, not knowing if its a 12 or 6 volt system you need to check the battery ,, see which one it is,, using a multimetter ( if its 12v ) check the battery after you charge it with an outside source ( battery charger) you would have a reading of 12-12.5 volts on a normal check,, then start the mower, and check the battery as its running,, you should get a reading of 13-13.5 volts minimum, if your not, the alternator or magneto isn't working properly, if you do show the increased voltage at the battery connections, then you need to clean the contacts since the charge isn't reaching the actual battery
May 24, 2011 | Garden
How do you tell when the battery is fully charged. It continues to show that it is still charging when it would have to be fully charged. The battery is a 3.8V which isn't mentioned on the charger...
The light usually changes colors or goes from flashing to solid even from a light being on it going off when charged. Every camera is different. Normally a good hour will fully charge most camera batteries.
May 13, 2011 | Cameras
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
Internet connects, however when we try and view a page it doesn't work. The amber light shows when it is not working properly. We have rang our ISP and they have done various things and it doesn't...
Is this a cable service?
It is possible you have a bad connection. Either inside the house or outside.
Cable.. You will have a cable modem connected to the cable.
One main thing to do is to re-trim all the ends of the cable at every connection point between the modem and the outside connection. Replace any old connectors or splitters with new ones of correct value. The idea being to remove any oxidation which will impair the signal. If none of this helps, you may need the outside wiring looked at. Your connection service should do this at no charge.
If you have not done so, power off the modem completely, including removing the battery back up.
Wait about 20 seconds. Reinstall battery and power connection. About 20 -30 seconds to reconnect.
"few hours everyday" might indicate a problem outside, (wiring or junction box) possibly warming up in sun and cooling later?
On the PC. Use the connection wizard to "connect to a network". Connect to your own network on every pc you use.
Feb 21, 2011 | Belkin (F5D7633UK4A) Wireless Router
Vehicle: '97 Nissan PU, alternator
ok we have four connections at the alternator( black wire is ground) (white with blue positive direct from the battery)
and two wires connector in the regulator(yellow with black that goes to charge indicator the red light and goes to fuse 7 10a fuse block inside) the blue with yellow goes to fuse 65- 7.5a in the left fron engine comparment fuse box))#1 check for ground at the black wire= #2 check for positive at the white with blue wire (allwas with power) this wire is protected with 100a fuse is in the left front engine comparment fuse box,
remenber== check the 100a fuse
and the two fuses that protect the regulator.
when you turn the ignition switch to the on position power goes to the alternator by the yellow black wire and activate
the alternator to work.
Mar 13, 2017 | 1997 Nissan Pickup
My 1996 cadillac eldorado says battery no charge now hard to turn but it cranks right up
Most likely you need a new battery but do this first. Remove the battery ground connection and the positive connection. Clean them with soda water(coke is sticky but all sodas will work). Scrape or sand the inside of the cable connectors and the outside of the battery posts till they are shiny. A low battery light usually means it is not fully charged or taking a charge optimally but effective troubleshooting the battery and starting system starts with clean,secure connections and a fully charged battery. If your battery has electrolyte filling caps undo them and check the level. If they need topping off use distilled water only. Charge the battery with a car battery charger. It should read about 13.4 Volts under no load. Check and clean the battery negative cable connection to the block and the positive connection to the starter solenoid. Check for good connections to the charging output from the alternator. Inspect all wires for kinks, cracking, shorts, ect. A good once over will reveal probem wiring. Reinstall the battery and cables. Giv'er a crank and see if that is not stronger. Drive it for an hour or so and crank it again. Any noticable degradation in cranking power means you have a bad battery, alternator, diode pack if applicable, voltage reguator, or any combination of the three. Take your alternator and battery to your auto parts dealer. They will usually test them for free. Aslo, starters can wear after time but this is most likely not your problem based on the symptoms.
Jul 08, 2009 | 1996 Cadillac Eldorado
Unable to crank after sitting
Interesting problem. There are a number of things that can contribute to these symptoms: Battery not holding charge, charging system not working, bad/corroded battery and/or starter cable connections, and of course something draining the battery when the ignition is off.
Before doing these tests, make sure the battery is fully charged by disconnecting it from the car and charging it 24 hours with an external battery charger.
Is the charging system (alternator) working? Accords have an idiot light, not an ammeter/voltmeter, so it could be your car isn’t charging and the indicator light is burned out. Connect a voltmeter to a fully charged battery and observe the voltage (should be about 13.8 volts). Now start the car and observe the voltage again, should be higher than before (around 15 volts). If the voltage doesn’t increase at least slightly either the alternator belt is loose and slipping or the alternator is bad.
Are the battery terminals tight/clean? Any corrosion on the terminals or wires? How about the end that connects to the starter? How about the ground wire to chassis? Any corrosion could produce an intermittent connection problem that acts like a dead battery.
The battery may be new…but is it good? Charge it, connect it and confirm the car starts. Then DISCONNECT the battery, let sit 24 hours, re-connect and try to start. If the battery now acts dead maybe it is bad. Exchange under warranty.
And last, something is discharging the battery. First question, do you have any non-Honda add-ons like an aftermarket audio system with a power amp? Audio power amps have a direct wire to the battery for greater power, if the amp isn’t turning off then you’ll have a drain. Try disconnecting such equipment and see if your problem goes away. If that’s not it connect an ammeter in series with the battery with the ignition OFF and start pulling fuses one by one until you find what’s causing the drain.
Hope this helps!
Jan 27, 2009 | 1988 Honda Accord 4 Door
Battery won t charge or operate phone Problem - T-Mobile MDA Compact Smartphone
Okay, I searched and searched until I found a solution that worked for me. I tried the USB thing, I got my phone to turn on once, but never to charge. Here's what I did:
(Do this at your own risk)
I zapped my battery with a 9v battery. One wire on each terminal and then held it to the MDA battery (positive to positive, negative to negative) for about three seconds. I did this about five times. (Don't let the wires touch while they are connected to the 9v battery.) I IMMEDIATELY plugged my phone into a wall charger, NOT my computer (The computer wouldn't charge my phone). As soon as it was connected to the wall charger, I turned it on. After starting up, the orange light came on, and it started charging. I was skeptical about this solution at first, but trying everything else I resolved to do this and then if it didn't work buy a new battery, but it worked and my MDA is charging as I'm typing. The original ideal came from a post on the xda-developers website by dew1989. I added the additional steps that got my battery charging again. I hope this helps!
Dec 04, 2007 | T-Mobile MDA Compact Smartphone
NiteRider Lumina 350 Bike Light Logo
155 people viewed this question
Top NiteRider Cycling Experts
John Egan
John Egan
Are you a NiteRider Cycling Expert? Answer questions, earn points and help others
