Question about Amana Dryers
Amana dryer ALE565SAW
How do you remove the top. idk how never had to work on one
    Novelist:
  • 150 Answers
A rigid puddy knife needs to be inserted approx 2-4" in from each corner where the top seam is across the front, while pressing and releasing the hidden spring clip lift the corner of the top and repeat for the other side.
Posted on Apr 17, 2014
How to take apart amana gas dryer
Some have 2 screws at the base you remove to gain access to the front. Others release from the top. Not all ASmana's are the same. Here is an Amana dryer service manual
Mar 29, 2013 | Amana Dryers
How do i remove a damage blower wheel on a amana dryer model # ndg2330aww?
Then remove the front. Take the control stat off.
You will remove the drum and then 2 screws hold the motor assembly to the floor
Lift out the whole thing and sit it on a work bench.
Remove the screws on the face of the blower housing and the blower unscrews lefty loosey
like this:
I have one of these dryer out back. I went and took some pics. Did the video for you
More here
Aug 24, 2011 | Amana Dryers
Acts like it wants to turn but it wont turn. Checked the belt. And its fine. If u turn the barrel manually it will sometimes start after..SO idk what the problem is. or how to even get the top of the dryer...
The belt is stretched out of its original shape. You will need to replace the belt along with the idler pulley. Sears has these parts in a kit form with instructions. The rear section were the top attaches to has a screw with a hinged metal peice which needs to be removed from each side of the back. Tiilt the top towards the front and pry up on the two front corners to remove the top. Then the front panel is removed undoing the sheet metal screws. The drum slides out and now you can access the belt and idler pulley. That a picture of it before removing the pulley with the belt on for reference
Apr 07, 2011 | Amana Dryers
How do i change the heating element on a Amana electric dryer is there a diagram or drawing also
you will need to take the front panel off, there are screws inside the dryer door, may be two on each bottom corner, and with a screwdriver gently pry up on the top corners as they are clipped in. Then you will have to unhook the door switch. remove the front panel you will need to look at the back top of dryer and make sure there are no screws that are holding the top down, lift up on top of the dryer and it will rest in the up position on the two brackets, the coil is located in the back right hind side an will look like a extended spring. You might want to remove the back upper plate of the dryer as there is usually a diagram in there, of course remember to unplug dryer before working on it. Hope this helps tim
Sep 02, 2010 | Amana DLE330RAW Electric Dryer
I HAVE A AMANA ELECTRIC DRYER , MODEL NDE7800AYW,
Start at the bottom. Remove lower panel then remove the door panel that will expose the 2 screws that secure the top.
Mar 04, 2010 | Dryers
My amana dryer took two cycles to dry cloths and now it just stopped working all together and makes a buzzing noise like it is stuck.
check the belt! also check the drum rear bushing after you remove the back and remove the top! then take the 2 inner front screws lose from the front cover and take the 2 bottom screws out and look to see if the drum/tub guides are worn out
Jan 22, 2010 | Amana DLE330RAW Electric Dryer
How do I replace bearings on the drum roller for the Amana electric dryer?
remove front cover then top cover remove belt around drum remove 3 or 4 screws inside drum that holds bearing onto drum, repl bearing and mount and reverse procedure
Sep 27, 2009 | Amana DLE330RAW Electric Dryer
How to install drum belt in Amana Model LED20AW.
HIya,
Cabinet Removal- Maytag & Amana Top Load Washing Machine
Remove the two (2) screws (item #21 on the attachment below) from the bottom of the front panel. Once the screws are removed, pull out on the bottom of the front panel until the spring clips release for the cabinet top.
Diagrams:
http://www.pcappliancerepair.com/model-display.php
Apr 07, 2009 | Amana DLE330RAW Electric Dryer
No heat coming from Amana Dryer
2 screws at the bottom of front panel if no screws there, then pry top off with wide flat screw driver then look inside toward top of front panel remove two more screws and the front should lift right out then remove screw/s in center of drum and lift out of cabinet there should be your heat element
Jan 17, 2009 | Amana NDE2335AY Electric Dryer
Installing dryer belt on amana LE2910W
Please view Amana dryer belt installation diagram amana.gif Diagram A
Style: Flat with ribs
Installation Tips: Ribs face toward drum
Disconnect dryer from the power source before servicing!
In assuming that you already have the front removed, you can raise the top by removing 2-5/16" screws located in each front corner that secure the top to the side panels. Then remove th 4-5/16" screws from the bulkhead that secures it to each side panel. Then use the diagram above on installing the belt properly.
Let me know if you need any more information.
May 28, 2008 | Amana Dryers
Dryers Logo
35 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
