Question about Whirlpool Duet GHW9150P Front Load Washer
Control panel locked
Control locked exibiting on control panel, whats solution? any body know?
Don
  • 89 Answers
On the control you will see a button and next to it there will be a little "padlock" press adn hold that button for 5 secs. it will beep and you will have access to the controls again.
Posted on Jun 18, 2009
Where is the body control module located in 2005 Lincoln las.
There is no BODY CONTROL module,but there is a Front Electronic module FEM, and a rear electronic module,REM (not the rock group,LOL!).
The FEM is located behind the driver's kick panel and the FEM is located on the right side down in the trunk.
The REM controls: Rear windows, , all rear lights, trunk opening, fuel door release, rear window defrost grid, trunk ajar switch, front passenger door lock, , front passenger door lock switch,rear door locks, trunk light, fuel pump, fuel level senders, antenna booster.
Hope this helps? don-ohio (:^)
Mar 17, 2017 | 2005 Lincoln LS
2006 GMC Envoy: I tested all of the fuses and all of them check out but my power locks, cabin lighting, dash panel lights, etc. aren't working.
Which fuse box ? Do you know what a DDM -is ? Driver door module . Do you have any idea what all is involved in making these thing's you have listed work ? A lot more then a fuse , there could be DTC'S - diagnostic trouble codes stored in the principal Control module ,the BCM , That could save a tech. valubale time in diagnoising this problem !
Door Lock System Components
The power door lock system consists of the following components:
• Driver Door Module (DDM)
• Passenger Door Module (PDM)
• Liftgate Module (LGM)
• Door lock relay
• Door unlock relay
• Body Control Module (BCM)
• Reversible door lock actuators in each of the doors
• LR/RR LOCKS 10A fuse (relay supply voltage)
• Door lock switches in driver and passenger doors (switches are integral components to the DDM and PDM)
Did you know there is a fuse box in the rear of the vehicle ?
Fuse Block - Rear
Beneath the left rear seat
The inside lights are also controlled by the BCM , and the fuse's are also located in the rear fuse box .
The body control module (BCM) directly sends a 5-volt reference voltage to the instrument panel (I/P) dimmer switch which is then adjusted based on the I/P dimmer switch position and returned as a low reference and a signal to the BCM. The BCM uses this signal to directly control the desired level of instrument panel illumination lamp intensity.
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC B2620 Display Dimming Pulse Width Modulation (PWM) Input Circuit. There are several DTC'S that can set !
DTC B3801 Passenger Compartment Lamp Request Circuit
DTC B2610 Passenger Compartment Dimming 1 Circuit plus others for power locks .
Thank You Uncle Sam
Nov 29, 2016 | 2006 GMC Envoy
2008 Chevy Impala LTZ: car wont lock or unlock with the power lock/unlock buttons on the remote or car door. It makes a clicking sound though when I attempt to. Is this a blown fuse? Or something else
Where do you here the clicking sound ? in the door , behind instrument panel ? I don't think a blown fuse would do this , possibly a relay ! do you know what a relay is ? This is Chevy factory service information !
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
There are three pcb relays integrated into the instrument panel fuse box ( non replaceable ) door unlock pcb relay drivers door -door unlock pcb relay an door lock pcb relay ! The BCM controls these relays ! Do you know what a BCM is ?
Circuit/System Description
The DR/LCK fuse supplies battery positive voltage to the I/P fuse block for the door lock system. The body control module (BCM) supplies and monitors a reference voltage to the door lock switch through the door lock switch lock/unlock signal circuit. The door lock switch also receives a constant ground source. If a door lock switch is placed in the lock position or unlock position, the reference voltage is taken directly to ground and the BCM detects the voltage drop on the signal circuit.
The BCM, upon receipt of a door lock switch lock or unlock signal, will switch the appropriate door lock actuator control circuits to battery positive voltage. The opposing side of the door lock actuators are connected to ground internally within the BCM through the other door lock actuator control circuit and the doors will lock or unlock appropriately.
With out have a factory GM tech 2 scan tool ,It would be best if you took this to a Chevy dealer . The first part of diagnosing this problem is to hook up a scan tool !
Wiht
There
How to test computer controlled door locks
Aug 25, 2015 | Cars & Trucks
Where is the fuse located for the front ac blower and what would cause my front passenger door controls to quit working my window or lock don't work not even from when you try from drivers side
in the fuse panel under the dash on the drivers side. it could also be in the fuse/relay panel under the hood. you don`t give the year make model of this car, so it makes it harder to let you know where it could be. the window/door lock could be a fuse or the wiring between the body of the car and the door where it opens and closes could be broken and needs repair.
Aug 21, 2015 | AC Cars & Trucks
Locked out front control panel while in menu. Now I can't unlock front control panel and I don't have original remote control or owners Manual. Help me please. The front panel is all I use for DVD pla
Hi there, if you know what model it is you can do a google search for the owners manual. There should be a sequence of buttons you can push or hold to reset to factory/default settings.
Jan 25, 2013 | Televison & Video
Whirlpool duet dryer control lock light is on. How do you reset it?
the control panel on the right side is a button that says hold for three seconds to lock. Look closely it's in small lettering. I don't know what model you have, so if you can't find the button please send the model number. If you need further assistance let me know
Oct 13, 2012 | Washing Machines
Where is BCM located on 2002 PT Cruiser locks working even when car is not on have been told to check BCM don't know where to find it
I don't find a body control module for your car, but according to the wiring diagram the door locks are controlled by a keyless entry module which is located on top of the dash behind the ac vents.
There are three fuses that power the module.
Check with your dealer for more details.
Aug 20, 2012 | 2002 Chrysler PT Cruiser
Central locking goes on and off whilst driving
Check your master switch on the door panel. If all doors are doing it, the master lock swith is suspect. Don't know if your car has a body control module, or if it has anything to do with the locks. good luck.
Oct 27, 2011 | 1997 Plymouth Grand Voyager
Doors wont lock. Windows won't work. Car thinks the door is locked because when I open the hood alarm goes off. Security light is flashing when doors are closed. Locks don't engage when driving...
Window fuse's and relay's may be up under driver or passenger side dash or behind glove box, under the hood and even under the seats, and finally on the ends of the dash. All passenger power windows and locks are controlled thru and get power from the master control switch on the drivers door. Could be a broken wire in the rubber boot going from the door to the body. You will have to eliminate each till you find the culprit. Check that all switches return to neutral when released. It could also be the body control module.
Aug 28, 2011 | 2003 Volkswagen Jetta TDI
Whirlpool Duet GHW9150P Front Load Washer Logo
167 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
