WIRING A TH-9520B
Programmable Thermostat (2-wire) but lost wiring diagram. thermostat has a five block connect numbered 1-5 of which 1, 3, 5 are used .....Connecting to a new ideal logic 30+ combi boiler.
  • 8 Answers
SOURCE: Wiring Hunter Thermostat to 6 wire Carrier fa4bnf036
you probably purchased a 4 wire thermostat which we call heat/cool you stated you have 6 wires which signifies a heat pump you have to purcahase a heat pump thermostat and then write down the color of the wires to there related spots example...yellowe-y red-r white- w and so forth also before you do this kill the power the voltage typical for residential is only 24v's but if the wires touch you could blow a fuse
Posted on Dec 15, 2008
machtcl1
  • 61 Answers
SOURCE: Thermostat Wiring: W2? E? Where to connect?
You have a heat pump. You need a thermostat for "Heat pump with Electric back-up heat". Make sure the 'stat has either an "aux" (auxilliary heat) or an "E"(Emergency heat) terminal. The wiring instructions will be provided with the thermostat.
Posted on Dec 16, 2008
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
  • 19 Answers
SOURCE: need a wiring diagram for thermostat/hunter model44260
Hello please try this link and see if this contains the information that you need
Reply to bsix@hotmail one way or the other Thanks
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/42711.pdf
Posted on Sep 14, 2009
SOURCE: WIRING DIAGRAM LOST FOR NON-PROGRAMMABLE CT87
Red is power return to turn on heat
White is common power to both heat and cold
Blue is power return to turn on AC
You can get specific guidance on wiring at the Honeywell Website.
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0274.pdf
Posted on Aug 30, 2010
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
Unable to get ac compressor to start
HI,
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
Goodluck,
Please don't forget to rate the solution
Apr 23, 2008 | Hunter Fan Company 5/1/1 Programmable...
How can I connect to replace an old Electromode thermostat that has 2 black and 2 white wires?
The packaging for the most recent Honeywell thermostat I installed has a "Consumer Helpline" telephone number of 1-800-468-1502. You also might try a Google search using the model number.
Mar 14, 2016 | Honeywell Programmable Thermostat Heater
Installed a rth6350 now no power
The RTH6350 is a battery-powered thermostat. Did you correctly install the AA batteries? Press down and pull the battery holder away from the thermostat on the right hand side. Try new batteries. Did you remember to secure the C wire with a wire nut and push it back into the wall. It should not be connected to the thermostat.
If you connected the C wire, you may have damaged the thermostat by providing too much current. Honeywell has the documentation for the RTH6350 on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH6350D.htm . The installation guide is here: https://customer.honeywell.com/request.cfm?form=69-2416ES . See page 23 and subsequent pages for the wiring diagrams.
I hope this helps.
Oct 11, 2014 | Honeywell RTH6350 5-2 Programmable...
Replacing double pole 220 v with honewell ct410a two wire120/140v wiring diagram not clear
1 power wire (120v) will go to the thermostat and 1 power wire (120v) will go directly to the unit. The other wire on the unit will go to the other side of the thermostat. The safety precaution behind using a single pole to replace a double pole contactor is that you will always have 1 leg of power going to the unit. Many systems are designed like this from the factory, but it is always better to have a 2 pole to cut all power off to the unit unless it's in operation. The unit will still not work as long as it does not have both legs of power.
L1 to Thermostat T1 to Unit
L2 and T2 wired together.
This is only for 240v systems. 120v Will have 1 common and 1 power, therefore you will need to know which wire is which. Power to thermostat, common wired direct.
Nov 26, 2013 | Honeywell Programmable Thermostat Heater
I just purchased a house with brand new furnace wired to a RTH2300 Honeywell thermostat. It only has two wires running to it. I can't seem to get it to work in "manual mode"-where I set it on...
?? Connect Wires 5.
Labels don't match?
If a wire does not match any terminal on the thermostat,
see next page.
Quick Installation Guide
6
Alternate Wiring
If a labeled wire does not match any terminal
designation, see diagram below.
Do not use C, C1 or X wire. Do not use B wire if you already
have O wire. Wrap bare end of wire with electrical tape.
This thermostat cannot be used if your old thermostat had
any two of the following wires: R, RC, RH, 4 and V.
Place a jumper (piece of wire) between Y and W if you have
a heat pump without auxiliary/back-up heat.
?? Connect Wires (cont'd)
Programmable Thermostat RTH2300
7
Set jumper JP1, on the back of the thermostat, if you
have connected a wire to the G terminal.
Incorrect jumper setting: An incorrect setting is
noticeable in a gas or oil heating system. When heating
starts, you will initially feel cold air coming out of the vents
as the fan is running before the furnace has enough time
to heat up the air.
?? Set Heating Fan Control 6.
HG Leave the jumper in this factory-set
position if you have a gas or oil furnace.
HE Place the jumper to this position if you
have an electric furnace.
JP1
8
Set jumper JP2, on the back of the thermostat, if you
have a heat pump.
Incorrect jumper setting: The heat pump operation
will be reversed, i.e., it will cool in Heat mode and will
heat in Cool mode.
?? Set Heat Pump Reversing Valve 7.
O Leave the jumper in this factory-set
position if you have connected O wire to
the O/B terminal.
B Place the jumper to this position if you
have connected B wire to the O/B terminal.
JP2
9
1) Install 2 AAA
batteries on the
back of the
thermostat.
2) Align the two
brackets on the
top of the
thermostat with
the corresponding
slots on the top of
the wallplate.
3) Push the
thermostat
against the
wallplate.
4) Tighten the screw
at the bottom of
the thermostat.
5) Turn power back
on at the heating/
cooling system.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
Need a wiring diagram for thermostat/hunter model44260
Sep 04, 2009 | Hunter Fan Company 5/1/1 Programmable...
Rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
Dec 28, 2008 | Honeywell Electronic Programmable...
Wiring a programmable thermostat for baseboard heater
The red and black is power and neutral. Green is just for the ground and that should tie into the ground wire for breaker or power wire .
The 2 black wire from thermostat should tie into the two red and black wire from your heater.
Just imagine you are wiring 1 heater to thermostat and just add the the next heater the same way
May 15, 2017 | Honeywell Programmable Thermostat Heater
Hunter fan programmable thermostat
Need more information about tstat model number what type of a/c and heater do you have..heat pump, gas furnace, electric heat. Also what wires are connected to the tstat and to what position on the tstat. I have included a link to hunter's user manual page for tstats. The wiring diagrams are there just enter your model number and click submit. Good luck Kevin
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
Dec 29, 2007 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
282 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
