Question about Sanyo DP42746 42 in. Plasma Television
Where is located the fuse in a tv sanyo model No. DP42740
    President:
  • Sanyo Master
  • 749 Answers
There are several fuses on the power supply board.
The main one is right next to where the cable from the AC connector is on the power supply.
BTW you may want to check these listings too:
http://www.coppelltvrepair.com/search?q=DP42740
(although if you are looking for a fuse that probably means totally dead TV and if that;s the case then you do not need a main board repair)
Posted on Apr 18, 2014
  • 222 Answers
SOURCE: Is there a fuse for Sanyo tv model dp32648?
try partstore.com
Posted on Jun 06, 2010
taran_2005
  • 10515 Answers
SOURCE: Sanyo DP42740 tv turns off and on by itselfl It
Unplug the TV for few minutes, say 30 minutes and then turn it ON. If it still does not work,it confirms an internal failure. The main cause on this model is ' power supply board '. Other than this, even the faulty boards could cause the same problem. The TV has to be opened, carefully inspected and then the part has to be replaced. If you have electronics repair experience, could read schematics, would be able to use multimeter and could keep all precautions, revert and i could tell you where you could buy a cost effective service manual and would provide you few pointers that would help you to fix this problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 02, 2010
SOURCE: Sanyo model dp42740. Audio speeds up, if I change
Sounds like you have a bad digital reception from the aerial. You'll either need to adjust or replace the aerial, make sure all lines are connected at the aerial point, and it's advisable to invest in a signal booster.
Posted on Dec 03, 2010
  • 375 Answers
SOURCE: How do we hook up
Hi Amy,
I cant see any specific connections for your tv but the end of the cable from your wii will have either a 21 pin sc"scart" connection or 3 plugs,(red, white and yellow) Look about on the back of the tv for corresponding socket. There should only be a couple of choices for each. Then simply plug it in. There will be no tuning or anything to do as these are direct connections. On your tv remote look for a button which will display or select the direct inputs. May look like a small screen shape with an arrow pointing into it, or may say "ext" or similar.
Hope this has been helpful
Posted on May 07, 2011
SOURCE: fuse location for a 50" sanyo tv
The fuse should be located on the power supply board. You'll have to remove the back cover to access it. I posted a link of what the board should look like.
http://www.shopjimmy.com/vizio-aax30284301-power-supply.htm
Posted on Sep 24, 2011
How can i program this remote to a sanyo tv remote is a sharp GA447SA
You can't. Each make is proprietary to its own make and they are not programmable.
Google
Sanyo <model> replacement remote
You will find replacements for that particular set on eBay, Amazon and specialist remote outlets.
Sanyo OEM & Replacement Remotes - Remotes.com‎
Adwww.remotes.com/‎+1 800-736-6837 Buy Any Replacement Remote Control! Order Online or Call 1-800-Remotes
Brands: Samsung, Panasonic, Philips, Toshiba, Magnavox, Yamaha, Sharp, RCA, JVC, Pioneer
Search Results
SANYO TV Remote Controls ' SANYO Replacement Remotes for TV ...
https://www.replacementremotes.com/SANYO/Remote-Controls/ ReplacementRemotes.com offers SANYO remote controls for sale online including remote controls for TV, Projector, VCR and many more.
Amazon.com: Sanyo - Remote Controls / Remote Controls ...
https://www.amazon.com/Remote-Controls-Sanyo.../s?ie=UTF8...1...4%3ASanyo Results 1 - 24 of 146 - Factory Original SANYO RC200NS00 LCD / LED HD TV Remote Control For Sanyo HDTV Television (8TL06-530W37/ 8TL06530W37). by Sanyo .... Generic Replacement Sanyo LCD Hdtv Tv Remote Control Gxbc Gxab Gxbj Gxbd Ht32546 Dp50747 Dp26649 Dp42746 All Sanyo Led Lcd Plasma Tv.
Amazon.com: Remote Control Replacement For Sanyo DP42841 ...
https://www.amazon.com/Remote-Control-Replacement-DP42841.../B00J7S2P7W Rating: 4.1 - ‎8 reviews
Factory Original SANYO RC200NS00 LCD / LED HD TV Remote Control For Sanyo HDTV Television.... ... Sanyo LCD Plasma HDTV TV Remote Control GXBM Supplied with models: DP32640 DP42740.... ... TV Replacement Remote Control For VIZIO VW32L VW42LHDTV10A E420-A0 LCD LED PLASMA....
SANYO TV Remote Controls ' eBay
https://www.ebay.com > ... > SANYO TV Remote Controls Results 1 - 48 of 104356 - Replacement Remote Control for ROKU 1/ 2/ 3/ 4 LT HD XD XS Streaming Player with 4 Shortcut Buttons (Do NOT Support Roku Streaming Stick, Hdmi Stick, Roku TV and Game). - ROKU 3 (Note, this remote DOES NOT have a headphone jack or pair button but it works like a charm with ROKU 3).
Universal Replacement Remote Control Fit For Sanyo DS13530 ...
https://www.amazon.ca/Universal-Replacement-Control-DS13530.../B00MGHAPRS Universal Replacement Remote Control Fit For Sanyo DS13530 DS13630 DS19650 DS19730 DS20380 LCD LED PLASMA HDTV TV: Amazon.ca: Electronics.
Universal Replacement Remote Control Fit For Sanyo GXCF ...
https://www.amazon.ca/Universal-Replacement-Control-DP19640.../B00HH5SFQM Universal Replacement Remote Control Fit For Sanyo GXCF DP19640 GXCC DP26649 LCD LED Plasma HDTV TV: Amazon.ca: Electronics.
Sanyo Remote Controls - Walmart
https://www.walmart.com/c/brand/sanyo-remote-controls Original Sanyo GXBA / 6450750984 Remote Control TV Television Projector DVD. This product is compatible with the following model numbers: GXBA, 6450750984, DS24425, DS24425, DS27225, DS27225, DS27425, DS27425, DS32225, DS32225. This product comes with a warranty of 1 Year. Product - Original Sanyo ...
Sanyo TV Remote Control New OEM Replacement Remotes
www.sanyo.newremotecontrol.com/SanyoTV.php Model Number, Remote ID Number, Remote Part Number. AVL-191, RC-Q32M-0A, XI6010Q03201. AVL-193, RC-Q32M-0A, XI6010Q03201. AVL-209, RC-Q32M-0A, XI6010Q03201. AVL-408, RC-U46R-0A, 301-UP42K8-46RA. AVL-428, RC-U46R-0A, 301-UP42K8-46RA. AVM-1304, FXBA, 6450001291. AVM-1904 ...
Apr 03, 2018 | Sharp Televison & Video
SANYO DP42740 DIGITAL CONTROL BOARD , can it stop the tv from powering up .
Yes. If it has shorted component/s. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 21, 2015 | Sanyo Televison & Video
What is the usb for on the sanyo DP42740
USB port is located on the back of unit next to the Antenna input. See page 6 of: http://us.sanyo.com/dynamic/product/Downloads/DP42740%20(355--)-25942323.pdf
Nov 27, 2013 | LG 42PX5D 42 in. Plasma HDTV
Sanyo plasma tv vs power surge
Oh dear, the line out section has got hit and this might require attention by a qualified service technician.
Jul 13, 2012 | Televison & Video
Is there a manual to explain the sanyo dp42740 remote?
Yes. You can get the tv manual from;
http://us.sanyo.com/Plasma-Televisions/42-Class-41-6-Diagonal-720p-Plasma
Click on the Download tab then click on the manual icon. The remote control operations are explained.
The manual is in PDF format so you will need ADOBE reader to read it. Most people have ADOBE
but if not you can download the reader from www.getadobe.com.
Apr 14, 2011 | Televison & Video
Sanyo DP42746 42 in. Plasma Television Logo
232 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
