Question about Panasonic SC-HTB65 Home Cinema Sound Bar Home Cinema Sound Bar 2.1 90W Total Power Black
Sound bars I cannot connect to tv as I have no digital audio cable sockets
  • Pete Anslow
    Pete Anslow Apr 25, 2014
    That did it thanks
  • 32 Answers
It has red and white RCA jacks you should be able to use as the input from your tv. Plug into audio out on tv.
Posted on Apr 14, 2014
  • Pete Anslow
    thanks DOLF that did it.
4 Suggested Answers
SOURCE: can't get sound from tv to the home theater system
I was having the same problem. I just figured it out. You have to set the audio input on the receiver to D-IN instead of AUX. On your Panasonic DVD remote, push the "SETUP" button until you see "TV AUDIO" on the front of the player. Then push the down arrow. You will either see AUX or D-IN. You can't toggle between the two. If you see AUX, you need to push setup again and then push the down arrow again and you should see D-IN. You should hear TV audio at that point. I don't think they could have been any less vague about this in the instruction manual. Hope this helps.
Posted on Sep 07, 2008
  • 118 Answers
SOURCE: Connect Bose System to Panansonic TV
in the tv setup menu there should be an item that will allow you to change the volume from variable to fixed on the output of the tv
Posted on Dec 08, 2009
  • 176 Answers
SOURCE: Just got Panasonic Home Theater
What kind of TV do you have?
I have found one of the easiest ways to connect surround system is to connect all your accessories (ie. Wii, Cable Box, VCR, etc) to the TV.
Next find the AUDIO OUT on the TV and connect this to the TV or AUX input on the home theater.
Tune the Home theater to the Input that you connected the TV to. This should play the audio through the home theater for any input you tune the TV to.
Note: make sure to turn the TV volume all the way down otherwise there will be some distortion due to the delay between the TV and the home theater.
Good Luck,
Robert
Posted on Feb 26, 2011
Can't hook up my sb 2920x-c6 to my auria eq 5888 tv where audio out jack
can't find that eq 5888 model number but does the tv have a connection labelled as spdif this is a special digital audio out standard by phillips.
http://www.hardwaresecrets.com/everything-you-need-to-know-about-the-spdif-connection/2/
I am not sure if this can be plugged into the sb 2920x-c6 digital in socket or if you need a digital amplifier between the two items ?
Someone else on fixya may know if a digital amplifier is needed or a direct connection from tv to sound bar is possible via a spdif cable.
Nov 27, 2015 | Audio Players & Recorders
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
How to connect my tv to optical outlet
What audio-outputs does your TV have? SPDIF? 3.5 millimeter stereo-jack? White/Red RCA "post-and-collar" sockets?
What inputs does the sound bar have? (Same choices as above.)
Note that you might need a 3.5mm to stereo-RCA cable.
Feb 09, 2015 | Televison & Video
I have a proscan with no sound so I brought a
You hooked up the sound bar to the cable box red & white sockets, right. Now you have the soundbar hooked up to the TV red and white sockets. Did you notice any difference with the labeling on the two sets of sockets? The cable box sockets were labeled "Audio Out", but the TV sockets are labeled "Audio In"
AV signals are directional. Any socket labeled "Out" will give a signal from it for connecting to another device e.g. the connection from the cable box to the soundbar.
Any socket labeled "In" is designed to accept a signal from something else, but it won't give a signal out. So you can't connect the TV's Audio In socket to the soundbar's Audio In socket because both expect a signal from something else and neither supply a signal out.
Check the back of the Proscan TV. Is there a socket labeled Audio Out? If so, use that.
Sep 03, 2014 | Televison & Video
How can I connect a sound bar?
Buy a digital optical cable and plug it in the audio output of the TV and into the audio input on the sound bar. If there is no digital input you can run it with a RCA cable (3 cable red, white, yellow) or just simply an HDMI cable.
SONY eSupport How to connect TV Sound Bar system to television
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Feb 15, 2013 | LG 42CS560 42 Class LCD HDTV
Audio out locations on back of tv
Hello
You want to connect your TV with an external audio device, and want to hear sound from it, I assuses, and posts this solution.
There is audio out sockets at the back side of the TV, very near to S-Video socket. Marked audio "L" & "R". These two sockets are audio out socketsfrom TV to connect any external audio amp. Just use an audio cable to connect these sockets, to 'Audio IN' of the amp socket. Switch ON both the devices. You can hear the audio of your TV programmes by the amp you conneccted with.
The picture of the AV cable is given here. Take red and White colourd connections to connect the TV with amp. Left the Yello coloured pins free. It is meant for video. 2_11_2012_3_19_43_pm.jpg
Feb 11, 2012 | Element Electronics FLX3210 32 in. LCD TV
How do I connect my Panasonic SC-HTB500 sound bsr to my Panasonic TH-42PX75U television with an HDMI cable?
If you have a set top box (blu-ray, dvd, cable) with HDMI Out, then you need a pair of HDMI cables. Connect one from the HDMI Out of the set top box to the HDMI In of the sound bar. Then connect the HDMI Out of the sound bar to the HDMI In of the TV.
If you only want to use the sound bar as an external speaker system for the TV, then you should get a digital audio cable (fiber optic cable). Connect this to the Digital Audio Out on the TV (below HDMI ports) and to the Digital Audio In of the sound bar.
I hope this helps. You can find the manual of the TV here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-TVs/model.TH-42PX75U . The TV also has analog (RCA) audio out jacks labeled Prog Out on the bottom left of the connection panel; the sound bar however doesn't have RCA audio in jacks.
(since there are no HDMI out jacks on the TV, there is no other way to connect the sound bar.)
Dec 26, 2010 | Panasonic Televison & Video
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
Panasonic SC-HTB65 Home Cinema Sound Bar Home Cinema Sound Bar 2.1 90W Total Power Black Logo
381 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
