Question about Grundfos Pumps Grundfos MQ 3-45 1 HP Pressure Boosting Pump
No water pump makes a noise quieter noise than normal and no water is coming from taps or shower also red light comes on sounds like it wants to work but nothing is happening please help
    Problem Solver:
  • 11 Answers
Does the motor turn it self off after a couple of minutes of no pumping?= ran out of water. If there is water up to the pump and still no water, check filter/s ( if there is any). Undo V band and check pump internals, impeller may be broken from shaft? When putting back together tap V band with block off wood or back of screw driver evenly as you do up the clamp to stop it distorting
Posted on Apr 14, 2014
Hi,After my wife had a shower the pressure in the pipes seem to drop heavy.Not just in the shower but the whole house's.Cold water comes out like a dream but dont know if it can be the pressure valve.
That sounds like a supply problem if it affects all taps (faucets). With no water running in the house, take a screw driver and put the blade on an uncovered supply pipe, put the other end to your ear and listen for a shushing noise. If you can hear it, you have a leak in the supply outside. Call the water supply utility. If there is NO noise, contact them and ask if they are throttling supply for the summer.
Jun 30, 2015 | Home
Fisher Paykel washer repair
it will be the pump. just check again where you did last time. there may be something in the hose, coins can get stuck, and lint. check also the pump is not getting very hot.
Aug 08, 2014 | Fisher and Paykel WA37T26G Top Load Washer
There is a high pitched sound coming from under my 2002 Jimmy. It seems to be originating in the vicinity of the fuel tank, catalytic converter, differential area. But I cannot isolate it. Possibles?
Fuel pump in the tank makes a high pitch sound which is normal. Turn your key in the ignition, but don't start, you should hear the high pitch sound with the pump priming the system. You will still hear it when started, it's annoying but normal. Different brands are quieter than other, I just replaced mine with a Delphi brand fuel pump which is a tad quieter than AC Delco stock pump.
Mar 16, 2014 | GMC Jimmy Cars & Trucks
Overheat light won't turn off, strange boiling sound.
it may have calcium build up in the valving.. may need to run some chemical thru it..
Jan 25, 2014 | Home
I have a triton t90 shower it was workin grand until 2day when i was fillin my daughter paddling pool wit the tap in the garden that is connected to the hot water and it must of empty the tank as there was...
As per my view, you should immediately contact to a professional who can fix this shower problem very easily and quickly. You can also explore latest shower enclosures that are available at reasonable price.
May 26, 2012 | Home
Last week my electric power went off for about one hour, in my kitchen I heard water rushing out my drains. when the lights came on I had no water.The well man came and said he had to turn my pressure...
It sounds like the bladder in your pressure tank is water logged. Turn your pump off and open a tap and let the pressure off. Once the water has completely stopped coming out of the tap go to your pressure tank and pump air into it. There should be more water come out of the tap. Continue to pump are in until you reach the pressure recommended for your tank and there is no longer water coming out of the tap. Close the water tap and turn the pump back on and this should fix the problem. If it does not you will probably need a new pressure tank. The bigger the pressure tank you have also will make the pump work less. I prefer a smaller one myself as there is less change in the shower pressure when the pump cycles than with a bigger tank but this is just a matter of prefference. Some people prefer a larger tank as it uses less power by the pump not working as often.
Mar 15, 2011 | Plumbing
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Water dispenser light flashing and no water at first
sounds like you've got power problems -- either there's an wiring issue somewhere or you've got a bad board
Dec 13, 2007 | Hotpoint HSS25GFP Side by Side...
Grundfos Pumps Grundfos MQ 3-45 1 HP Pressure Boosting Pump Logo
181 people viewed this question
Top Grundfos Pumps Plumbing Experts
Boyet Soriano
Boyet Soriano
Matthew Ward
Level 1 Expert
Gil Shultz
Are you a Grundfos Pumps Plumbing Expert? Answer questions, earn points and help others
