Question about Kia 2002 Sedona EX
Door alarm chime wont go off
Door alarm chime will not stop going off with the exception when the car is at a standstill. Where is the fuse and how can I make it stop?
    Sergeant:
  • 249 Answers
Sounds like a fault with the door switch and a short circuit. Find out if Haynes make a manual for your car or look up videos on youtube. It may be a case of giving the switch a good clean or reattaching a wire that is touching the metal in the door or the door post.
Posted on Apr 14, 2014
Stop the annoying door chime on a 1997 Mitsubishi diamante
take the annoying door chime module out , its right there in the fuse box (use your hearing to zero in on it), but ill warn you now then you wont anylonger have the annoying chime you left your lights on and your battery will be dead .
Feb 29, 2016 | 1997 Mitsubishi Diamante
How do you disable the door chime?
many drivers have dash lights to inform them that a door is open yet they still drive around and then complain about a knock some where in the back
I would check all the door sensors for adjustment and leave the alarm alone as , as annoying as it might be , it might let you know when a child has opened a door without your knowledge and save a life.
Mar 25, 2015 | 2009 Toyota Camry XLE V6
Location of tail gate alarm on 2004 Chrysler Pacifica
you may have a bad switch which is located on the latch asm
Sep 03, 2012 | 2004 Chrysler Pacifica
Does the bcm control the alarm in a 2006 monte Carlo? I can't seem to get the alarm to go off. I've also noticed that I have no chime and turn signal sounds. I just recently purchased this car and...
The no chime and turn signal has nothing to do with the alarm. You have a issue with power supply to turn flasher and door chime. The alarm consist of The door ajar switch,body control module,front door lock switch,power door lock switch. You need to check your fuse for turn signal and the door chime
Feb 22, 2012 | 2006 Chevrolet Monte Carlo
How do I go about disabeling the alarm/chime in my 2005 Saturn relay. This chime goes off constantly even while I am driving. It originally started with a chime telling me that the rear door was open when...
The problem is likely a bad switch in said door. If you can't fix it now, crawl under the dash, find the chime (should be easy..ding..ding), and unplug it. Please rate me. Thanks
Sep 03, 2011 | Saturn Relay Cars & Trucks
Ford Windstar alarm and door ajar issues.
We are having the same problem and looking for a solution. My husband is in the garage right this minute pulling things apart :0). Tried searching YouTube, but no luck. HELP!
Jun 03, 2010 | 1998 Ford Windstar
I need the layout for 1992 saturn fuse box the door alarm wont stop ringing
There is a chime module behind the fuse box on the passenger side. The best way to access it is from the drivers side. Remove the drivers side panel that is located at the front of the center console near the drivers right leg. You can see the back of the fuse box and there will be a small green or orange box. That is the chime module. Some are brown. When I worked at the Saturn dealer, we usually would replace the chime module and that fixed the problem. Customer who did not want to pay for them just asked us to remove it.
May 29, 2010 | 1992 Saturn SL
My door chime wont stop ringing when the driver side door is open and the keys are out of the ignition. how can i fix this?
I just found out that the problem on our 1998 windstar was the chime switch attached to the ignition switch. This chime switch when dislodged will short and act as if the keys are still on when the door is open ( thus sounding off the alarm). I had a hunch that the problem was close to the steering wheel because the alarm would stop if I change the angle of the steering wheel a couple of notches up or down. I guess when i did that the chime switch that i'm pertaining to get reset to the right position and stops the alarm. when i opened up the steering wheel housing around the ignition , the chime switch fell, it had a blk wire I think, and I saw that the clips on it were kind of melted thus not sticking to its right position. I just had to remove the ignition switch for a while and replaced the chime switch with the help of a zip tie wrapped around it. then I placed every part back together and no chimes... also I did this all while the battery was disconnected because i needed the ignition switch to be in the on position to get it off the steering wheel. Good luck guys!
Apr 30, 2010 | 1992 Honda Civic
Door chime wont stop
thgis problem is caused by one or more defective door ajar/courtesy light switches or sliding door contacts, since these switches are very hard to replace as they are located inside the doors on the door latch the best thing to do is have the dealer hook up a body module scanner, it can ID the faulty switch, then i f wish u can change it to save money, the switches are about $15 each, there are 5 of them
Dec 21, 2009 | 1998 Ford Windstar
Kia 2002 Sedona EX Logo
42 people viewed this question
Top Kia Heating & Cooling Experts
Mike Squire
terry stevens
Andrew Taylor
Andrew Taylor
Are you a Kia Heating and Cooling Expert? Answer questions, earn points and help others
