Question about Karcher 2500 PSI Pressure Washer
Hard kickback from pull cord
Didn t get an answer
How do I cure kickback when starting a Stihl 044 chain saw , as soon as you pull the starter cord it snatches it out of your hand it really hurts.
pull rope just pass compression piston top dead center release rope let it rewind fully .then pull rope quick and firm.
Oct 10, 2017 | Stihl Garden
Where is the fuse located
I would be surprised if there is a fuse in the circuit. I have never seen one on a chain saw.
Feb 08, 2015 | Remington M30016aw Electric Chain Saw Yard...
Honda gx340
Valves need to adjusted with a feeler gauge (6 and 8). Allows no kickback during start. Check air filter if still running rich. Hold filter away from housing, if it pulls it in most likely clogged. Hope it helps
Sep 09, 2013 | Electrical Supplies
I have a Rockford fosgate P4004 with two 12'
I think you are right about the "fried" part. It would have to be opened up and repaired to be able to use it again
Oct 29, 2012 | Car Audio & Video
How can I avoid kickbacks?
You can avoid kickback by purchasing the new E-drive Aircraft Starter which is completely immune to kickbacks and has a two year warranty.
Sep 10, 2012 | Champion Sport & Outdoor - Others
I am getting very bad kickback about 3/4 the way through my cuts. I have a new blade on the saw. I dont really know how to troubleshoot this.
Possible that the fence you are using is not on a true parallel line with the blade and as a result it is causing the wood to pull into the blade causing kickback. I would do an alignment procedure on the fence to make it as true to the blade as possible.
Sep 11, 2010 | Dewalt DW744S 10" Portable Table Saw with...
It starts up, but when trigger is pulled, the
Most saws have a safety or anti kickback brake. Yours might have tripped. There is a guard in front of where your left hand holds the saw. With the saw NOT running, pull the guard HARD towards the back of the saw. It should move a bit ant you may hear a click. The chain should now move. If the chain moves easily when the saw is not running, but doesn't move when you rev the saw up, the clutch is broken.
Sep 10, 2009 | Garden
I have a Toro GT 5 6.5 hp Tecumseh model #Lev 120 and it just quit. Checked everything. Good fire,turns over good but have a kickback while it's cranking. Everything else is working. Is there a wire...
Sounds like the blade hit something solid when it was running & then it had problems soon thereafter. It may have sheared the flywheel key & is not firing at about 7 degrees before (TDC) top dead center. Pull out the plug & put your thumb tightly over the spark plug hole to feel for compression as you slowly rotate the blade or pull on the starter cord. About 7 degrees before TDC is when you should get a spark. Maybe you can download a repair manual for it or have a friendly repair shop tell you when it is supposed to fire the plug.You may have to pull off the shroud over the pull cord/flywheel to see where the magnets are at TDC. I had this happen to my Lawn Boy after my grand son used the mower. A $3.00 new key solved the problem BUT it was a pain to take the top covers off. apart
May 09, 2009 | Garden
Karcher 2500 PSI Pressure Washer Logo
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
