Question about Yamaha HTR-5790 Receiver
I have a HTR 5760 reciver, it was in storage for 3 years i pluged it in with no spearkers hooked up and when i try to turn it on with remote or buy pressing the on off button it turns on makes a poping noise then turns off right away hjow can i fix this thank you Hawk
  • hawk selcuk
    hawk selcuk Apr 14, 2014
    Thank you Scott i will try it.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Try hooking up the Spkrs sometimes if there is no load the override will shut the unit down so things don't blow.
Posted on Apr 14, 2014
  • 336 Answers
SOURCE: turns on then off.
It probably needs a set of output transistors, 2 pre-amp transistors and a 5.6v zener diode. Possibly a resistor or two. I've fixed many of these. Definitely a job for a pro.
John W
Posted on Jan 10, 2009
  • 236 Answers
SOURCE: HTR-5550 will not stay on.
jerry ...
question??? before you stored the unit, was it working fine?
are you using the same sets of speakers like before?
Posted on Mar 19, 2008
SOURCE: front left and right speakers don't put out sound
Hit the button  "speakers/a/b/off" on the left hand side of the front panel until it shows that "speakers b"  are turned on.
Posted on Jan 18, 2009
  • 3 Answers
SOURCE: what's NEC PF68S33 TV's remote control code for YAMAHA HTR-6130
I had similar problem when setting up the YAMAHA remote control for my NEC LCD TV. At the end I found I did not follow the YAMAHA manual properly. Did you hold down the DTV/CBL button, and AT THE SAME TIME press the AV POWER for 3+ seconds? You should be able to "REMOTE SETUP OK" displayed in the front panel of the YAMAHA AV receiver. Hope this helps. BTW, only the TV POWER, TV MUTE and the numeric buttons work in my case.
Posted on Feb 16, 2009
  • 5 Answers
SOURCE: Sir we are try to find the right code for working
If you can find codes for Marantz receivers they might work. Yamaha makes Marantz like Pioneer to Premier & Onkyo to Integra.
Posted on Jun 23, 2009
I have a yamaha htr 5890. I would like to hook up
You are probably connected to the pre-out jacks. These are not amplified. Connect them to the B speaker outputs(screw down connectors). If that won't work (and it should), you can connect to the "Presence" speaker connections(spring loaded connections).
Feb 02, 2010 | Yamaha HTR-5890 Receiver
No power
open and replace the fuse
Sep 09, 2009 | Yamaha HTR-5760 Receiver
Yamaha HTR-5760 goes to standby 2 seconds after power on
Maybe your device got the audio amplifier IC damaged
Jul 02, 2009 | Yamaha HTR-5760 Receiver
Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
Feb 25, 2009 | Yamaha HTR-5760 Receiver
My video out on my home theater system wont work.
your reciver probabily wont pass progressive through it, Hook the audio from the box to your reciever, and the video directily to your tv, thats a better way to do it anyway, your tv has alot better video prossesor than your reciver , or hook both audio and video to your tv, and run audio output from your tv to the reciver
Jan 11, 2009 | Sony HT-C800DP System
Front left and right speakers don't put out sound
Jan 11, 2009 | Yamaha HTR-6130 Receiver
Powers on but immediately shuts down
No I hate to be the one to give you the bad news but most likly the capacitors in the power supply or the output circuit of this reciver, are bad and most likly need to be overhouled. Or there is mosture contamination on the printed circuit board. It is time to let go and buy a new reciver, unless you want to invest big bucks into the repair of this reciver, as Im sure it can be repaired, but at what cost??
Oct 08, 2006 | Yamaha HTR-5250 Receiver
Yamaha HTR-5790 Receiver Logo
145 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
