Valor flamenco spark generator switch sticks down
Switch sticks which can be released by giving sharp tap on top of unit
3 Suggested Answers
SOURCE: instalation manual
hi there, did you mange to find a copy of the instructions for the valor flamenco unigas ii at all?? i need to replace the ignitor so would like to see a copy..
cheers
sharron
Posted on Oct 04, 2010
SOURCE: cannot get the pilot light
Is the clicker making the clicking noise? If not, it is most probably the spark generator which houses the battery. The part is still available online for about £40. It did the job for me.
Posted on Dec 20, 2010
Runs when start button pushed for several seconds then shuts down. Starts with button, but when button released, shuts down right away.
Odds are that the ignition switch or wires are giving you the grief.
Thee unit will probably be getting spark power through the starter solenoid (look for a wire there) but when the solenoid is not activated, there will be no ignition power.
Take your time and trace it down.
You'll get it.
Cheerfuls!
Aug 17, 2015 | Onan Cummins 5.5 HGJAB-901 RV QG 5500...
Gas gage stuck on full
This may be a short circuit on the wiring, Try locating the sender unit on the top of your fuel tank and disconnecting the wires. If gauge still shows full then the fault is in the wires or gauge in which case do the same at the gauge end to see if it is a wire short. If gauge goes to empty then actual float in tank may be stuck. YUou could try giving a sharp tap on top of tank but use something wooded to prevent damage or sparks.
Mar 20, 2012 | 2002 Nissan Xterra
Valor flamenco unigas 2 fire ignites but wont stay on, assume this thermocouple problem how is thermocouple replaced
Valor uses either a Thermocouple or Thermopile, depending on the unit. In some cases, it has both. And, yes, your assumption is probably correct. Some thermocouples are a part of the Pilot Assembly, which means you have to replace entire pilot assembly. If you check you Owners Manual in the Parts Breakdown section, it will indicate if it is or not and whether you need a Thermocouple or Thermopile or both.
If you're not familiar with repairing gas fireplaces, replacing the parts listed above, can be a little challenging. Especially if you don't have the proper tools. But, before you jump on this project, try cleaning the Pilot Orifice first. You can easily do this, using canned compressed air with a straw nozzle (like you clean your computer with) by blowing out the pilot tip. And while you're at it, clean all around the pilot assembly with the canned air. If cleaning the pilot solved your problem, you're back in business. If it didn't you'll have to go the other route.
Hope this helps you solve the problem. Please be kind enough to rate my reply to you. Thanks!
Mar 24, 2011 | Heating & Cooling
Cannot get the pilot light to ignite on my Valor Flamenco Unigas II when the ignition knob is pressed down. Have had the ignition battery out, but the voltage seems to be correct. Fire Serial No 005 344 No...
Oct 10, 2010 | General Heating & Cooling
Switch not making contac
Most likely you have a whirlpool washer design also called a direct drive unit. (most popular) If you tip the washer back, the motor is between the pump and the transmission with no belt. (one way to check)
these are service by releasing the control panel at the end caps and rotating the entire control panel up on the back panel plastic hinges.
You will see two spring clips holding the entire cabinet in position, release these and unplug the lid switch.
Do not forget to unplug unit and watch out for sharp edges on sheet metal edges of cabinet.
Apr 04, 2010 | Kenmore 23822 Top Load Washer
I have a valor hone flame gas fire. It is quite old now and I believe the ignition switch is faulty. Does this fire have a self generating ingier or ir there a battery ?
I believe the valor is self generating. Ours is also not working and we need to replace it. Any ideas where to purchase one?
Feb 10, 2010 | Valor Toys
The ignition keeps on sparking after the burner is lit.
How old oof a unit is it? The burners switches when on will operate ignitors for all burners no matter which switch is "turned on". Usually when units get older these switches on the most "often used" burners will stick and stay "connected" then all ignitors will continue to spark this is also true if switches accidentally get wet with spillage or water till they dry out. No danger though because jsut because ignitor is sparking doesnt mean gas is being released, gas is only released when valves are turned on
May 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Oil dip stick broke off about 1 inch in shaft
You have to remove the oil dipstick tube.  Most are just pushed into the engine block with a o ring seal.  With some effort you should be able to pull it directly out.  Have you tried a bent coat hanger with a barbed end?
The procedure is easy the acessability may be the hard part.
Mar 12, 2009 | 2004 Jeep Liberty
Instalation manual for valor flamenco unigas 111 balanced flue wall mount gas fire
cheers
sharron
Mar 08, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
