SOURCE: Can't get a Widget back!
This should help you...
Open your widget bar by touching the "W". Once it's open, add all of your widgets to the home screen. Stack them from top of the screen down. that should allow you to scroll down to the one you can't get to otherwise. Now simply move that one up higher, then begin to put back the ones you don't want into your widget bar in order from bottom to top. Once you have them docked back where you want them, click the "X" to close the widget bar.
Problem should be solved.
SOURCE: my memo pad widget disappeared from my home screen
Mine has just done the same.
Did you ever get your memo pad back?
If so, how?
SOURCE: Hi. My memo widget
Check page 38 does it help?
www.cellphones.ca/upload/manuals/lg-xenon-gr500-manual.pdf
Still problem persist then go for.
Reset:
Goto settings and select phone, then select reset settings and master reset . This will make all ofyour setting go back to default but it wont delete anything
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: can't remove widget from display
Try to tap the screen with your finger and hold for a few seconds. You should figure out the rest by yourself...
