Question about Gigabyte GA-G41M-ES2L Motherboard
GA-G41M-ES2 cmos clear password - Gigabyte GA-G41M-ES2L Motherboard
3 Suggested Answers
  • 4961 Answers
SOURCE: mather board Gigabyte Ga-G41M CMOS checksum error -Defaults loaded and keyboard and Mouse are not working
Replace the battery and make sure it has a good connection in it's seat. Download and reflash the BIOS again. The original download file may have been corrpted. If those steps don't fix it then there are only a couple remaining things that could be happening:
1) Bad CMOS memory chip. This does happen. It's a small, couple K battery backed chip. The chip itself, mainboard tracings or circuitry leading to it could go bad or be defective.
2) Mainboard is shorting on the case somewhere. The tracings on the mainboard can definately short/ground or have periodic shorts causing the cmos memory to become corrupt.
3) Something electromagnetic is effecting the CMOS memory. A poorly shielded fan or other magnetic source is wiping out the CMOS memory periodically. You don't have like a refridgerator magnet on the side of the case do you? :D
4) Temperature. If for some reason your mainboard has a hot-spot, excessive temperatures for the CMOS chip can cause it's contents to scramble.
5) Unstable power. If one of your voltage rails from the PSU is bad, it can wipe CMOS memory contents. Get a hardware monitor and let it run to watch voltage ranges.
6) BIOS virus. Some virus attack the BIOS/CMOS memory space. Run a full scan and if you cannot afford a good virus program, try AVIRA. Even if your system comes up clean, look for patterns in usage (like a particular CD you use when it happens, etc.etc.)
I'd say it's most likely just a bad chip/mainboard. I've seen this before.
Posted on Jun 14, 2012
  • 4961 Answers
Good Luck!
Checksum error
TRY WITH CLEAR CMOS.IT MAY HELP.
Sep 25, 2013 | Gigabyte GA-G41M-Combo Motherboard
After power on beeper beeps 9 times and computer doesn't working. What is it? Motherboard ga-g41m-es2l
error: 9 beeps is ROM checksum
Turn OFF the PC
1.- Clear the CMOS (jumper near the battery)
place the jumper in 2-3
return the jumper to normal position
2. Remove the battery
Turn on
enter to BIOS
Update bios from the Gigabyte web page
remeber rate my answer,,
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Gigabyte GA-G41M-ES2L Motherboard
Where would i get GA-G41M-ES2L driver
http://www.gigabyte.com/products/product-page.aspx?pid=3500#dl
In the Downloads section, select your OS, then download.
Sep 17, 2011 | Gigabyte GA-G41M-ES2L Motherboard
I want to reset BOIS password for Gigabyte GA EP43 motherboard which has no jumper, i try to remove battery but the problem unsolved~
There is a CLR CMOS jumper on that MB next to the SYS FAN 2 connector by the IDE header
open = no clr
jumped= Clear CMOS
From the manual page 32
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jul 20, 2011 | Gigabyte GA-EP43-UD3L Motherboard
How can i change intel chip on my gigabite motherboard
Try this . Explains quite a bit. http://www.iusermanual.com/motherboard/gigabyte-ga-g41m-es2l-motherboard-manual.htm
Feb 17, 2011 | Gigabyte GA-G41M-ES2L Motherboard
Forgot my password how to you clear the password
hi if you want clear BIOS password you need clear CMOS by pull up jumper witch is locate below IDE_1 socket on your motherboard
take a look in manual
http://download.gigabyte.us/FileList/Manual/motherboard_manual_8s661fxm-775_20_e.pdf
i hope it help please rate it
regards
Sep 08, 2010 | Gigabyte GA-8S661FXM-775 (4719331838096)...
I have got a motherbored and it has got a bios password on it and could any one help thanks
You can clear the password by clearing the CMOS. Your manual will show you how to clear the CMOS, If you don't have a manual, go to the gigabyte support website, enter your motherboard model, and you can download the manual
Oct 28, 2009 | Gigabyte Giga-Byte: GA-8S661FXMP-RZ P4...
Gigabyte GA-G41M-ES2L Motherboard Logo
26 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
