Question about Toshiba 20HLV15 TV
Power cord I have to replace power cord but I have no idea where it plugs into on the tv
  • Jean
    Jean Apr 14, 2014
    The tv model is 20hlv15
  • Jean
    Jean Apr 14, 2014
    Purchased in 2005, lost origanl cord
    New Friend:
    Problem Solver:
  • 13 Answers
The powercord connector is at the back. oval shape connector 2 metal pins
Posted on Apr 17, 2014
Why wont my lg 50 plasma tv turn
Perhaps replace your power cord. Borrow power cord from repair shop. If it works it's the cord. Also if the TV is plugged into power bar make sure the power bar hasn't been inadvertently turned off.
Oct 07, 2015 | LG Televison & Video
I have an Acer AT3720A TV and it's not getting any power at all and i know it's not the cord because i tested it and it's getting full power anyone have any idea as to how i can fix it?
your problem most probably lies with a burnt fuse in the back of the tv set.unplug the tv put on a solid surface and remove the back of the set.if you look carefully enough you wil spot a elongated glass casing with two bright metal ends.remove and inspect or test the fuse,and if burnt replace.now fit the back loosely on the set and plug in ,turn on and if it works,unplug refasten back and the job is done, congratulations.
Nov 21, 2011 | Acer Televison & Video
While watching the TV the screen went blank and there wasn't any sound. I've checked all the cables. I tried turning it off and back on but when I did this the power light flashes 27 times before...
The tv power supply board it is shorted and dead.That the board where the tv power a/c cord plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 28, 2011 | LG 32LC2R 32 in. HD-Ready LCD Television
YES I HAVE A FLATSCREEN AND THE POWER LIGHT COMES ON AND BLINKS AND NOTHING ELSE HAPPENS I HAVE HAD THIS TV LESS THAN 2 YEARS ANY IDEAS
Tries unplug,replug the tv back like an hour later.The tv now,is resetting back to factory setting.The tv should work now.Not,than the power supply board have problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 29, 2010 | Samsung LN-T2632H 26 in. LCD HDTV
Viewsonic N3735W LCD TV Hello, I connected my laptop to the VGA input and the TV powered off.After powering it back on it went off again. now it is completely dead. in standby mode and will not power...
Yes,the power supply board it dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 20, 2010 | ViewSonic N3735W 37 in. LCD TV
My Toshiba 52XV645U shuts off spontaneously after 2 hours. It isn't because the sleep timer is set. Any ideas?
Now,tv power up and picture come up and work normal again now wright?Only happen one time,than it just a power glitch.Happen often,than the power supply board is dying.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 20, 2010 | Toshiba Regza 52XV645U LCD TV
My HP LC3772N TV shuts off and then restarts again playing for 2-5 mins before it does it again. Any helpful ideas? Trying to decide between repair and replace. Thanks in advance
The power supply board is defective.That the board where the a/c power cord plug into it.Take ur tv aparts,replaced the power supply board should solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 29, 2010 | HP LC3772N 37 in. LCD Television
The power went off at my house due to an overload and when the breaker was turned back on, the tv had no power, no green or orange light. I unplugged the power cord and plugged it in later and the tv...
The power supply board is dead,that the board where the power cord plug into it.Take ur tv aparts,replaced the power supply board,ur tv should work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 23, 2010 | Vizio L32 32 in. LCD HDTV
Can you help me find a pwer cord for my 32''flat screen (Proton)
Unless this set is really oddball, it probably has the same type power cord connector used on computers and so many other electronic appliances. If this is the case, you can use a standard computer power cord as a replacement. The computer cord is a three-wire plug with a ground pin and the TV probably only had a two-prong plug, but the cord will still fit. Your electric outlet should be the three-prong type (if it's not, get it replaced!) so the plug will fit.
If the connector in the set is really different, you can check online by doing a Google search for replacement parts for you TV.
Nov 21, 2008 | Proton MM2701VT 27" TV
Power cord
Have you tried Toshiba Phils? Perhaps tehy can help, here are their contact details should you need it.
Alternately, if you are anywhere near Gonzalo Puyat (formerly Raon) you can try bringing the AC adapter and try fitting replacement power cord readily available on most stores. Additionally, most electronics part stores carry generic/replacement power cords and one should fit.
There are some versions that uses the same power cord as that of a desktop PC.
If you need the entire power adapter with cord, pls try here or here. Incidentally, any power adapter rated at 12VDC output @ 4amps should also work, you just have to make sure the polarity of the crown plug matches the Toshiba.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 12, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Toshiba 20HLV15 TV Logo
22 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
