Question about Speed Queen AWS45NW Top Load Washer
I have an industrial coin operated SPEEDQUEEN washing machine and I have been told I have to replace the PC board which is quite pricey. Is there anyone in South Africa that repairs these boards?
This is usually caused by dry and cracked up solder joints
take the board out and take it to a tv shop and ask the solder guru to resolder the board for you any bad connections
try this first
Posted on Dec 08, 2014
Its a commercialcoin operated machine that won't start washing what could be the problem please?
open the coin dispenser and push in the start button that the coin lever should push in when you put the correct coins in the dispenser
Feb 04, 2013 | Maytag Washing Machines
I have a coin operated timer control box for my washing machine. Someone turned the power off at the wall and now it won't work
Please confirm if the power was restored. Now If so then you can turn it off once again and wait for few minutes before switching it ON. Tap on sides while the machine if switched off to confirm if any coin was lodged while the power was off. If this is struck within you will need to remove the covers to clear the mechanism and reset the sensor action. Also check if there is power supply within the unit for the functioning of the control board.
Jan 25, 2013 | Washing Machines
Speedqueen gas dryer switch mechanism
my guess would be the door switch is not working somehow as it should start if the lights are on
Feb 01, 2012 | Dryers
I have an industrial 8.2 kg speedqueen washing machine and the water on completion of wash cycle is not exiting the machine. my machine is a top loader
check the pump filter first,, if its blocked up clear it out
then check that the pump is working it may just be stuck up,,,
Jul 01, 2010 | Washing Machines
Machine will run through entire cycle and will not spin. It quits at the spin cycle. I checked the Black boot at the bottom. Removed and cleared out coins. Checked pump- it was turning freely. Reinstalled...
I had a similar problem and found out the "latch" on the washer door broke off. The machine won't run in spin cycle if the door is"open", but it would run through the wash cycle.
Feb 05, 2010 | Frigidaire Washing Machines
Speedqueen washer coin operated turns on and says unbalanced load. The washer is empty. I have unplugged it and replugged it in, same problem. Best regards, Jim Iverson
normally you can access the unbalance switch from the back panel ,it may just need to be adjusted,it is activated from a trigger point on the top of the drum,hope this helps
Jan 08, 2010 | Washing Machines
Coin operated machines: slide mechanism is not moving back.
I had a coin washer and dryer.The slider has little fingers(metal)that slide over the coins.If the coin isn't placed and the slider is pushed hard will jam. Mine had a side cover with a lock. Open that and there is a long rod that has to be unscrewed to remove the lock box,then you should is what went wrong.Hope this helps>
Jul 04, 2008 | Whirlpool CAM2752RQ Coin Operated...
Water supply
look on the control board. there's some DIP switches. these are set according to the number of coins needed to run the machine. the coin acceptor reads the number of coins going through it and advances the control board one increment for each "good" coin. objectionable coins are rejected.
Sep 06, 2007 | Maytag MAT12CS Top Load Washer
Speed Queen AWS45NW Top Load Washer Logo
61 people viewed this question
Top Speed Washing Machines Experts
Dan Webster
Dan Webster
Coss
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
