Question about Haier HWR06XC9 Air Conditioner
Haier HWR06XC9 fan stopped working
I turn the unit on, but only the compressor comes on, the fan doesn't. After a few minutes the unit turns the compressor off and back on again. But the fan is still not spinning.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 136 Answers
Either the fan motor
the fan control relay
or the fan control relay switching transistor
the unit is re starting because the gas is not getting cooled
If competent check for voltage at the fan and work you way back
Posted on Apr 14, 2014
koolbreezes
  • 540 Answers
SOURCE: I have a Haier HWR05XC7
HEY< If you start out having problems , what do you think the future of that unit will be!
Posted on Sep 03, 2008
louislevel_2
  • 374 Answers
SOURCE: ++HAIER 3125. Fan shuts off.
hi! there it seems that your control circuit board is activating default set up or abnormal set up after recieving on control circuit board when you shut off the unit, there's a short circuit behind on holding relay when deactivation process is done, the holding relay should be cutting your entire source connection on compressor terminal when you shut off the unit, in this case try to isolate checking supply voltage behind relay and the supply source terminal of your relay, .try to check on this to your manual circuit diagram to lessen the complication of trouble shooting just focus on relay circiut,replace relay if defective.this is a hard job and should be done by qualified a/c technician. have a nice day regard and thank's a lot
Posted on Mar 30, 2009
  • 587 Answers
SOURCE: Fan stopped turning
Check yhe capacitor.
Posted on Aug 25, 2009
SOURCE: Haier 12,000 portable unit. Red light comes on STOP appears
Drained tank then operated fine
Posted on Oct 08, 2009
  • 106 Answers
SOURCE: Haier Mini spilt HSU18VC7 compressor runs for 5
This is called short cycling. It sounds like the compressor is getting hot and opening a bi-metal overload, which shuts the compressor off. The compressor cools, because it is not running and the bi-metal contacts close allowing the compressor to start again. This will repeat itself and is usually due to low refrigerant, which usually means there is a leak in the normally sealed refrigerant lines. The refrigerant cools the compressor windings and if it is low it cannot do that, hence the shutting off of teh compressor, cooling down process and restarting of your compressor. Short cycling will ultimately ruin the compressor.
If this has helped you please give me a rating worthy of my diagnosis.
Posted on Aug 03, 2011
Compressor stops running.
in dehumidifier modes work like in cool mode..try in cool mode too see if it work
Nov 30, 2013 | Haier CPN14XC9 Air Conditioner
HAIER HWR12XCA. Main fan stopped working. Condensor kicks on then kicks off after a few minutes. Any suggestions.
I would replace the fan capacitor. This is a split system and from the symptom you
describe, it would be the first thing I would look at since the compressor will go into
thermal overload and shut down if the fan is not running.
Fan caps are available online, Or you can get a substitute from a local appliance
parts store. Just be sure the value of the replacement is the same. Make sure power
is off at all sources feeding this unit before servicing. :)
Jul 31, 2011 | Haier HWR12XCA Air Conditioner
The air does not come on at all but the fan will work.
mcdevito75 Here, You may need a charge of freon, turn the a/c unit off completely and remove plug from wall for about 5 minutes, then plug back into wall, now just put the fan on for 5 minutes, now the cool control, tiur that slowly to it"s coolest point and ss if compressor comes on, if so back off the cool control slowly just until the compressor goes off, if compressor doesn"t come on, contact a local a/c repair shop in your area. They come to the house.
Sep 01, 2010 | Amana Heating & Cooling
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Duo Therm A/C unit will not run
It appears you may have a bad fan motor the reason the compressor stops is it is kicking out a low pressure switch to protect the compressor. You may be better taking it to an RV shop because I think you will have to remove the evap coil to change out the fan motor.
Jun 22, 2008 | Dometic Rooftop RV Air Conditioner
Haier dehumidifer HD656E
What you think it means is exactly what it does mean. When a running unit is shut off it should not be restarted until the system pressures have had time to balance out so the compressor can restart without difficulty.
Jun 18, 2008 | Haier 65-Pint Dehumidifier
The compressor only turn on once (GE AHH40LHG1)
before you go to fix it, what is the setting it is at? What is the tempurature of the room it is in? If the setting has been satified the unit has done it job and if it is too cold in the room it will not operate properly either.
Sgt 48
Jun 06, 2008 | GE AHG40LJ Dehumidifier
Haier HWR06XC9 Air Conditioner Logo
59 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
