Question about Garden
Weedeater XT 85T wont run
I have a weedeater 85T. It will start on full choke and run a few seconds if I pump the throttle then it dies. Wont even start on 1/2 or no choke.
I have changed the sparkplug shot carb cleaner in the intake(as soon as its burned up it dies also) . blew out the gas filter, put new gas in the unit ( I empty the tank each fall).
Also when I pump the fuel prime bulb after 2 pumps it stays in the ''pushed in'' position like it cant draw gas.
Thanks for any help or suggestions.
Scott
    Problem Solver:
  • 9 Answers
Check to see if your feul line is cracked or it is drawing air . Check your clamps that hold the lines on . One other thing you can check is to see if any bolts are loose that hold the carb on . Best of luck Ed.
Posted on Jun 18, 2009
Need new gaskets orprimer bulb
Posted on Jul 23, 2009
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
1979 GMC Carb issues
You haven't provided a lot to go on here but I'll take a stab in the dark. If you are somewhere that is unusually cold, maybe you just need to let it warm up. Could be the choke is not working, could be the choke is closing but wont open because the heat riser passage in the intake manifold is plugged up with carbon, could be the fuel pump is weak or the filter is plugged and the carb is starving for fuel even though the tank is full.
To check the choke operation, take off the air cleaner lid before you try to start it and operate the throttle by hand while watching the choke plate. It should snap shut. If it does rack the throttle two more times, start it up and watch the choke plate. it should open just a little (maybe 3/8') on a cold day let it run on fast idle for a few minutes, as it starts to warm up the choke should open more. And be fully open after a little while. Given it's age it would not surprise me at all if the carburetor is not working right. If you are going to take it to a shop, look for a mechanic in his late 40's. I know that sounds weird but most of the young guys out there have never even seen a quadrajet let alone rebuilt one.
Jan 28, 2014 | GMC Sierra 1500 Cars & Trucks
Homelite trimlite weedeater will start and idle in full choke position only. Cannot use any throttle or it dies. Cannot switch out of full choke or it dies. Cannot use any throttle to start it as well, if...
Fuel starvation either too the carb or in the carb itself, start with a simple cheap fix, replace the fuel filter in the tank on the end of the fuel hose.
Aug 16, 2013 | Garden
I have a 1994 Intruder. It only starts and runs
The hot side is running way too lean. Have your carbs synchronized may help. Try draining the bowls. Good luck.
May 28, 2010 | 1994 Suzuki VS 800 Intruder
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater wont run
Take the red and blue limiters off to adjust. Back out 1- 1 1/4 turns and go from there.
Jun 22, 2009 | Poulan Garden
Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Jun 21, 2009 | Garden
Weedeater xt-85t fuel leak
the float in the carb is stuck un screw the nut on the bottom of the carb take it off t6hen put it back on that should do it in the mean time leave that thing out side
May 06, 2009 | Garden
Garden Logo
701 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
