Question about Sceptre X322BV HD 32 inch Class Television 720P HDTV LCD/ PC Monitor Black -
Sound How do you get sound to external speakers
    Problem Solver:
  • 13 Answers
Your TV has a pair of analog RCA Audio Outputs on the back of the set. They are the red and white, female, round outputs and should be labelled as Audio Out. If you have a surround receiver or stereo that accepts this type of input (most do), then you would purchase a stereo RCA audio cable that has the red and white male ends on both ends of the cable and plug them in to the appropriate stereo RCA left and right channel audio inputs on your receiver and the aforementioned outputs on your TV. The same is true if you have a pair of self-powered computer speakers (or similar). If your external speakers or audio systems don't have the RCA inputs, you may need to get an adapter to convert the RCA output to stereo mini-jack (or similar) to match the appropriate input on your external speakers. Does that make sense?
Posted on Apr 17, 2014
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
No sound, when I click on the little speaker on the right hand lower coner the sound level bar is moving but no sound
Check the sound ICON at the lower right of the screen. Make certain the options are Internal Speakers and not EXTERNAL Speakers. Test by using a head phone in the external port to see if the sound is diverted properly. If you have sound OUT at the external Ports, then Reverse the option to Laptop Speakers.
May 09, 2014 | Sony VAIO VPCEB12FX PC Notebook
No sound
Your computer's external speakers are either disconnected or damaged. Let a computer technician repair them or use headphones/external speakers.
Take care!
damnor01
Sep 12, 2012 | Acer Aspire 5050 5430 Laptop
Can't turn off internal speakers when i have external speakers connected via headphone socket
First, check if you put the connector for external speakers all the way to the end. Sometimes when the connector isn't fully inside both internal and external speakers will work. After you do that, once you connect the external speakers, go to the sound settings in windows and look for the volume mixer. You can regulate the sound for each type of speaker there.
May 04, 2011 | Computers & Internet
No sound does it need an external speaker
hi, it does need a set of external speakers , if you intend playing music it will sound better if you buy a 2.1 setup ( 2 small speakers and a subwoofer) you can purchase reasonable ones for around £25 , if not playing music or games with sound effects then opt for a simple 2 speaker setup , plug the mini 3.5mm jack plug from the speakers into the green jack socket .
hope this helps
Feb 22, 2010 | E-Machines eMachines Desktop PC
IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
External speakers do not work on my MacBook pro
Plug in your external speakers then go to system preferences then sound when in the sound control panel go to the output tab and select the external speakers as the device for sound output and of course at the bottom of the control panel make sure that the mute check box is unchecked and turn up the volume. Hope this helps
Oct 08, 2009 | Apple MacBook Pro Laptop Computer with...
Compaq Evo N610c No internal sound
No, you need not to install soud/audio driver if its work with external speakers. Its seems that the internal speaker of your laptop has got damaged. So you shuld call your vendor for service. If you are in warranty it will be free for you.
Thanks
Iqbal
Mar 05, 2008 | HP Compaq Evo n610c Notebook
Computer speakers work but external speakers do not
Schuttie
hello there!
First Things First:
1) Check if your external Speakers are connected on the external sound card output connector **
2) Check on control panel and multimedia if your sound card (external) is enable, and not MUTED sound. Rise the volume.
3) check cables from Speakers and see if not old or broke.
Good Luck
Feb 09, 2008 | Audio Players & Recorders
Sceptre X322BV HD 32 inch Class Television 720P HDTV LCD/ PC Monitor Black - Logo
89 people viewed this question
Top Sceptre Computers & Internet Experts
Robert Veldman
Robert Veldman
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
