Question about Canon FAX-B820 Plain Paper Bubblejet
Code 342 How can i go in Service Menue to reset the Wasst ink-counter?
  • 23 Answers
Did you scoop all the ink out of the tank? why reset it so it leaks into the machine?
Posted on Apr 30, 2014
E8 Waste ink absorber full, or platen waste ink absorber full WHAT MUST DO?
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Jan 14, 2011 | Canon PIXMA MP190 All-In-One InkJet...
The waste ink absorber is full
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
Jan 04, 2011 | Canon PIXMA iP90 Mobile Printer
Canon B820 error ##342
wast ink counter filled 100%. reset ink counter and replace ink absorbers.
Dec 07, 2010 | Canon FAX-B820 Plain Paper Bubblejet
How can you reset the waste toner counter?
Hello there :
in the main menue of the printer there is a option that lets you reset it to zero but if this is a buisness printer you might have to have the company come and set it for you cause theire somtimes is a code that is entered to get to the main menue
Oct 23, 2009 | Xerox Phaser 6110 All-In-One Laser...
I need the reset code for cannon starwriter 350
Canon GENERIC "S" SERIES RESET CODE
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in
succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
or move momentarily. If the above was properly performed the printer will enter the
"Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp
will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Oct 08, 2009 | Canon Office Equipment & Supplies
Reset code for epson px700w ink pads showing full
Hi
You can purchase a service manual and the service program for your printer from. http://www.2manuals.com/index.php?cPath=56
the computer program is used to reset the waste ink counter, follow instructions in the service manual to first replace the was ink pads, only then reset the waste ink counter with the service software for your model.
It would be recommended to take this to a epson service center, but you may do this at home if you wish.
Thanks and good luck,
Ekse
Aug 14, 2009 | Epson Office Equipment & Supplies
Canon Fax Machine B120 ##342
1.) press function then # u reach SERVICE MODE
2.) arrow right until TEST MODE confirm with Start / Enter (green button)
TEST MODE [1] - [8]
3.) press # ... u reach AMI MODE [1] - [*9]
4.) press 7 ... u reach FACULTY [1] - [6]
5.) press 6 ... .u reach LOST INK CHECK...confirm with green button...
u get [1] - [2]....
6.) press 2 u reach SET LOST INK CNT....confirm with green button...
u get LOST INK = 100 (in my case it was 100 ..this was the error..)
7.) press 0 (the digit zero..) confirm with green button...
8.) wait a few seconds....the unplug and reboot....
this worked in my case....
Apr 08, 2009 | Canon FAX-L250
My epson stylus photo r230 keep flashing the 2 red light????
this means your printer wasst pad if full this can be reset without puting new pads in at your own rick has ink may come out let me no and i will send you the info on now to reset your printer
Feb 19, 2009 | Epson Stylus Photo R300 InkJet Printer
Canon FAX-B820 Plain Paper Bubblejet Logo
180 people viewed this question
old marine
old marine
