Question about Magellan Cycling
Raising handle bars
Hi. I have loosened every nut possible in an attempt at raising the handle bars and it won't budge. Any advise? Thanks
    Novelist:
    Scholar:
  • 132 Answers
Right in the center of the handle bars you will find a nut ( usually allen key) that is in line with the tube going down/attached to the fork of the bicycle. Loosen this nut and unscrew it for about 5mm - don't remove it completely. Take a mallet and hit the nut firmly on its head to force it back the 5 mm unscrewed. It should release the tapered lock inside the tube and the handles can be adjusted. If it is still stuck, unscrew the nut more and repeat the process. After adjustment tighten the nut firmly, while holding the handles in position. It will lock again as it is getting tightened. Make sure it is secure by "clamping" the front wheel between your legs while trying to move the handles in any direction. Handle movement should not be possible when applying moderate to strong force. However, excessive force will result eventually in movement and or damage to the front wheel and is therefor not required.
Posted on Apr 16, 2014
4 Suggested Answers
  • 10 Answers
SOURCE: Schwinn Impact MOS.....can the handle bars be raised...
In order to raise the handle bars, you will need a hex key. Put it into the hex indentation at the top. Turn it left to loosen it. Then raise the handle bars to the desired height.
Posted on May 22, 2010
Testimonial: "Very Helpful because it is not an ordinary handle-bar and I didn't know which one to loosen. "
Coachphil
  • 347 Answers
SOURCE: I would like to raise
Hey joe - Sounds like you have a classic stuck stem. Here are a couple things to try.
1 - Loosen the stem through the top bolt so the wedge is loose, but not removed. The give the top of the stem a good hit or two with a plastic mallet. That should break the bond between the steerer and the stem. If that does not work...
2 - Use liquid Wrench and drip around the stem so it seeps in-between the stem and steerer. Let sit a while then try the plastic mallet again.
sometimes you will need to work the stem back and forth a bit by using the handlebars as leverage and bracing the front wheel between your knees.
If neither of these get your stem loose, then it's time to take into a bike shop.
BTW - stems have a maximum insertion/ extension. There is a line of max extenstion that should be on the shaft when you get it removed. If you discover that the stem will not raise your handlebars enough, then you can get a replacement stem with a higher shaft and greater angle to lift the bars up.
Posted on Nov 18, 2010
  • 8 Answers
SOURCE: I want to raise my handle bars just a bit have
There is a bolt at the top of the stem (the part that fits in to the fork and clamps around the handle bars) which is the only thing you need to loosen to raise the handlebars.
It should only need to be loosened 2 or so full rotations. (If you have loosened it a lot, tighten it back up a bit.) The secret is that you need to bop that bolt with a mallet. (The stem is held in place by 2 wedges- they jam together to make the connection secure. Sometimes they get a little stuck.)
If that doesn't work, try loosening the bolt another turn and bopping it harder.
(Make sure that you don't raise the stem up any higher than the "insertion point"- the series of lines on the stem to mark it's maximum height. And make sure that you don't damage the bolt from hitting it too hard.)
If that doesn't work- I'd recommend taking it to a shop. They shouldn't charge to much for the adjustment... all the shop's I've worked at would do it either for free or for under $10.
Posted on Dec 07, 2011
I want to raise my handle bars just a bit have unscrewed everything and still won't budge
Sep 25, 2011 | Huffy 26 in. Cranbrook Cruiser Bike
How do I remove the castle nut on the hub assembly of my 2001 Dodge Ram? I need to replace the hub but I can't get the castle nut to budge. Impact guns and breaker bars won't move it at all.
the nut that you are trying to undo may be a left hand thread ( anti clockwise to undo ) try it that way to see if it loosens it ........cheers.
Sep 22, 2011 | 2001 Dodge Ram 1500 Truck 2WD
I just purchased a Protocol 1 bike. I need to raise the handle bars. What is the procedure? Thank you for time. Carter McFall
Loosen up the goose neck in the center of the handle bars. There is a bolt there. Directly under that bolt you will see a large nut. Get a pair of channel locks or a crescent wrench and loosen up that nut and you should be able to push up or pull down to loosen the handle bars and change the height. Once you get them where you want them, remember to tighten up the large nut as well as the bolt on the goose neck.
Jul 06, 2011 | Schwinn Protocol 1.0 Men's Dual-Suspension...
Lug nuts on right rear tire won't loosen! Turning counter-clockwise, won't budge.
pur a long bar on the end of the socket say about 3ft long as the nuts have been done up with a wrench gun ,max torque for a wheel nut is 40lbs and yours are about 120 i reckon
Jun 27, 2011 | 2004 Hyundai XG350
I would like to raise the handlebars. I have loosened the stem wedge nut and the handle bars will not budge. I've tried everything almost to the point of losing the ball bearings in the steering shaft. Are...
Nov 11, 2010 | Cycling
How do you raise the handle bars on a mongoose scorch bike?
there should be an allen wrench bolt on top of the handle bar shaft. loosen that but not to much because you dont want the tightening nut to fall off. now put the front tire between your legs and try to wiggle the handle bars back and forth while pulling up if it does not move try loosening it a little more and take off the first bolt on the shaft and that should work. i hope this helped you
SabiousOne
Nov 07, 2010 | Mongoose Exile 26 Men's Full-Suspension...
How do i raise the handlebars?
There are two bolts in the center of the handle-bars. One bolt (on some bikes this is actually 4 bolts) is used to clamp the handle-bars to the handle-bar-stem. You can see both ends of this bolt. If you loosen it, you can tip the handle-bars up and down, but not raise them. The other bolt you can only see the head of. Loosen this a couple of turns (don't unscrew it all the way) then give it a tap with a hammer. You will then be able to pull the handle-bar-stem completely out. Do this so that you can see the wedge-shaped nut at the other end of the bolt. You should also see a mark on the stem that indicates how high you can safely raise the stem. Put the stem back in to the desired height and tighten it back up. Good luck.
Jun 11, 2010 | Huffy 26 in. Cranbrook Cruiser Bike
How do you hire the handle bars on a giant mountain bike
Hello. You will need an adjustable wrench. Then look at the center of the handlebars and you will see a bolt and a nut. Usually the nut is on the underside. Loosen the nut, raise the handle bars and retighten the nut. J.
Jun 01, 2010 | Giant Boulder Se Mountain Bike 19"...
Schwinn Impact MOS.....can the handle bars be raised? If so, do you loosen the small star nut on top, or the large nut at the base of the handle bars?
May 22, 2010 | Cycling
How do i adjust the handle bars to go higher?
there is a nut on the lower part of the hadel bars you loosen that up then rais handel bars.
Jul 02, 2009 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Cycling Logo
88 people viewed this question
Top Magellan Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Magellan Cycling Expert? Answer questions, earn points and help others
